HEATSHRINK
TUBING
Technical Data Sheet
ADVANCED ENGINEERING
Put-Ups
S
hrink Temperature
212°F (100°C)
I deal Finish For Cosmetic
Applications
H
eat Resistance Up To 221°F
(105°C)
E
xcellent Oil, Moisture, And
Fungus Resistance
E
asily Installs Over
Connectors And Splices
Nominal
Size
Part
Unshrunk
Diameter
/mm
Shrunk
Diameter
/mm
Put-Ups
Bulk Spool
Shop Spool
1/16”
1/4”
5/16”
3/8”
1/2”
5/8”
3/4”
1”
1 1/2”
2”
2 1/2”
3”
H2P0.06
H2P0.25
H2P0.31
H2P0.38
H2P0.50
H2P0.63
H2P0.75
H2P1.00
H2P1.50
H2P2.00
H2P2.50CL
H2P3.00CL
1.6
6.4
8.0
9.5
12.7
15.9
19.1
25.4
38.1
50.8
63.5
76.2
0.8
3.2
4.0
4.8
6.4
7.9
9.5
12.7
19.1
25.4
31.8
38.1
1,000'
250’
250’
250’
250’
250’
250’
250’
100’
100’
100’
50’
100'
25’
25’
25’
25’
25’
25’
25’
25'
25’
25’
25’
Available
Colors
Lbs/
100’
2
2
2
2
2
2
2
2
2
2
Clear CL
Clear CL
0.20
0.60
0.70
0.80
1.10
1.16
1.90
3.00
5.30
8.02
9.45
18.00
PVC 2:1 Heatshrink Tubing
Shrinks To 1/2 its original diameter!
PVC tubing is a Polyvinyl Chloride heatshrink
tubing that shrinks to 1/2 its original diameter.
During the shrinking operation, the tubing will
encapsulate any device inside of it at the time
and will assume the contour of that device.
Cut Cleanly
Scissor
Material
Polyvinyl Chloride
Grade
H2P
Ultra clear PVC heatshrink tubing is ideal for
application where complete transparency is
required. Perfect for protecting exposed
wires and cables on motorcycles and custom
automobiles.
Resists gasoline, oil, and common chemicals;
provides protection from abrasion and severe
environments.
Perfect tubing for application where
complete transparency is required.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
VW-1
Colors Available:
Clear (CL) & Black (BK)
HEATSHRINK
TUBING
FLAMMABILITY
Moisture Absorption % ASTM D-570________________0.5
Flammability Rating___________ Self-Extinguishing VW-1
Corrosion MIL-I-23053__________________ No Corrosion
212°F(100°C)
Maximum Continuous
Mil-DTL-23053
221°F (105°C)
Minimum Continuous
Mil-DTL-23053
-4°F (-20°C)
Measure the Shrinkflex® tubing to length
and cut with a scissor. The thickness of
your bundle, as well as the desired final
appearance, will determine the length of the tubing you
cut. Generally, a piece 1 1/2” - 2” long will accommodate
almost any need. Single wires, or smaller bundles, require
shorter pieces.
Slip the Shrinkflex® tubing over the
bundle and position it so that both the
sleeved and unsleeved portions are sufficiently covered. Notice the small pieces of tubing installed on single wires as part of a color coding system. If
your project requires multiple operations, always work up
from the smallest to the largest bundle.
Gently apply heat to Shrinkflex® tubing
from a heat gun, hair dryer or torch with
an appropriate attachment. Keep the
heat source far enough away so that hot metal or direct
flame does not come in contact with the tubing, wires or
sleeving. Move the heat around the bundle to prevent
damaging the sleeving and to ensure that all areas of the
tubing have been shrunk. Once cooled, your installation
is complete.
PHYSICAL
PROPERTIES
Recommended Cutting_____________________ Scissors
Stock Colors____________________________________ 2
Tensile Strength PSI ASTM D-638________________ 3,000
Elongation % ASTM D-638_______________________ 300
Specific Gravity ASTM D-792____________________ 1.32
Deformation % (250°F/121°C, 1 Hr.)________________ 50
MIL-I-23053
Heat Shock (250°F/121°C, 1 Hr.)____________ No Cracking
MIL-I-23053
Cold Bend (14°F/-10°C, 1 Hr.)______________ No Cracking
MIL-I-23053
Flexibility______________________________ No Cracking
MIL-I-23053
Secant Modulus PSI ASTM D-882_______________ 19,500
Longitudinal Shrinkage (%)_______________________ 15
Dielectric Strength (volts/mil) ASTM D-876________ 1,083
Volume Resistivity (ohm-cm) ASTM D-876______21.5 x 10¹²
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex®’s only obligations are those in standard terms of
sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
CHEMICAL
RESISTANCE
Shrinks
很抱歉,暂时无法提供与“H2P2.00CL25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1306.798091+167.62313
