CTM310C2
CTM310C2
    HELLERMAN(海尔曼太通)
CTM310C2 数据手册
Specification Sheet Part Number: CTM310C2 Cable Tie Anchor Mount, .86" x .61", .2" Hole Dia, .31" Max Tie Width, PA66, White, 100/pkg Article Number 151-30605 Type CTM3 Color White (WH) Features & Benefits • Designed for use with 18 through 120 pound cable ties to provide stability when securing bundles. • Secures with a single screw providing quick installation. Quantity Per bag Product Description HellermannTyton cable tie mounts are designed for use with 18 through 120 pound cable ties to provide stability when securing bundles. The mounts are installed quick and easy by securing a single screw. Short Description Cable Tie Anchor Mount, .86" x .61", .2" Hole Dia, .31" Max Tie Width, PA66, White, 100/pkg Global Part Name CTM3-PA66-WH Length L (Imperial) 0.86 Length L (Metric) 21.8 Fixation Method Screw Mounting and Rivet Width W (Imperial) 0.61 Width W (Metric) 15.5 Cable Ties T18 - T120 Height H (Imperial) .37 Height H (Metric) 9.40 Cable Tie Width Max (Imperial) 0.31 Cable Tie Width Max (Metric) 7.9 Mounting Hole Diameter D (Imperial) 0.2 Mounting Hole Diameter D (Metric) 5.1 mm Mounting Hole Diameter D Max (Metric) 5.1 Material Polyamide 6.6 (PA66) Material Shortcut PA66 Flammability UL 94 V2 Operating Temperature (Metric) -40°F to +185°F (-40°C to +85°C) Reach Complaint(Article 33) Yes ROHS Complaint Yes Certification/Specification WEB UL | ANSI/UL 62275 UL | ANSI/UL 1565 UL | ANSI/UL 746B UL Recognized (US) Yes UL Recognized (US and Canada) Yes Package Quantity(Imperial) 100 Package Quantity (Metric) 100 Customs Number 3926909988 Content Unit(BMEcat) pcs. © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
CTM310C2 价格&库存
很抱歉,暂时无法提供与“CTM310C2”相匹配的价格&库存,您可以联系我们找货
