LKM.NB6P
LKM.NB6P
    HELLERMAN(海尔曼太通)
LKM.NB6P 数据手册
Screw Fixing Mounts LKM | HellermannTyton Page 1 of 1 www.hellermanntyton.co.uk | Products | Cable Ties and Fixings | Cable Tie Mounts Screw Fixing Mounts LKM LKM / CL / FH with curved design for sideways fixing, Article number: 151-26302 • Screwable mounts for fixing cable sideways • Ideal for securing large, heavier bundles • Suitable for cable ties up to 8 mm wide In areas with limited space these mounting bases allow the cable to be offset from the fixing hole, and can be installed in the equipment prior to the cable installation. A major cost saving can be made by using these products as many different sizes of standard cable ties can be used, reducing the need to stock a wide range of specific fixing ties. Print Base Data Colour Black (BK) Fixation Method (FF) Screw Mounting and Rivet Product Family LKM / CL / FH with curved design for sideways fixing Product Group Screw Fixing Mounts Type LKM.NB6P Product Dimensions Height (H) 16 mm Height (H2) 5 mm Hole ∅ (FH) 6.0 mm Length (L) 27 mm Strap Width max. (G) 7.6 mm Width (W) 12 mm Logisitic and Packaging EAN code 5022660310751 Pack Cont. 500 Quantity per Bag Material and Specifications Flammability UL94 V2 Material PA66 Material Polyamide 6.6 (PA66) Operating Temperature -40 °C to +85 °C, (+105 °C, 500 h) © HellermannTyton 2013 http://www.hellermanntyton.co.uk/site/products/cable-tie-mounts/lkm/151-26302 10/25/2013
LKM.NB6P 价格&库存
很抱歉,暂时无法提供与“LKM.NB6P”相匹配的价格&库存,您可以联系我们找货
