HEATSHRINK
TUBING
Technical Data Sheet
ADVANCED ENGINEERING
Put-Ups
S
hrink Temperature
347°F (175°C)
H
igh Operating Temperature 392°F (200°C) For Extreme Working Conditions
F
lame Retardant
R
esistant To Highly Corrosive Acids, Fluids, Fuels &
Solvents
M
eets Military Specification
MIL-DTL-23053/13
Nominal
Size
Part
Unshrunk
Diameter
/mm
Shrunk
Diameter
/mm
Put-Ups
Bulk Spool
Shop Spool
1/8”
3/16”
1/4”
3/8”
1/2”
5/8”
3/4”
7/8”
1”
1 1/4”
1 1/2”
2”
H2V0.13BK
H2V0.19BK
H2V0.25BK
H2V0.38BK
H2V0.50BK
H2V0.63BK
H2V0.75BK
H2V0.88BK
H2V1.00BK
H2V1.25BK
H2V1.50BK
H2V2.00BK
3.2
4.8
6.4
9.5
12.7
16.0
19.1
22.4
25.4
31.7
38.1
50.8
1.6
2.4
3.2
4.7
6.4
8.0
9.5
11.0
12.7
15.7
19.1
25.4
200’
200’
200’
100’
100’
100’
100’
50’
50’
50’
50’
50’
25’
25’
25’
25’
25’
25’
25’
25’
25’
25’
25’
25’
Available
Colors
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
Lbs/
100’
1.26
1.45
1.68
2.27
2.29
2.50
4.14
4.83
5.73
8.20
8.80
13.40
2:1 Viton - Flexible Heatshrink Tubing
Shrinks To 1/2 its original diameter!
2:1 Viton is a rubber-like, highly fluid resistant, flame
retardant flouro-elastomer heatshrink tubing with
high solvent resistance.
Cut Cleanly
Scissor
The product is recommended for applications where
resistance to aggressive solvents and high temperatures is required. Bundling, harnessing and environmental protection within engine compartments is one
such application.
Material
Fluoro-Elastomer
High Temperature, Solvent Resistant, and Flame
Retardant Flexible Fluoro-Elastomer
Grade
H2V
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Viton is a registered trademark of DuPont Performance Elastomers.
Colors Available:
Black (BK)
HEATSHRINK
TUBING
FLAMMABILITY
Moisture Absorption % ASTM D-570________________0.5
Flammability Rating MIL-DTL-23053________ 15 Sec. Max.
Shrinks
347°F(175°C)
Maximum Continuous
Corrosion ASTM DTL-23053_______________ No Corrosion
Fluid Resistance ( 73°F/ 23°C 24 hrs.)_____________ 1,200
Measure the Shrinkflex® tubing to length
and cut with a scissor. The thickness of
your bundle, as well as the desired final
appearance, will determine the length of the tubing you
cut. Generally, a piece 1 1/2” - 2” long will accommodate
almost any need. Single wires, or smaller bundles, require
shorter pieces.
Slip the Shrinkflex® tubing over the
bundle and position it so that both the
sleeved and unsleeved portions are sufficiently covered. Notice the small pieces of tubing installed on single wires as part of a color coding system. If
your project requires multiple operations, always work up
from the smallest to the largest bundle.
Gently apply heat to Shrinkflex® tubing
from a heat gun, hair dryer or torch with
an appropriate attachment. Keep the
heat source far enough away so that hot metal or direct
flame does not come in contact with the tubing, wires or
sleeving. Move the heat around the bundle to prevent
damaging the sleeving and to ensure that all areas of the
tubing have been shrunk. Once cooled, your installation
is complete.
Minimum Continuous
-67°F (-55°C)
PHYSICAL
PROPERTIES
Recommended Cutting_____________________ Scissors
Colors_________________________________________ 1
Tensile Strength PSI ASTM D-638________________ 1,200
Elongation % ASTM D-638_______________________ 250
Heat Shock (572ºF/ 300ºC, 4 Hrs.)__________ No Cracking
MIL-DTL-23053
Heat Resistance (482ºF/ 250°C, 168 Hrs.)___________ 200
ASTM D-638
Longitudinal Change %_________________________ -20
MIL-DTL-23053
Cold Impact (-40ºF/ -40°C)________________ No Cracking
ASTM D-746
Dielectric Strength (volts/mil) _____________________ 200
ASTM D-876
Volume Resistivity (ohm-cm) ________________1.0 x 10¹¹
ASTM D-876
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex®’s only obligations are those in standard terms of
sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
CHEMICAL
RESISTANCE
Mil-I-23053
392°F (200°C)
很抱歉,暂时无法提供与“H2V0.13BK25”相匹配的价格&库存,您可以联系我们找货
