151-00646
    HELLERMAN(海尔曼太通)
    4WAY W/3M 5952 ADH 1.12" BLACK
151-00646 数据手册
Specification Sheet Part Number: 151-00646 Adhesive Cable Tie Mount, 1.12" x 1.12", .18" Max Tie Width, .18" Hole Dia, PA66UV, Black, 500/pkg Article Number 151-00646 Type MB4A Color Black (BK) Features & Benefits • For use with 18 and 30 pound cable ties to provide stability when securing bundles. • Secures with rubber based adhesive backing and/or two or four screws. • 4 way opening allows cable ties to be installed parallel or perpendicular to wire bundles. Quantity Per bag Product Description HellermannTyton adhesive fastened mounting bases are used with 18 through 150 pound cable ties to provide stability when securing bundles. The mounts are installed using the adhesive backing and/or by securing two or four screws. The 4 way opening allows the cable ties to be inserted parallel or perpendicular to the wire bundles. Short Description Adhesive Cable Tie Mount, 1.12" x 1.12", .18" Max Tie Width, .18" Hole Dia, PA66UV, Black, 500/pkg Global Part Name MB4A-PA66UV-BK Length L (Imperial) 1.12 Length L (Metric) 28.5 Fixation Method Screw Mounting and Adhesive Width W (Imperial) 1.12 Width W (Metric) 28.5 Cable Ties T18 - T50 Height H (Imperial) .23 Height H (Metric) 5.80 Cable Tie Width Max (Imperial) 0.18 Cable Tie Width Max (Metric) 4.6 Mounting Hole Diameter D (Imperial) 0.18 Mounting Hole Diameter D (Metric) 4.6 mm Mounting Hole Diameter D Max (Metric) 4.6 Mounting Hole Centers (Imperial) 0.8 Material Polyamide 6.6 UV-stabilized (PA66UV) Material Shortcut PA66UV Adhesive Acrylate with base of acrylic foam Flammability UL 94 V2 (excluding adhesive) Operating Temperature (Metric) -40°F to +185°F (-40°C to +85°C) ROHS Complaint Yes Package Quantity(Imperial) 500 Package Quantity (Metric) 500 Customs Number 3926909988 © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
151-00646 价格&库存
很抱歉,暂时无法提供与“151-00646”相匹配的价格&库存,您可以联系我们找货
