CTM30C2
CTM30C2
    HELLERMAN(海尔曼太通)
    CBL TIE MNT .2"DIA .31"W BLACK
CTM30C2 数据手册
CTM30C2 Article Number: 151-30600 Cable Tie Mount, 0.2" Hole Dia., 0.31" Max Tie Width, PA66, Black, 100/pkg Download spec sheet Base Data Local Order Number CTM30C2 Type CTM3 Color Black (BK) Features and Benefits • Designed for use with 18 through 120 pound cable ties to provide stability when securing bundles. • Secures with a single screw providing quick installation. Product Description HellermannTyton cable tie mounts are designed for use with 18 through 120 pound cable ties to provide stability when securing bundles. The mounts are installed quick and easy by securing a single screw. Short Description Cable Tie Mount, 0.2" Hole Dia., 0.31" Max Tie Width, PA66, Black, 100/pkg Product Dimensions Length L (Imperial) 0.86 " Length L (Metric) 21.8 mm Fixation Method Screw Mounting and Rivet Width W (Imperial) 0.61 " Width W (Metric) 15.5 mm Cable Tie Width Max. (Imperial) 0.31 " Cable Tie Width Max. (Metric) 7.9 mm Height H (Imperial) 0.37 " Height H (Metric) 9.4 mm Mounting Hole Diameter D (Imperial) 0.2 " Mounting Hole Diameter D (Metric) 5.1 mm Mounting Hole Diameter D Max. 5.1 mm (Metric) Mounting Hole Diameter D Min. (Metric)5.1 mm Logistics and Packaging Quantity Per bag Package Quantity (Metric) 100 Pieces Carton Quantity 5000 Weight (Metric) 1 kg Material and Specifications Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL94 V2 Operating Temperature -40°F to +185°F (-40°C to +85°C) ROHS Compliant Yes Certification/Specification UL UL Listed (US and Canada) No UL Recognized (US and Canada) Yes © HellermannTyton 2015
CTM30C2 价格&库存
很抱歉,暂时无法提供与“CTM30C2”相匹配的价格&库存,您可以联系我们找货
CTM30C2
  • 100+8.05917100+1.04395
  • 200+7.67376200+0.99402
  • 300+7.45693300+0.96594
  • 500+7.19292500+0.93174
  • 700+7.02397700+0.90985
  • 1000+6.849421000+0.88724
库存:1100
