Specification Sheet
Part Number: CTAM210C2
Cable Tie Anchor Mount, .20" Hole Dia, .20" Max Tie Width, PA66, White, 100/pkg
Article Number
151-31203
Type
CTAM2
Color
White (WH)
Features & Benefits
• Suitable for applications with minimal space. • CTAM has 4-way entry design
for use in line or at 90° angle to cable run. • CTAM mounts are available in
different sizes and materials.
Quantity Per
bag
Product Description
Anchor Mounts for cable ties are suitable for applications with minimal space.
Anchors are mounted onto the equipment prior to cable installation and take
up no more space than the cable itself. Choose between a four-way entry
design that can be used either 'in line' or at 90 degrees to the cable run.
Short Description
100/pkg
Global Part Name
CTAM2-PA66-WH
Length L (Imperial)
0.8
Length L (Metric)
20.4
Fixation Method
Screw Mounting and Rivet
Width W (Imperial)
0.4
Width W (Metric)
10.2
Cable Ties
T18 - T50
Height H (Imperial)
.20
Height H (Metric)
5.10
Cable Tie Width Max (Imperial)
0.2
Cable Tie Width Max (Metric)
5.0
Mounting Hole Diameter D (Imperial)
0.2
Mounting Hole Diameter D (Metric)
5.2 mm
Mounting Hole Diameter D Max (Metric)
5.2
Material
Polyamide 6.6 (PA66)
Material Shortcut
PA66
Flammability
UL 94 V2
Operating Temperature (Metric)
-40°F to +185°F (-40°C to +85°C)
Reach Complaint(Article 33)
Yes
ROHS Complaint
Yes
Certification/Specification WEB
UL | ANSI/UL 746B UL | ANSI/UL 1565 UL | ANSI/UL 62275
UL Recognized (US)
Yes
UL Recognized (US and Canada)
Yes
Package Quantity(Imperial)
100
Package Quantity (Metric)
100
Customs Number
3926909988
Content Unit(BMEcat)
pcs.
© 2019 HellermannTyton. All Rights Reserved.
Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
很抱歉,暂时无法提供与“CTAM210C2”相匹配的价格&库存,您可以联系我们找货
