SH275-2
SH275-2
    DABURNELECTRONICS
    HEATSHRINK BLK 2IN X 100FT
SH275-2 数据手册
SH275 Heat Shrinkable Irradiated Polyolefin Tubing Page 1 of 3 Heat Shrinkable Irradiated Polyolefin Tubing All Purpose · 2:1 · MIL-I-23053/5 UL ° VW-1 ° CSA Description: When exposed to heat 194°F/90°C the tubing shrinks 50% in diameter, with 5% longitudinal contraction. Controlled shrinkage to exact requirement takes place. This series is designed for maximum mechanical strength at stress or points of connection. It is strong, abrasion resistant and is supplied in expanded sizes. It insulates, jackets, splices, encapsulates, weather-proofs components, connectors, cables and irregular shaped objects. SH275 meets or exceeds UL STD 224, Mil-I-23053B/5 Class 1 (colors), 2 (clear) and Class 3 (highly flame retardant-except for clear). SH275 is UL and CSA approved. AMS 3636 (colors), 3637A (clear). Flame retardant (except clear). Daburn Cat. No. Size I.D. As Supplied IN. MM. Recovered (After Heating) I.D. Max. IN. MM. Nom. Wall* IN. MM. Standard Package Click to Order M23053/5† Prototype Quantities SH275-3/64 3/64 0.046 1.17 0.023 0.58 0.016 0.41 100’, 1000’ 101 SH275-1/16 1/16 0.063 1.60 0.031 0.79 0.017 0.43 100' , 250' , 1000' 102 Order SH275-3/32 3/32 0.093 2.36 0.046 1.17 0.020 0.51 100' , 250' , 1000' 103 Order SH275-1/8 1/8 0.125 3.18 0.062 1.57 0.020 0.51 100' , 250' , 1000' 104 Order SH275-3/16 3/16 0.187 4.75 0.093 2.36 0.020 0.51 100' , 250' , 1000' 105 Order SH275-1/4 1/4 0.250 6.35 0.125 3.18 0.025 0.64 100' , 250' , 1000' 106 Order SH275-3/8 3/8 0.375 9.53 0.187 4.75 0.025 0.64 100' , 200' 107 Order SH275-1/2 1/2 0.500 12.70 0.250 6.35 0.025 0.64 100' , 200' 108 Order SH275-3/4 3/4 0.750 19.05 0.375 9.53 0.030 0.76 100' , 200' 109 Order SH275-1" 1" 1.000 25.40 0.500 12.70 0.035 0.89 100' 110 Order SH275-1 1/2" 1 1/2" 1.500 38.10 0.750 19.05 0.040 1.02 12' **, 24' **, 100' ** 111 SH275-2" 2" 2.000 50.80 1.000 25.40 0.045 1.14 12' **, 24' **, 100' ** 112 SH275-3" 3" 3.000 76.20 1.500 38.10 0.050 1.27 12' **, 24' **, 100' ** 113 Order SH275-4" 4" 4.000 101.60 2.000 50.80 0.055 1.40 12' **, 24' **, 50' ** 114 Order * Wall thickness will be less if recovery is restricted. ** Stocked in 4FT lengths. All items are available in 4FT lengths or long length spools. http://www.daburn.com/sh275.html 11/15/2002 SH275 Heat Shrinkable Irradiated Polyolefin Tubing Page 2 of 3 † Add suffix "C" for clear, i.e. SH275-1/4 Clear is M23053/5-106C. Stock Colors: Black, White, Red, Clear. Additional colors available. Note: Extra flexible, & Industrial grade shrinkable polyolefin is available to order. SH275 Pack Assortments A. Pack Assortments- Assorted Sizes Daburn Cat. No. Lengths Per Pack Tubing Size SH275-PA1 30 3/64" thru 3/16" SH275-PA2 16 1/4" thru 3/4" SH275-PA3 10 1" SH275-PA4 10 1" thru 4" Colors: Black. Additional colors to order. Each pack contains an assortment of 6" lengths in mixed sizes. B. Pack Assortments- 6" Lengths Of Same Size Daburn No. Of 6" Size Cat. No. Lengths Per Pack SH275PA-3/64 3/64 40 SH275PA-1/16 1/16 36 SH275PA-3/32 3/32 32 SH275PA-1/8 1/8 28 SH275PA-3/16 3/16 24 SH275PA-1/4 1/4 20 SH275PA-3/8 3/8 16 SH275PA-1/2 1/2 14 SH275PA-3/4 3/4 12 SH275PA-1" 1" 8 SH275PA-1 1/2" 1 1/2" 5 SH275PA-2" 2" 3 SH275PA-3" 3" 2 SH275PA-4" 4" 1 Colors: Black, Clear. Additional colors to order. Each pack contains 6" lengths of the same sizes. Although processed by hi-energy radiation the Daflex SH275 shrinkable tubing does not at any time become radioactive or http://www.daburn.com/sh275.html 11/15/2002 SH275 Heat Shrinkable Irradiated Polyolefin Tubing Page 3 of 3 possess any residual radioactivity. Properties Of SH275 -55°C To +135°C Operating Temperature Shrinkage Temperature Nom: 90°C/194°F 2:1 Shrink Ratio: Longitudinal Change, Max.: ±5% To Top of Page To Additional Heat Shrinkable Tubing To Heat Shrinkable Tubing Cross Reference Property Chart Back to DABURN’S Home Page. Daburn electronics & cable corp. 224 Pegasus Ave. Northvale, NJ 07647 Tel: 201-768-5400 Fax: 201-768-9642 E-Mail: daburn@daburn.com URL: http://www.daburn.com/ http://www.daburn.com/sh275.html 11/15/2002
SH275-2 价格&库存
很抱歉,暂时无法提供与“SH275-2”相匹配的价格&库存,您可以联系我们找货
