Specification Sheet
Part Number: 151-00644
Dual Swivel Saddle Spacer for T50-T250, Bundle Diameter 0.25 - 3.0", PA66HS/POM, Black, 50/pkg
Article Number
151-00644
Type
DSWS4
Color
Black (BK)
Features & Benefits
• H-profile of the saddles allows for broad surface contact with the
bundle, which minimizes pinching and crushing of the bundle. •
Swivels in 360-degree motion to accommodate any area. •
Accommodates T50–T250 ties to handle both light-duty and
heavy-duty applications.
Quantity Per
bag
Product Description
These saddle spacers are installed between two bundles (such as
wires, cables, hoses, tubing, conduit, etc.) to separate and prevent
chafing and wear. The mounts can be easily rotated by hand,
allowing the bundles to be crossed and rotated at any angle. Cable
ties, which secure the bundles, are used with the mounts. The dual
swivel saddle spacers accommodate cable ties up to 1/2" wide.
Short Description
Dual Swivel Saddle Spacer for T50-T250, Bundle Diameter 0.25 3.0", PA66HS/POM, Black, 50/pkg
Global Part Name
DSWS4-PA66HS/POM-BK
Length L (Imperial)
0.91
Length L (Metric)
23.6
Width W (Imperial)
0.8
Width W (Metric)
20.3
Bundle Diameter Min (Imperial)
0.3
Bundle Diameter Min (Metric)
6.0
Bundle Diameter Max (Imperial)
3.0
Bundle Diameter Max (Metric)
76.0
Cable Ties
T50 - T250
Height H (Imperial)
0.7
Height H (Metric)
18.0
Cable Tie Width Max (Imperial)
0.5
Cable Tie Width Max (Metric)
12.7
Material
Polyamide 6.6 heat stabilized (PA66HS) Polyacetal (POM)
Material Shortcut
PA66HS POM
Flammability
UL 94 HB
Operating Temperature (Metric)
-40°F to +221°F (-40°C to +105°C) -31°F to +185°F (-35°C to +85°C)
Minimum Extraction Force (Imperial)
100.0
Minimum Extraction Force (Metric)
445
Reach Complaint(Article 33)
Yes
ROHS Complaint
Yes
Package Quantity(Imperial)
50
Package Quantity (Metric)
50
Customs Number
3926909988
Content Unit(BMEcat)
pcs.
Weight (Metric)
3.8
© 2020 HellermannTyton. All Rights Reserved.
Contact Us
RoHS/WEEE Compliance
Disclaimer
Terms and Conditions
很抱歉,暂时无法提供与“151-00644”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+23.6834850+3.06346
