HDM3120HIRC2
Article Number: 151-00439
Standard Torque Mount, Mounting Hole .3125", Max Torque 115.0 lb - in, PA66HIRHSUV, Black, 100/pkg
Download spec sheet
Base Data
Local Order Number HDM3120HIRC2
Type HDM312
Color Black (BK)
Features and Benefits • Mount and tie combination makes it easy to service bundles in the field.
• Made from impact modified, heat stabilized, UV resistant material, ideal for heavy duty environments.
• Eliminates the needs for multiple sized fix diameter clamps.
Product Description This mount, when used with a cable tie eliminates the need to carry multiple sizes of fixed bundle diameter clamps;
which reduces inventory and purchasing costs while simplifying the assembly process.
Fixation Method (FF) Screw Mounting and Rivet
Short Description Standard Torque Mount, Mounting Hole .3125", Max Torque 115.0 lb - in, PA66HIRHSUV, Black, 100/pkg
Product Dimensions
Length L (Imperial) 1.4 "
Length L (Metric) 36.3 mm
Width W (Imperial) 0.8 "
Width W (Metric) 19.3 mm
Cable Tie Width Max. (Imperial) 0.5 "
Cable Tie Width Max. (Metric) 12.7 mm
Width W2 (Imperial) 0.5 "
Width W2 (Metric) 13.3 mm
Height H (Imperial) 0.7 "
Height H (Metric) 16.7 mm
Height H2 (Imperial) 0.3 "
Height H2 (Metric) 8.0 mm
Mounting Hole Diameter D (Imperial) 0.3 "
Mounting Hole Diameter D (Metric) 7.8 mm
Logistics and Packaging
Quantity Per bag
Package Quantity (Metric) 100 Pieces
Carton Quantity 3000 Pieces
Material and Specifications
Material Polyamide 6.6 high impact modified, heat and UV stabilized (PA66HIRHSUV)
Material Shortcut PA66HIRHSUV
Flammability UL94 HB
Maximum Torque (kgf-cm) 132.5 kgf-cm
Maximum Torque (lbf-ft) 9.583 lbf-ft
Operating Temperature -40°F to +230°F (-40°C to +110°C)
ROHS compliant (Article 4 - 1) Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“HDM3120HIRC2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+13.09523100+1.69357
