309-65299
Article Number: 309-65299
Heat Shrink Tubing, 4FT-Stick, 2:1, 1", 25.4/12.7 dia., Polyolefin, White, 5/pkg
Base Data
Local Order Number 309-65299
Type TFN21-ST 25.4/12.7 WH
Color White (WH)
Features and Benefits • Thin, 2 to 1 shrink ratio tubing provides insulation and abrasion protection for wires and cables.
• Flammability rating of UL224 VW-1 for use in applications requiring the highest degree of flame protection (excludes
clear tubing).
• Flexible-yet-durable material resists most common oils, chemicals and fluids.
• Available in a variety of diameters and colors for identifying and marking wires and cables.
• Available in mini reels, bulk reels, and sticks for small to large volume applications.
Product Description TFN21 is a highly flexible thin wall heat shrink tubing with a 2 to 1 shrink ratio and excellent flame retardant
properties. In addition to providing insulation and abrasion protection for wires and cables, the polyolefin material also
offers resistance to oils, solvents and chemicals. Available in mini reels, bulk reels and sticks, for small to large
Short Description Heat Shrink Tubing, 4FT-Stick, 2:1, 1", 25.4/12.7 dia., Polyolefin, White, 5/pkg
Product Dimensions
Length L2 (Imperial) 4.0 ft
Length L2 (Metric) 1.22 m
Printable (Yes/No) Yes
Shrink Ratio 2:1
Tensile Strength (MPa) 14 MPa
Trade Size 1 "
Variant Thin-Wall
Volume Resistance (Ohm cm) 10¹ Ω cm
Nominal Diameter (Imperial) 1 "
Nominal Diameter (Metric) 25.4 mm
Wall Thickness WT (Imperial) 0.034 "
Wall Thickness WT (Metric) .87 mm
Recovered Diameter d (metric) 12.7 mm
Recovered Diameter d (imperial) 0.5 "
Supplied Diameter D (imperial) 1.0 "
Supplied Diameter D (metric) 25.4 mm
Logistics and Packaging
Quantity Per pack
Package Quantity 5
Material and Specifications
Material Polyolefin, cross-linked (PO-X)
Material Shortcut PO-X
Dielectric Strength (Metric) 20 kV/mm
Elongation at break 600%
Flammability UL224 VW-1
Halogenfree No
Shrink Temperature +212 °F (+100 °C)
Operating Temperature -67°F to +275°F (-55°C to +135°C)
ROHS Compliant Yes
Certification/Specification CSA
UL224 125 °C 600V VW-1
UL Recognized (US) Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“309-65299”相匹配的价格&库存,您可以联系我们找货
