SH275 Heat Shrinkable Irradiated Polyolefin Tubing
Page 1 of 3
All Purpose · 2:1 · MIL-I-23053/5
UL ° VW-1 ° CSA
Description: When exposed to heat 194°F/90°C the tubing shrinks 50% in diameter, with 5% longitudinal contraction.
Controlled shrinkage to exact requirement takes place. This series is designed for maximum mechanical strength at stress or
points of connection. It is strong, abrasion resistant and is supplied in expanded sizes. It insulates, jackets, splices,
encapsulates, weather-proofs components, connectors, cables and irregular shaped objects.
SH275 meets or exceeds UL STD 224, Mil-I-23053B/5 Class 1 (colors), 2 (clear) and Class 3 (highly flame retardant-except
for clear).
SH275 is UL and CSA approved. AMS 3636 (colors), 3637A (clear). Flame retardant (except clear).
Daburn
Cat. No.
Size
I.D. As Supplied
IN.
MM.
Recovered (After Heating)
I.D. Max.
IN.
MM.
Nom. Wall*
IN.
MM.
Standard
Package
Click
to Order
M23053/5†
Prototype
Quantities
SH275-3/64
3/64
0.046
1.17
0.023 0.58
0.016 0.41
100’, 1000’
101
SH275-1/16
1/16
0.063
1.60
0.031 0.79
0.017 0.43
100'
, 250'
, 1000'
102
Order
SH275-3/32
3/32
0.093
2.36
0.046 1.17
0.020 0.51
100'
, 250'
, 1000'
103
Order
SH275-1/8
1/8
0.125
3.18
0.062 1.57
0.020 0.51
100'
, 250'
, 1000'
104
Order
SH275-3/16
3/16
0.187
4.75
0.093 2.36
0.020 0.51
100'
, 250'
, 1000'
105
Order
SH275-1/4
1/4
0.250
6.35
0.125 3.18
0.025 0.64
100'
, 250'
, 1000'
106
Order
SH275-3/8
3/8
0.375
9.53
0.187 4.75
0.025 0.64
100'
, 200'
107
Order
SH275-1/2
1/2
0.500
12.70
0.250 6.35
0.025 0.64
100'
, 200'
108
Order
SH275-3/4
3/4
0.750
19.05
0.375 9.53
0.030 0.76
100'
, 200'
109
Order
SH275-1"
1"
1.000
25.40
0.500 12.70 0.035 0.89
100'
110
Order
SH275-1 1/2" 1 1/2" 1.500
38.10
0.750 19.05 0.040 1.02
12'
**, 24'
**, 100'
** 111
SH275-2"
2"
2.000
50.80
1.000 25.40 0.045 1.14
12'
**, 24'
**, 100'
** 112
SH275-3"
3"
3.000
76.20
1.500 38.10 0.050 1.27
12'
**, 24'
**, 100'
** 113
Order
SH275-4"
4"
4.000
101.60
2.000 50.80 0.055 1.40
12'
**, 24'
**, 50'
** 114
Order
* Wall thickness will be less if recovery is restricted.
** Stocked in 4FT lengths.
All items are available in 4FT lengths or long length spools.
http://www.daburn.com/sh275.html
11/15/2002
Page 2 of 3
† Add suffix "C" for clear, i.e. SH275-1/4
Clear is M23053/5-106C.
Stock Colors: Black, White, Red, Clear. Additional colors available.
Note: Extra flexible, & Industrial grade shrinkable polyolefin is available to order.
SH275 Pack Assortments
A.
Pack Assortments- Assorted Sizes
Daburn
Cat. No.
Lengths
Per Pack
Tubing Size
SH275-PA1 30
3/64" thru 3/16"
SH275-PA2 16
1/4" thru 3/4"
SH275-PA3 10
1"
SH275-PA4 10
1" thru 4"
Colors: Black. Additional colors to order.
Each pack contains an assortment of 6" lengths in mixed sizes.
B.
Pack Assortments- 6" Lengths Of Same Size
Daburn
No. Of 6"
Size
Cat. No.
Lengths Per Pack
SH275PA-3/64
3/64 40
SH275PA-1/16
1/16 36
SH275PA-3/32
3/32 32
SH275PA-1/8
1/8
28
SH275PA-3/16
3/16 24
SH275PA-1/4
1/4
SH275PA-3/8
3/8
16
SH275PA-1/2
1/2
14
SH275PA-3/4
3/4
12
SH275PA-1"
1"
8
SH275PA-1 1/2" 1 1/2" 5
SH275PA-2"
2"
3
SH275PA-3"
3"
2
SH275PA-4"
4"
1
Colors: Black, Clear. Additional colors to order.
Each pack contains 6" lengths of the same sizes.
Although processed by hi-energy radiation the Daflex SH275 shrinkable tubing does not at any time become radioactive or
11/15/2002
Page 3 of 3
possess any residual radioactivity.
Properties Of SH275
-55°C To +135°C
Operating Temperature
Shrinkage Temperature Nom: 90°C/194°F
2:1
Shrink Ratio:
Longitudinal Change, Max.: ±5%
To Top of Page
To Additional Heat Shrinkable Tubing
To Heat Shrinkable Tubing Cross Reference Property Chart
Back to DABURN’S Home Page.
Daburn electronics & cable corp.
224 Pegasus Ave.
Northvale, NJ 07647
Tel: 201-768-5400
Fax: 201-768-9642
E-Mail: daburn@daburn.com
URL: http://www.daburn.com/
11/15/2002
很抱歉,暂时无法提供与“SH275-3/4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1122.671071+144.05139
