H2V1.25BK25
H2V1.25BK25
    TECHFLEX
    1-1/4" VITON HEAT SHRINK 2:1 BLK
H2V1.25BK25 数据手册
HEATSHRINK TUBING Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put-Ups S  hrink Temperature 347°F (175°C) H  igh Operating Temperature 392°F (200°C) For Extreme Working Conditions F  lame Retardant R  esistant To Highly Corrosive Acids, Fluids, Fuels & Solvents M  eets Military Specification MIL-DTL-23053/13 Nominal Size Part # Unshrunk Diameter /mm Shrunk Diameter /mm Put-Ups Bulk Spool Shop Spool 1/8” 3/16” 1/4” 3/8” 1/2” 5/8” 3/4” 7/8” 1” 1 1/4” 1 1/2” 2” H2V0.13BK H2V0.19BK H2V0.25BK H2V0.38BK H2V0.50BK H2V0.63BK H2V0.75BK H2V0.88BK H2V1.00BK H2V1.25BK H2V1.50BK H2V2.00BK 3.2 4.8 6.4 9.5 12.7 16.0 19.1 22.4 25.4 31.7 38.1 50.8 1.6 2.4 3.2 4.7 6.4 8.0 9.5 11.0 12.7 15.7 19.1 25.4 200’ 200’ 200’ 100’ 100’ 100’ 100’ 50’ 50’ 50’ 50’ 50’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ Available Colors Black Black Black Black Black Black Black Black Black Black Black Black (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) Lbs/ 100’ 1.26 1.45 1.68 2.27 2.29 2.50 4.14 4.83 5.73 8.20 8.80 13.40 2:1 Viton - Flexible Heatshrink Tubing Shrinks To 1/2 its original diameter! 2:1 Viton is a rubber-like, highly fluid resistant, flame retardant flouro-elastomer heatshrink tubing with high solvent resistance. Cut Cleanly Scissor The product is recommended for applications where resistance to aggressive solvents and high temperatures is required. Bundling, harnessing and environmental protection within engine compartments is one such application. Material Fluoro-Elastomer High Temperature, Solvent Resistant, and Flame Retardant Flexible Fluoro-Elastomer Grade H2V www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Viton is a registered trademark of DuPont Performance Elastomers. Colors Available: Black (BK) HEATSHRINK TUBING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet FLAMMABILITY Moisture Absorption % ASTM D-570________________0.5 Flammability Rating MIL-DTL-23053________ 15 Sec. Max. Shrinks 347°F(175°C) Maximum Continuous Corrosion ASTM DTL-23053_______________ No Corrosion Fluid Resistance ( 73°F/ 23°C 24 hrs.)_____________ 1,200 Measure the Shrinkflex® tubing to length and cut with a scissor. The thickness of your bundle, as well as the desired final appearance, will determine the length of the tubing you cut. Generally, a piece 1 1/2” - 2” long will accommodate almost any need. Single wires, or smaller bundles, require shorter pieces. Slip the Shrinkflex® tubing over the bundle and position it so that both the sleeved and unsleeved portions are sufficiently covered. Notice the small pieces of tubing installed on single wires as part of a color coding system. If your project requires multiple operations, always work up from the smallest to the largest bundle. Gently apply heat to Shrinkflex® tubing from a heat gun, hair dryer or torch with an appropriate attachment. Keep the heat source far enough away so that hot metal or direct flame does not come in contact with the tubing, wires or sleeving. Move the heat around the bundle to prevent damaging the sleeving and to ensure that all areas of the tubing have been shrunk. Once cooled, your installation is complete. Minimum Continuous -67°F (-55°C) PHYSICAL PROPERTIES Recommended Cutting_____________________ Scissors Colors_________________________________________ 1 Tensile Strength PSI ASTM D-638________________ 1,200 Elongation % ASTM D-638_______________________ 250 Heat Shock (572ºF/ 300ºC, 4 Hrs.)__________ No Cracking MIL-DTL-23053 Heat Resistance (482ºF/ 250°C, 168 Hrs.)___________ 200 ASTM D-638 Longitudinal Change %_________________________ -20 MIL-DTL-23053 Cold Impact (-40ºF/ -40°C)________________ No Cracking ASTM D-746 Dielectric Strength (volts/mil) _____________________ 200 ASTM D-876 Volume Resistivity (ohm-cm) ________________1.0 x 10¹¹ ASTM D-876 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex®’s only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com CHEMICAL RESISTANCE Mil-I-23053 392°F (200°C)
H2V1.25BK25 价格&库存
很抱歉,暂时无法提供与“H2V1.25BK25”相匹配的价格&库存,您可以联系我们找货
