H2P0.50CL25
H2P0.50CL25
    TECHFLEX
    PVCHEATSHRINK1/2"CLEAR25'
H2P0.50CL25 数据手册
HEATSHRINK TUBING Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put-Ups S  hrink Temperature 212°F (100°C) I deal Finish For Cosmetic Applications H  eat Resistance Up To 221°F (105°C) E  xcellent Oil, Moisture, And Fungus Resistance E  asily Installs Over Connectors And Splices Nominal Size Part # Unshrunk Diameter /mm Shrunk Diameter /mm Put-Ups Bulk Spool Shop Spool 1/16” 1/4” 5/16” 3/8” 1/2” 5/8” 3/4” 1” 1 1/2” 2” 2 1/2” 3” H2P0.06 H2P0.25 H2P0.31 H2P0.38 H2P0.50 H2P0.63 H2P0.75 H2P1.00 H2P1.50 H2P2.00 H2P2.50CL H2P3.00CL 1.6 6.4 8.0 9.5 12.7 15.9 19.1 25.4 38.1 50.8 63.5 76.2 0.8 3.2 4.0 4.8 6.4 7.9 9.5 12.7 19.1 25.4 31.8 38.1 1,000' 250’ 250’ 250’ 250’ 250’ 250’ 250’ 100’ 100’ 100’ 50’ 100' 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25' 25’ 25’ 25’ Available Colors Lbs/ 100’ 2 2 2 2 2 2 2 2 2 2 Clear CL Clear CL 0.20 0.60 0.70 0.80 1.10 1.16 1.90 3.00 5.30 8.02 9.45 18.00 PVC 2:1 Heatshrink Tubing Shrinks To 1/2 its original diameter! PVC tubing is a Polyvinyl Chloride heatshrink tubing that shrinks to 1/2 its original diameter. During the shrinking operation, the tubing will encapsulate any device inside of it at the time and will assume the contour of that device. Cut Cleanly Scissor Material Polyvinyl Chloride Grade H2P Ultra clear PVC heatshrink tubing is ideal for application where complete transparency is required. Perfect for protecting exposed wires and cables on motorcycles and custom automobiles. Resists gasoline, oil, and common chemicals; provides protection from abrasion and severe environments. Perfect tubing for application where complete transparency is required. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 VW-1 Colors Available: Clear (CL) & Black (BK) HEATSHRINK TUBING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet FLAMMABILITY Moisture Absorption % ASTM D-570________________0.5 Flammability Rating___________ Self-Extinguishing VW-1 Corrosion MIL-I-23053__________________ No Corrosion 212°F(100°C) Maximum Continuous Mil-DTL-23053 221°F (105°C) Minimum Continuous Mil-DTL-23053 -4°F (-20°C) Measure the Shrinkflex® tubing to length and cut with a scissor. The thickness of your bundle, as well as the desired final appearance, will determine the length of the tubing you cut. Generally, a piece 1 1/2” - 2” long will accommodate almost any need. Single wires, or smaller bundles, require shorter pieces. Slip the Shrinkflex® tubing over the bundle and position it so that both the sleeved and unsleeved portions are sufficiently covered. Notice the small pieces of tubing installed on single wires as part of a color coding system. If your project requires multiple operations, always work up from the smallest to the largest bundle. Gently apply heat to Shrinkflex® tubing from a heat gun, hair dryer or torch with an appropriate attachment. Keep the heat source far enough away so that hot metal or direct flame does not come in contact with the tubing, wires or sleeving. Move the heat around the bundle to prevent damaging the sleeving and to ensure that all areas of the tubing have been shrunk. Once cooled, your installation is complete. PHYSICAL PROPERTIES Recommended Cutting_____________________ Scissors Stock Colors____________________________________ 2 Tensile Strength PSI ASTM D-638________________ 3,000 Elongation % ASTM D-638_______________________ 300 Specific Gravity ASTM D-792____________________ 1.32 Deformation % (250°F/121°C, 1 Hr.)________________ 50 MIL-I-23053 Heat Shock (250°F/121°C, 1 Hr.)____________ No Cracking MIL-I-23053 Cold Bend (14°F/-10°C, 1 Hr.)______________ No Cracking MIL-I-23053 Flexibility______________________________ No Cracking MIL-I-23053 Secant Modulus PSI ASTM D-882_______________ 19,500 Longitudinal Shrinkage (%)_______________________ 15 Dielectric Strength (volts/mil) ASTM D-876________ 1,083 Volume Resistivity (ohm-cm) ASTM D-876______21.5 x 10¹² © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex®’s only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com CHEMICAL RESISTANCE Shrinks
H2P0.50CL25 价格&库存
很抱歉,暂时无法提供与“H2P0.50CL25”相匹配的价格&库存,您可以联系我们找货
