GTM50A0C2
GTM50A0C2
    HELLERMAN(海尔曼太通)
    GRPTIEMNTFOR.5"TIEADHBLK
GTM50A0C2 数据手册
GTM50A0C2 Article Number: 130-95001 Grip Tie Mount for .5" Wide Grip Tie, Adhesive, PA66UV, Black, 100/pkg Download drawing Download spec sheet Base Data Local Order Number GTM50A0C2 Type GTM50A Color Black (BK) Features and Benefits • Adhesive with 1/4" screw hole mount secures .5" grip ties for use on flat surfaces Product Description To secure bundles to flat surfaces, HellermannTyton offers a mounting base to be used with the Grip Ties. Available with or without adhesive, two sizes of Grip Tie mounts cover every size of Grip Tie. The mounts are manufactured from nylon 6/6 material and are UV-stabilized for outdoor applications. Short Description Grip Tie Mount for .5" Wide Grip Tie, Adhesive, PA66UV, Black, 100/pkg Product Dimensions Length L (Imperial) 2.5 " Length L (Metric) 63.5 mm Fixation Method None Identification Plate Position none Mounting Method Adhesive Releasable Closure Yes Tie Closure hook and loop Variant Grip Tie Width W (Imperial) 1.0 " Width W (Metric) 25.4 mm Logistics and Packaging Quantity Per bag Package Quantity 100 Package Quantity (Metric) 100 Pieces Material and Specifications Material Polyamide 6.6 UV-resistant (PA66UV) Material Shortcut PA66UV ROHS Compliant Yes © HellermannTyton 2015
GTM50A0C2 价格&库存
很抱歉,暂时无法提供与“GTM50A0C2”相匹配的价格&库存,您可以联系我们找货
GTM50A0C2
  • 100+14.78843100+1.91328
  • 200+14.08200200+1.82189
  • 300+13.68477300+1.77049
  • 500+13.20025500+1.70781
  • 700+12.89050700+1.66773
  • 1000+12.570241000+1.62630
库存:100
