Insulation
2.1
Heat Shrinkable Tubing
Heat Shrinkable Tubing up to 4:1 - 1 m lengths
TREDUX MA47 medium wall - with adhesive liner
Suitable for insulation and protection of low voltage cable joints and
terminations.
Features and Benefits
• Medium walled heat shrink tubing
• Securely packed in display boxes for use in smaller quantities
• Supplied in lengths of 1 m
• Thermoplastic adhesive liner for protection from moisture
and weathering
MA47 and MU47 medium wall tubing - lined and unlined.
Detailed Information about
Heatguns please refer to page 529.
One Step to the Web!
MATERIAL
Polyolefin, cross-linked (PO-X)
Shrink Ratio
up to 4:1
Operating Temperature
-55 °C to +110 °C
Softening Point Adhesive
+85 °C
Minimum Shrink
Temperature
+120 °C
Longitudinal change
after shrinkage
-10 % max.
Dielectric Strength
20 kV/mm
Flammability
not flame retarded
Insulation Class
A (VDE 0530)
L
Supplied
Ø D min.
Recov.
Ø d max.
Wall
(WT)
Length
(L)
TREDUX-MA47-12/3
12.0
3.0
2.00
TREDUX-MA47-19/6
19.0
6.0
2.50
TREDUX-MA47-30/8
30.0
8.0
TREDUX-MA47-40/12
40.0
TREDUX-MA47-50/16
50.0
TREDUX-MA47-63/19
TREDUX-MA47-75/22
TREDUX-MA47-95/30
TYPE
Pack
Cont.
Colour
Article-No.
1.0 m
6 pcs.
Black (BK)
323-50120
1.0 m
10 pcs.
Black (BK)
323-50190
2.50
1.0 m
6 pcs.
Black (BK)
323-50300
12.0
2.50
1.0 m
4 pcs.
Black (BK)
323-50400
16.0
2.70
1.0 m
2 pcs.
Black (BK)
323-50500
63.0
19.0
2.80
1.0 m
2 pcs.
Black (BK)
323-50630
75.0
22.0
3.00
1.0 m
2 pcs.
Black (BK)
323-50750
95.0
30.0
3.00
1.0 m
1 pcs.
Black (BK)
323-50950
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
226
Further information at www.HellermannTyton.com/insulation
Date of issue: October 2015
Heat Shrinkable Tubing 4:1 with adhesive
Insulation
2.1
Insulation and Protection of low voltage cable jonts and terminations
above and below ground.
• Medium walled tubing with robust insulation characteristics
• Shrink tubing for above and underground cable applications
• Protects cable joints and terminations in low voltage applications
• Coated inside with thermoplastic adhesive
• Protects against humidity and other environmental impacts
after shrinking
Cut lengths available on request.
Please contact us!
MATERIAL
Shrink Ratio
up to 4:1
-55 °C to +110 °C
Minimum Shrink
Temperature
+120 °C
Softening Point
Adhesive
+85 °C
Longitudinal change
after shrinkage
-10 % max.
Dielectric Strength
20 kV/mm
Flammability
not flame retarded
Insulation Class
A (VDE 0530)
MA47 - medium wall adhesive lined
L
Supplied
Ø D min.
Recov.
Ø d max.
Wall
(WT)
Length
(L)
Colour
Article-No.
MA47-12/3
12.0
3.0
2.00
1.0 m
Black (BK)
323-20120
MA47-19/6
19.0
6.0
2.50
1.0 m
Black (BK)
323-20190
MA47-30/8
30.0
8.0
2.50
1.0 m
Black (BK)
323-20300
MA47-40/12
40.0
12.0
2.50
1.0 m
Black (BK)
323-20400
MA47-50/16
50.0
16.0
2.70
1.0 m
Black (BK)
323-20500
MA47-63/19
63.0
19.0
2.80
1.0 m
Black (BK)
323-20630
MA47-75/22
75.0
22.0
3.00
1.0 m
Black (BK)
323-20750
MA47-95/30
95.0
30.0
3.00
1.0 m
Black (BK)
323-20950
MA47-115/34
115.0
34.0
3.00
1.0 m
Black (BK)
323-21150
MA47-140/42
140.0
42.0
3.00
1.0 m
Black (BK)
323-21400
TYPE
227
Insulation
2.1
MU47 - medium wall unlined
L
Supplied
Ø D min.
Recov.
Ø d max.
Wall
(WT)
Length
(L)
Colour
Article-No.
MU47-12/3
12.0
3.0
2.00
1.0 m
Black (BK)
323-10120
MU47-19/6
19.0
6.0
2.20
1.0 m
Black (BK)
323-10190
MU47-30/8
30.0
8.0
2.50
1.0 m
Black (BK)
323-10300
MU47-40/12
40.0
12.0
2.50
1.0 m
Black (BK)
323-10400
MU47-50/16
50.0
16.0
2.70
1.0 m
Black (BK)
323-10500
MU47-63/19
63.0
19.0
2.80
1.0 m
Black (BK)
323-10630
MU47-75/22
75.0
22.0
3.00
1.0 m
Black (BK)
323-10750
MU47-95/30
95.0
30.0
3.00
1.0 m
Black (BK)
323-10950
MU47 115/34
115.0
34.0
3.00
1.0 m
Black (BK)
323-11150
MU47-140/42
140.0
42.0
3.00
1.0 m
Black (BK)
323-11400
TYPE
228
很抱歉,暂时无法提供与“323-50500”相匹配的价格&库存,您可以联系我们找货
