HEATSHRINK
TUBING
2:1 PTFE Heatshrink Tubing
2:1 Polytetrafluoroethylene heatshrink tubing has the lowest coefficient of friction
of any polymer and possesses a broad temperature range, allowing it to excel
equally in extreme cold and hot environments.
When ordering our 2:1 PTFE heatshrink, order as size after shrinking.
Nominal
Size
Part
Unshrunk
Diameter
Shrunk
Diameter
Wall
Thickness
Put Up/4’Pcs.
24 AWG
22 AWG
20 AWG
19 AWG
18 AWG
17 AWG
15 AWG
14 AWG
13 AWG
12 AWG
11 AWG
10 AWG
9 AWG
1/8”
8 AWG
7 AWG
6 AWG
5 AWG
4 AWG
3 AWG
1/4”
2 AWG
1 AWG
5/16”
0 AWG
3/8”
7/16”
1/2”
5/8”
3/4”
7/8”
1”
M23053-12-201-C
M23053-12-202-C
M23053-12-203-C
M23053-12-204-C
M23053-12-205-C
M23053-12-206-C
M23053-12-207-C
M23053-12-208-C
M23053-12-210-C
M23053-12-211-C
M23053-12-212-C
M23053-12-213-C
M23053-12-214-C
M23053-12-215-C
M23053-12-216-C
M23053-12-217-C
M23053-12-218-C
M23053-12-219-C
M23053-12-220-C
M23053-12-221-C
M23053-12-222-C
M23053-12-223-C
M23053-12-224-C
M23053-12-225-C
M23053-12-226-C
M23053-12-228-C
M23053-12-229-C
M23053-12-230-C
M23053-12-231-C
M23053-12-232-C
M23053-12-233-C
M23053-12-234-C
1.27mm
1.40mm
1.52mm
1.65mm
1.93mm
2.16mm
2.79mm
3.05mm
3.56mm
3.81mm
4.32mm
4.85mm
5.21mm
5.46mm
6.10mm
6.86mm
7.67mm
8.13mm
9.40mm
9.91mm
10.41mm
10.92mm
11.43mm
11.94mm
11.94mm
14.22mm
16.64mm
19.05mm
23.62mm
28.58mm
33.27mm
38.10mm
0.69mm
0.81mm
0.99mm
1.09mm
1.24mm
1.37mm
1.70mm
1.83mm
2.03mm
2.26mm
2.57mm
2.84mm
3.15mm
3.30mm
3.58mm
4.01mm
4.52mm
5.03mm
5.69mm
6.32mm
6.60mm
7.06mm
7.90mm
8.36mm
8.81mm
10.13mm
11.73mm
13.31mm
16.64mm
19.96mm
23.14mm
26.31mm
0.30mm
0.30mm
0.41mm
0.41mm
0.41mm
0.41mm
0.41mm
0.41mm
0.41mm
0.41mm
0.41mm
0.41mm
0.51mm
0.51mm
0.51mm
0.51mm
0.51mm
0.51mm
0.51mm
0.51mm
0.51mm
0.51mm
0.51mm
0.51mm
0.51mm
0.64mm
0.64mm
0.64mm
0.76mm
0.89mm
0.89mm
0.89mm
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Available
Colors
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
Clear
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
(CL)
• Shrink Temperature
650°F (343°C)
• Mil-I-DTL-23053/12
• Excellent Dielectric
Strength
• Resistant to All
Common Solvents,
Acids, and Bases
• High Operating Temp.
up to to 500°F (260°C)
Splice sleeving
Adhesive lining
Hot Fusion Tape
Techflex hot-melt adhesive tape works great in conjunction with our sleeving
and heatshrink products. HFA has good adhesion to polyolefin, PET, PVC,
copper, and nylon. Hot Fusion Tape is very flexible and can be field cut to fit your
application. Use when extra adhesive may be needed, in areas between wire
bundles for weatherproofing, or under heatshrink products not available with
pre-coated dual wall adhesive. Tape activates easily when shrinking your tubing.
Nominal
Size
Part
Width
Thickness
2”
HFA2.00CL
1.97”
0.012”
Standard Spool Put-Ups
Bulk Spool
Shop Spool
Available
Colors
Lbs/
100’
100’
25’
Clear (CL)
1.16
Added waterproofing
1-973-300-9242
www.techflex.com
87
很抱歉,暂时无法提供与“M23053-12-204-C”相匹配的价格&库存,您可以联系我们找货
