300-30160
300-30160
    HELLERMAN(海尔曼太通)
    2:1 RATIO HS DISPENSER BOX
300-30160 数据手册
Insulation Heat Shrinkable Tubing 2.1 Storage Rack for HIS-Boxes HIS-Service Station HIS general purpose heat shrink tubing provides a reliable insulation and protects against corrosion and mechanical influences. The handy dispenser is ideal for small and medium size projects on-site. The sturdy metal HIS Service Station comes with a cutter and can store all sizes and colours. The Service Station can be mounted to the wall in the work shop or service-van. Features and Benefits • Contains up to 5 dispenser boxes • Place on bench or mount to wall • Special cutter included for easily cutting tubing length to size TYPE HIS Service Station HIS Rack/Rite On HIS-Service Station contains 5 dispensers and a special cutter. Description Article-No. HIS-Service Station incl. cutter, contents: 5 dispensers HIS-3 (shrink ratio: 3:1), black, sizes are as follows: HIS-3/1, HIS-6/2, HIS-12/4 (2 pcs.), HIS-24/8 365-30100 HIS-Service Station incl. cutter, contents: 5 dispensers HIS-Pack (shrink ratio: 2:1), black, sizes are as follows: HIS-1/8, HIS-3/16, HIS-1/4, HIS-3/8, HIS 1/2 365-20000 HIS-Service Station incl. cutter, empty 300-30000 HIS Service Station All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Heat Shrinkable Tubing 2:1 on a Reel HIS-PACK HIS-PACK is used in general purpose of electrical insulation with a high level of protection against corrosion and mechanical abrasion. Features and Benefits • Cross-linked Polyolefin, thin-wall and flexible • Handy dispenser box including table showing application size range • Available in black, red, blue, transparent and yellow/green • 10 sizes from 1.2 mm to 25.4 mm HIS-PACK. Heat Shrinkable Tubing 2:1 Date of issue: October 2015 Detailed Information about Heatguns please refer to page 529. MATERIAL Polyolefin, cross-linked (PO-X) Shrink Ratio 2:1 Operating Temperature -55 °C to +125 °C Minimum Shrink Temperature +100 °C Longitudinal change after shrinkage +/-5 % Dielectric Strength 20kV/mm according to ASTM D2671 Flammability UL224 VW-1 (except clear) Specifications SAE - AMS - DTL-23053/5 Class 1 and 3, SAE - AMS - DTL-23053/5 Class 2 (clear), UL224 125 °C 600V VW-1 For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/insulation 201 Insulation 2.1 Heat Shrinkable Tubing Heat Shrinkable Tubing 2:1 on a Reel HIS-PACK HIS-PACK-1.2/0.6 HIS-PACK-1.6/0.8 HIS-PACK-2.4/1.2 HIS-PACK-3.2/1.6 HIS-PACK-4.8/2.4 HIS-PACK-6.4/3.2 HIS-PACK-9.5/4.7 HIS-PACK-12.7/6.4 HIS-PACK-19.1/9.5 HIS-PACK-25.4/12.7 Supplied Ø D min. Size (imperial) Recov. Ø d max. Wall (WT) Reel Length Colour 1.2 3/64 " 0.6 0.40 10 m Black (BK) 300-30120 1.2 3/64 " 0.6 0.40 10 m Blue (BU) 300-30126 1.2 3/64 " 0.6 0.40 10 m Red (RD) 300-30122 1.2 3/64 " 0.6 0.40 10 m Transparent (CL) 300-30123 1.6 1/16 " 0.8 0.40 10 m Black (BK) 300-30160 1.6 1/16 " 0.8 0.40 10 m Blue (BU) 300-30166 1.6 1/16 " 0.8 0.40 10 m Red (RD) 300-30162 1.6 1/16 " 0.8 0.40 10 m Transparent (CL) 300-30163 2.4 3/32 " 1.2 0.50 10 m Black (BK) 300-30240 2.4 3/32 " 1.2 0.50 10 m Blue (BU) 300-30246 2.4 3/32 " 1.2 0.50 10 m Red (RD) 300-30242 2.4 3/32 " 1.2 0.50 10 m Transparent (CL) 300-30243 3.2 1/8 " 1.6 0.50 10 m Black (BK) 300-30320 3.2 1/8 " 1.6 0.50 10 m Blue (BU) 300-30326 3.2 1/8 " 1.6 0.50 10 m Green-Yellow (GNYE) 300-30327 3.2 1/8 " 1.6 0.50 10 m Red (RD) 300-30322 3.2 1/8 " 1.6 0.50 10 m Transparent (CL) 300-30323 4.8 3/16 " 2.4 0.50 10 m Black (BK) 300-30480 4.8 3/16 " 2.4 0.50 10 m Blue (BU) 300-30486 4.8 3/16 " 2.4 0.50 10 m Green-Yellow (GNYE) 300-30487 4.8 3/16 " 2.4 0.50 10 m Red (RD) 300-30482 4.8 3/16 " 2.4 0.50 10 m Transparent (CL) 300-30483 6.4 1/4 " 3.2 0.60 5m Black (BK) 300-30640 6.4 1/4 " 3.2 0.60 5m Blue (BU) 300-30646 6.4 1/4 " 3.2 0.60 5m Green-Yellow (GNYE) 300-30647 6.4 1/4 " 3.2 0.60 5m Red (RD) 300-30642 6.4 1/4 " 3.2 0.60 5m Transparent (CL) 300-30643 9.5 3/8 " 4.7 0.60 5m Black (BK) 300-30950 9.5 3/8 " 4.7 0.60 5m Blue (BU) 300-30956 9.5 3/8 " 4.7 0.60 5m Green-Yellow (GNYE) 300-30957 9.5 3/8 " 4.7 0.60 5m Red (RD) 300-30952 9.5 3/8 " 4.7 0.60 5m Transparent (CL) 300-30953 12.7 1/2 " 6.4 0.60 5m Black (BK) 300-31270 12.7 1/2 " 6.4 0.60 5m Blue (BU) 300-31276 12.7 1/2 " 6.4 0.60 5m Green-Yellow (GNYE) 300-31277 12.7 1/2 " 6.4 0.60 5m Red (RD) 300-31272 12.7 1/2 " 6.4 0.60 5m Transparent (CL) 300-31273 19.1 3/4 " 9.5 0.80 5m Black (BK) 300-31900 19.1 3/4 " 9.5 0.80 5m Blue (BU) 300-31906 19.1 3/4 " 9.5 0.80 5m Green-Yellow (GNYE) 300-31907 19.1 3/4 " 9.5 0.80 5m Red (RD) 300-31902 19.1 3/4 " 9.5 0.80 5m Transparent (CL) 300-31903 25.4 1" 12.7 0.90 5m Black (BK) 300-32540 25.4 1" 12.7 0.90 5m Blue (BU) 300-32546 25.4 1" 12.7 0.90 5m Green-Yellow (GNYE) 300-32547 25.4 1" 12.7 0.90 5m Red (RD) 300-32542 25.4 1" 12.7 0.90 5m Transparent (CL) 300-32543 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. For product specific approvals and specifications please refer to the Appendix. 202 Article-No. Further information at www.HellermannTyton.com/insulation Date of issue: October 2015 TYPE
300-30160 价格&库存
很抱歉,暂时无法提供与“300-30160”相匹配的价格&库存,您可以联系我们找货
  • 1+149.172071+19.32300
  • 3+139.925153+18.12520
  • 5+131.550585+17.04040
库存:67
