M23053-12-234-C
M23053-12-234-C
    TECHFLEX
    1PTFEHEATSHRNK2:1NTRL4'
M23053-12-234-C 数据手册
HEATSHRINK TUBING 2:1 PTFE Heatshrink Tubing 2:1 Polytetrafluoroethylene heatshrink tubing has the lowest coefficient of friction of any polymer and possesses a broad temperature range, allowing it to excel equally in extreme cold and hot environments. When ordering our 2:1 PTFE heatshrink, order as size after shrinking. Nominal Size Part # Unshrunk Diameter Shrunk Diameter Wall Thickness Put Up/4’Pcs. 24 AWG 22 AWG 20 AWG 19 AWG 18 AWG 17 AWG 15 AWG 14 AWG 13 AWG 12 AWG 11 AWG 10 AWG 9 AWG 1/8” 8 AWG 7 AWG 6 AWG 5 AWG 4 AWG 3 AWG 1/4” 2 AWG 1 AWG 5/16” 0 AWG 3/8” 7/16” 1/2” 5/8” 3/4” 7/8” 1” M23053-12-201-C M23053-12-202-C M23053-12-203-C M23053-12-204-C M23053-12-205-C M23053-12-206-C M23053-12-207-C M23053-12-208-C M23053-12-210-C M23053-12-211-C M23053-12-212-C M23053-12-213-C M23053-12-214-C M23053-12-215-C M23053-12-216-C M23053-12-217-C M23053-12-218-C M23053-12-219-C M23053-12-220-C M23053-12-221-C M23053-12-222-C M23053-12-223-C M23053-12-224-C M23053-12-225-C M23053-12-226-C M23053-12-228-C M23053-12-229-C M23053-12-230-C M23053-12-231-C M23053-12-232-C M23053-12-233-C M23053-12-234-C 1.27mm 1.40mm 1.52mm 1.65mm 1.93mm 2.16mm 2.79mm 3.05mm 3.56mm 3.81mm 4.32mm 4.85mm 5.21mm 5.46mm 6.10mm 6.86mm 7.67mm 8.13mm 9.40mm 9.91mm 10.41mm 10.92mm 11.43mm 11.94mm 11.94mm 14.22mm 16.64mm 19.05mm 23.62mm 28.58mm 33.27mm 38.10mm 0.69mm 0.81mm 0.99mm 1.09mm 1.24mm 1.37mm 1.70mm 1.83mm 2.03mm 2.26mm 2.57mm 2.84mm 3.15mm 3.30mm 3.58mm 4.01mm 4.52mm 5.03mm 5.69mm 6.32mm 6.60mm 7.06mm 7.90mm 8.36mm 8.81mm 10.13mm 11.73mm 13.31mm 16.64mm 19.96mm 23.14mm 26.31mm 0.30mm 0.30mm 0.41mm 0.41mm 0.41mm 0.41mm 0.41mm 0.41mm 0.41mm 0.41mm 0.41mm 0.41mm 0.51mm 0.51mm 0.51mm 0.51mm 0.51mm 0.51mm 0.51mm 0.51mm 0.51mm 0.51mm 0.51mm 0.51mm 0.51mm 0.64mm 0.64mm 0.64mm 0.76mm 0.89mm 0.89mm 0.89mm 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Available Colors Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear Clear (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) (CL) • Shrink Temperature 650°F (343°C) • Mil-I-DTL-23053/12 • Excellent Dielectric Strength • Resistant to All Common Solvents, Acids, and Bases • High Operating Temp. up to to 500°F (260°C) Splice sleeving Adhesive lining Hot Fusion Tape Techflex hot-melt adhesive tape works great in conjunction with our sleeving and heatshrink products. HFA has good adhesion to polyolefin, PET, PVC, copper, and nylon. Hot Fusion Tape is very flexible and can be field cut to fit your application. Use when extra adhesive may be needed, in areas between wire bundles for weatherproofing, or under heatshrink products not available with pre-coated dual wall adhesive. Tape activates easily when shrinking your tubing. Nominal Size Part # Width Thickness 2” HFA2.00CL 1.97” 0.012” Standard Spool Put-Ups Bulk Spool Shop Spool Available Colors Lbs/ 100’ 100’ 25’ Clear (CL) 1.16 Added waterproofing 1-973-300-9242 www.techflex.com 87
M23053-12-234-C 价格&库存
很抱歉,暂时无法提供与“M23053-12-234-C”相匹配的价格&库存,您可以联系我们找货
