309-65276
309-65276
    HELLERMAN(海尔曼太通)
    HEATSHRINK1-1/4"X4'GN
309-65276 数据手册
309-65276 Article Number: 309-65276 Heat Shrink Tubing, 4FT-Stick, 2:1, 1.25", 31.8/15.4 dia., Polyolefin, Green, 10/pkg Base Data Local Order Number 309-65276 Type TFN21-ST 31.8/15.9 GN Color Green (GN) Features and Benefits • Thin, 2 to 1 shrink ratio tubing provides insulation and abrasion protection for wires and cables. • Flammability rating of UL224 VW-1 for use in applications requiring the highest degree of flame protection (excludes clear tubing). • Flexible-yet-durable material resists most common oils, chemicals and fluids. • Available in a variety of diameters and colors for identifying and marking wires and cables. • Available in mini reels, bulk reels, and sticks for small to large volume applications. Product Description TFN21 is a highly flexible thin wall heat shrink tubing with a 2 to 1 shrink ratio and excellent flame retardant properties. In addition to providing insulation and abrasion protection for wires and cables, the polyolefin material also offers resistance to oils, solvents and chemicals. Available in mini reels, bulk reels and sticks, for small to large volume applications. Short Description Heat Shrink Tubing, 4FT-Stick, 2:1, 1.25", 31.8/15.4 dia., Polyolefin, Green, 10/pkg Product Dimensions Length L2 (Imperial) 4.0 ft Length L2 (Metric) 1.22 m Printable (Yes/No) Yes Shrink Ratio 2:1 Tensile Strength (MPa) 14 MPa Trade Size 1-1/4 " Variant Thin-Wall Volume Resistance (Ohm cm) 10¹ Ω cm Nominal Diameter (Imperial) 1-1/4 " Nominal Diameter (Metric) 31.8 mm Wall Thickness WT (Imperial) .039 " Wall Thickness WT (Metric) 1.00 mm Recovered Diameter d (metric) 15.9 mm Recovered Diameter d (imperial) 0.625 " Supplied Diameter D (metric) 31.8 mm Supplied Diameter D (imperial) 1.25 " Logistics and Packaging Quantity Per pack Package Quantity 10 Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Dielectric Strength (Metric) 20 kV/mm Elongation at break 600% Flammability UL224 VW-1 Halogenfree No Shrink Temperature +212 °F (+100 °C) Operating Temperature -67°F to +275°F (-55°C to +135°C) ROHS Compliant Yes Certification/Specification CSA UL224 125 °C 600V VW-1 UL Recognized (US) Yes © HellermannTyton 2015
309-65276
物料型号:309-65276
器件简介:TFN21是一种高柔性的薄壁热缩管,具有2:1的收缩比和出色的阻燃性能。它为电线和电缆提供绝缘和耐磨保护,聚烯烃材料还具有抗油、溶剂和化学品的特性。
引脚分配:文档中没有提供关于引脚分配的信息,因为它是关于热缩管的,而不是电子元件。
参数特性: - 收缩比:2:1 - 抗张强度:14 MPa - 体积电阻率:10^1 Ω cm - 标称直径:1-1/4" (31.8 mm) - 壁厚:0.039" (1.00 mm) - 收缩后直径:0.625" (15.9 mm) - 供应直径:1.25" (31.8 mm) - 工作温度范围:-67°F 至 +275°F (-55°C 至 +135°C) - 阻燃等级:UL224 VW-1
功能详解:TFN21热缩管提供绝缘和耐磨保护,具有优异的阻燃性能,并且材料抗油、抗溶剂和抗化学品。它适用于小到大批量的应用。
应用信息:适用于需要最高防火保护的应用,并且材料灵活耐用,可抵抗大多数常见油脂、化学品和流体。
封装信息:提供直径和颜色多样,可用于识别和标记电线和电缆。包装形式包括迷你卷、大卷和棒状,适用于不同应用规模。
309-65276 价格&库存
很抱歉,暂时无法提供与“309-65276”相匹配的价格&库存,您可以联系我们找货
