CTM010C2
Article Number: 151-30303
Cable Tie Mount, 0.15" Hole Dia., 0.2" Max Tie Width, PA66, White, 100/pkg
Download spec sheet
Base Data
Local Order Number CTM010C2
Type CTM0
Color White (WH)
Features and Benefits • Designed for use with 18 through 50 pound cable ties to provide stability when securing bundles.
• Secures with a single screw providing quick installation.
Product Description HellermannTyton cable tie mounts are designed for use with 18 through 120 pound cable ties to provide stability
when securing bundles. The mounts are installed quick and easy by securing a single screw.
Short Description Cable Tie Mount, 0.15" Hole Dia., 0.2" Max Tie Width, PA66, White, 100/pkg
Product Dimensions
Length L (Imperial) 0.58 "
Length L (Metric) 14.7 mm
Fixation Method Screw Mounting and Rivet
Width W (Imperial) 0.37 "
Width W (Metric) 9.4 mm
Cable Tie Width Max. (Imperial) 0.2 "
Cable Tie Width Max. (Metric) 5.0 mm
Height H (Imperial) 0.27 "
Height H (Metric) 6.9 mm
Mounting Hole Diameter D (Imperial) 0.15 "
Mounting Hole Diameter D (Metric) 3.8 mm
Mounting Hole Diameter D Max. 3.8 mm
(Metric)
Mounting Hole Diameter D Min. (Metric)3.8 mm
Logistics and Packaging
Quantity Per bag
Package Quantity (Metric) 100 Pieces
Carton Quantity 15000
Material and Specifications
Material Polyamide 6.6 (PA66)
Material Shortcut PA66
Flammability UL94 V2
Operating Temperature -40°F to +185°F (-40°C to +85°C)
ROHS Compliant Yes
Certification/Specification UL
UL Listed (US and Canada) No
UL Recognized (US and Canada) Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“CTM010C2”相匹配的价格&库存,您可以联系我们找货
