H2C0.38BK
H2C0.38BK
    TECHFLEX
H2C0.38BK 数据手册
HEATSHRINK TUBING Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put-Ups M  IL-I-DTL-23053/5 E  xcellent High Frequency EMI Shielding E  asily Installs Over Connectors And Splices F  lame Retardant UL224 Nominal Size Part # Unshrunk Diameter /mm Shrunk Diameter /mm Wall Thickness AFTER 3/16” 1/4” 3/8” 1/2” 3/4” 1” 1 1/2” H2C0.19BK H2C0.25BK H2C0.38BK H2C0.50BK H2C0.75BK H2C1.00BK H2C1.50BK 4.8 6.4 9.5 12.7 19.1 25.4 38.1 2.4 3.2 4.8 6.4 9.5 12.7 19.1 0.020” 0.025” 0.025” 0.025” 0.030” 0.035” 0.040” Bulk Box Shop Box Put Up/ Put Up/ 4’Pcs. 4’Pcs. 12 12 12 12 12 12 12 2 2 2 2 2 2 2 Shield 2:1 Heatshrink Tubing Shrinks To 1/2 its original diameter! Available Colors Lbs/ 10Pcs. Black Black Black Black Black Black Black 0.28 0.47 0.61 0.72 1.18 1.70 2.55 Colors Available: Black (BK) 2:1 Shielding heatshrink tubing is a unique combination of Polyolefin and conductive cloth, with a high frequency EMI shielding properties. This product, a flame retardant and fluid resistant tubing, is a perfect solution for protecting your wire & cable bundles. Cut Cleanly Scissor Grade H2C -60.00 ATTENUATION (Db) Material Polyolefin SHIELDING EFFECTIVENESS (ASTM D4935) 1 -70.00 -80.00 2 3 >1 2 3 4 5 6 7 8 100.00000 kHz 100.00000 kHz 500.00000 kHz 1.0000000 kHz 1.5000000 kHz 2.0000000 kHz 2.5000000 kHz 3.0000000 kHz -61.763 dB -74.909 dB -76.226 dB -82.324 dB -84.937 dB -88.880 dB -86.155 dB -77.532 dB 8 4 -90.00 5 Nominal Diameter 7 6 -100.0 START 100 kHz www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 IFBW 70 kHz Stop 3 GHz HEATSHRINK TUBING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet FLAMMABILITY Flammability Rating____________Flame Retardant UL224 Shrinks 194°F (90°C) Melt Point ASTM D-2117 Fluid Resistance __________________________ Excellent Measure the Shrinkflex® tubing to length and cut with a scissor. The thickness of your bundle, as well as the desired final appearance, will determine the length of the tubing you cut. Generally, a piece 1 1/2” - 2” long will accommodate almost any need. Single wires, or smaller bundles, require shorter pieces. Slip the Shrinkflex® tubing over the bundle and position it so that both the sleeved and unsleeved portions are sufficiently covered. Notice the small pieces of tubing installed on single wires as part of a color coding system. If your project requires multiple operations, always work up from the smallest to the largest bundle. Mil-I-23053 275°F (135°C) Minimum Continuous -67°F (-55°C) PHYSICAL PROPERTIES Recommended Cutting_____________________ Scissors Colors_________________________________________ 1 Flexibility_________________________________ Medium Break Strength______________________________ 1,500 After Shrinkage Dielectric Strength (volts/mil)____________________ 500 Wall Thickness____________________________ .020-.040 After Shrinkage Gently apply heat to Shrinkflex® tubing from a heat gun, hair dryer or torch with an appropriate attachment. Keep the heat source far enough away so that hot metal or direct flame does not come in contact with the tubing, wires or sleeving. Move the heat around the bundle to prevent damaging the sleeving and to ensure that all areas of the tubing have been shrunk. Once cooled, your installation is complete. © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex®’s only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. 12-30 www.techflex.com CHEMICAL RESISTANCE 392°F (200°C) Maximum Continuous
H2C0.38BK 价格&库存
很抱歉,暂时无法提供与“H2C0.38BK”相匹配的价格&库存,您可以联系我们找货
