Engineered Fastening Solutions
Fasteners
Wide Strap Heavy Duty Cable Ties
The wide strap cable tie minimizes pinching on soft bundles and
features a low profile head to provide compact bundling. A thinner
strap provides increased flexibility for improved ergonomics.
– Wide strap is designed to minimize pinching of soft hoses and
convoluted tubing
– Low profile head
– Clamping rails on the bottom of head to increase grip on round
bundles
– Accommodates a large range of bundle diameters:
.375” - 4.125” (9.5mm - 104.7mm)
– Flexible strap
– Bent tip for quick insertion into mounts
Material Data
Material
Polyamide 6.6 high impact modified,
heat stabilized (PA66HIRHS)
Operating
Temperature
-40 °F to +230 °F (-40 °C to +110 °C)
continuous
Flammability
UL94 HB
Product Selection
Article No.
Part No.
Type
Min. Tensile Strength
Length (L)
Max. Ø Bundle
Width (W)
lbs. (N)
in. (mm)
in. (mm)
in. (mm)
Color
Pkg. Qty.
WSS
111-12303 111-12303
WSS
120 lbs
(534)
9.1″
(231.14)
2.25″
(57.15)
.5″
(12.7)
Black
60
111-12300 111-12300
WSS
120 lbs
(534)
9.1″
(231.14)
2.25″
(57.15)
.5″
(12.7)
Black
300
111-12304 111-12304
WSI
120 lbs
(534)
12.1″
(307.34)
3.25″
(82.55)
.5″
(12.7)
Black
60
111-12301 111-12301
WSI
120 lbs
(534)
12.1″
(307.34)
3.25″
(82.55)
.5″
(12.7)
Black
300
111-12305 111-12305
WSR
120 lbs
(534)
15.1″
(383.54)
4.125″
(104.78)
.5″
(12.7)
Black
60
111-12302 111-12302
WSR
120 lbs
(534)
15.1″
(383.54)
4.125″
(104.78)
.5″
(12.7)
Black
300
WSI
WSR
Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification
purposes.
32
w w w . h e l l e r m a n n . t y t o n . c o m
1 - 8 0 0 - 5 3 7 - 1 5 1 2
Fasteners
T250 Series
These cable ties offer a high minimum tensile strength and have a
buckle feature which allows the end of the cable tie to be tucked
away if necessary. The buckle also snaps into HellermannTyton LTM,
lashing tie mounts.
T250 heavy duty cable tie and lashing tie mount application
Material Data
Material
Polyamide 6.6 (PA66)
Operating
Temperature
-40 °F to +185 °F (-40 °C to +85 °C) continuous
Flammability
UL94 V2
File# E64139
Product Selection
Min. Tensile
Strength
Article No.
T250S
Part No.
Type
lbs.
(N)
Length (L)
in.
Max. Ø Bundle
(mm)
in.
(mm)
Width (W)
in.
(mm)
Color
Pkg. Qty.
111-24702
T250S9X2
T250S
250 lbs
(1115)
9.05″
(230)
2.17″
(55)
.49″
(12.5)
Natural
25
111-24700
T250S0X2
T250S
250 lbs
(1115)
9.05″
(230)
2.17″
(55)
.49″
(12.5)
Black
25
111-24803
T250R9X2
T250R
250 lbs
(1115)
20.47″
(520)
5.71″
(145)
.49″
(12.5)
Natural
25
111-24801
T250R0X2
T250R
250 lbs
(1115)
20.47″
(520)
5.71″
(145)
.49″
(12.5)
Black
25
111-25002
T250M9X2
T250M
250 lbs
(1115)
22.24″
(565)
5.90″
(150)
.49″
(12.5)
Natural
25
111-25001
T250M0X2
T250M
250 lbs
(1115)
22.24″
(565)
5.90″
(150)
.49″
(12.5)
Black
25
T250R
T250M
T250I
111-25219
T250I9X2
T250I
250 lbs
(1115)
28.54″
(725)
8.00″
(203)
.49″
(12.5)
Natural
25
111-00507
T250I0X2
T250I
250 lbs
(1115)
28.54″
(725)
8.00″
(203)
.49″
(12.5)
Black
25
111-00436
T250L9X2
T250L
250 lbs
(1115)
34.65″
(880)
10.00″
(254)
.49″
(12.5)
Natural
25
111-24601
T250L0X2
T250L
250 lbs
(1115)
34.65″
(880)
10.00″
(254)
.49″
(12.5)
Black
25
T250L
T250XL
111-00466
T250XL9X2
T250XL
250 lbs
(1115)
40.55″
(1030)
12.00″
(305)
.49″
(12.5)
Natural
25
111-25200
T250XL0X2
T250XL
250 lbs
(1115)
40.55″
(1030)
12.00″
(305)
.49″
(12.5)
Black
25
purposes.
33
Fasteners
T255 Series
HellermannTyton’s T255 series heavy duty cable ties are ideal for bundles
requiring a strong cable tie that may also require a higher temperature
rating than the T250 series. These ties have a tensile strength of 250 lbs.
Material Data
Material
Polyamide 6.6 high impact modified, heat
Operating
Temperature
-40 °F to +230 °F (-40 °C to +110 °C) continuous
Flammability
UL94 HB
File# E64139
Product Selection
Article No.
(N)
Length (L)
Max. Ø Bundle
(mm)
Width (W)
Part No.
Type
lbs.
in.
(mm)
in.
in.
(mm)
Color
Pkg. Qty.
111-25500 T255S0HIRX2
T255S
250 lbs
(1115)
8.86″
(225)
2.16″
(55)
.49″
(12.5)
Black
25
111-25400 T255R0HIRX2
T255R
250 lbs
(1115)
20.28″
(520)
5.71″
(145)
.49″
(12.5)
Black
25
111-25300 T255M0HIRX2
T255M
250 lbs
(1115)
22.05″
(565)
6.30″
(160)
.49″
(12.5)
Black
25
purposes.
34
Fasteners
Button Head Ties
The button head tie is a two piece tie providing
for parallel entry and exit through the head. The
strap contains serrations on both sides and has
two opposed pawls recessed within a domed
head.
This design allows the strap to be directed
clockwise or counter-clockwise prior to insertion
into the head, enabling bi-directional looping.
New and Improved Features
The button head tie offers many new and
improved features for added durability and
installation ease.
Standoff tabs — prevent tie head from seating in
button during strap insertion
Pilot bushing - protects the strap from abrasion on
the mounting hole edge
Ribs - increased ribs added to the bottom of the
button head for added durability
Strap - more radiused edges for added flexibility
Serrations - redesigned serrations and wedge design
provide optimal strength when seated in the head
Retainers — lower retainers on BT130 help prevent
the strap from backing out of the mounting hole
and holds HellermannTyton’s saddle mounts in place
during assembly.
35
Fasteners
Button Head Ties (continued)
Material Data
Cable Tie Material
Button Head
Material
Polyamide 6.6 heat stabilized (PA66HS)
Operating
Temperature
-40 °F to +221 °F (-40 °C to +105 °C) continuous
Color
Flammability
Black
UL94 HB
Product Selection
Min. Tensile
Strength
Article No.
Part No.
BT105 Button Head Ties
Type
lbs.
(N)
Length (L)
in.
Max. Ø Bundle
(mm)
Width (W)
in.
(mm)
in.
(mm)
Color
Pkg.
Qty.
132-00010
132-00010
BT105R
105 lbs
(467)
9.63″
(244.4)
2.62″
(66.7)
.22″
(5.6)
Black
50
132-00011
132-00011
BT105L
105 lbs
(467)
15″
(381.5)
4.33″
(110)
.22″
(5.6)
Black
50
BT105 Button Head Ties with Pilot Bushings
132-00006
132-00006
BT105RP
105 lbs
(467)
9.63″
(244.4)
2.62″
(66.7)
.22″
(5.6)
Black
50
132-00007
132-00007
BT105LP
105 lbs
(467)
15″
(381.5)
4.33″
(110)
.22″
(5.6)
Black
50
BT130 Button Head Ties with Retainers and Pilot Bushings
132-00008
132-00008
BT130RDP
130 lbs
(578)
10.51″
(267.0)
2.87″
(73)
.30″
(7.6)
Black
50
132-00009
132-00009
BT130LDP
130 lbs
(578)
15″
(381.5)
4.33″
(110)
.30″
(7.6)
Black
50
purposes.
36
Fasteners
Fir Tree Mount and Cable Tie Assemblies
HellermannTyton's fir tree mounts provide a secure grip in a mounting
hole and protect against dirt and other impurities. The mount can slide
along the strap of the tie for proper orientation. The fir tree mounts are
designed to provide a low insertion force and high extraction force.
These mounts are sold as an assembly with the cable tie.
Material Data - All Cable Ties/
FT7, FT8 and FT10 Mounts
Material
Operating
Temperature
Color
Flammability
Material Data - FT5, FT6 and FT6LG Mounts
Material
Polyamide 6.6 heat
stabilized (PA66HS)
-40 °F to +221 °F
(-40 °C to +105 °C)
Operating
Temperature
Black
Color
UL94 V2
Flammability
modified, heat stabilized
(PA66HIRHS)
-40 °F to +230 °F
(-40 °C to +110 °C)
Black
UL94 HB
Product Selection
Cable Tie
Article No.
Part No.
Type
Min.
Tensile
Strength
lbs.
(N)
Max. Ø Length
(L)
Bundle
in.
in.
(mm)
(mm)
Mount
Width
(W)
in.
(mm)
Disc Ø
in.
(mm)
Length
(L2)
in.
(mm)
Length
(L3)
in.
(mm)
Width
(W3)
in.
(mm)
Height
(H2)
in.
(mm)
.52 ″
(13.2)
.52 ″
(13.2)
.20 ″
(5)
.20 ″
(5)
.27 ″
(6.9)
.27 ″
(6.9)
.54 ″
(13.8)
.54 ″
(13.8)
.54 ″
(13.8)
.54 ″
(13.8)
.20 ″
(5)
.20 ″
(5)
.20 ″
(5)
.20 ″
(5)
.295 ″
(7.5)
.295 ″
(7.5)
.295 ″
(7.5)
.295 ″
(7.5)
Pkg.
Qty.
FT5 - Mounting Hole Ø: .177″″ - .197″″ (4.5-5.0mm) - Panel Thickness: .028″″ - .193″″ (0.7 - 3.0mm)
150-55850 150-55850
T30RFT5
156-00025 156-00025
T50RFT5
30 lbs
(135)
50 lbs
(225)
1.38 ″
(35)
1.75 ″
(44.5)
5.8 ″
(148)
8″
(203.2)
.14 ″
(3.6)
.18 ″
(4.6)
.63 ″
(16.0)
.63 ″
(16.0)
.46 ″
(11.6)
.46 ″
(11.6)
500
500
FT6 - Mounting Hole Ø: .252″″ - .28″″ (6.4-7.1mm) - Panel Thickness: .028″″ - .193″″ (0.75 - 3.0mm)
150-77940 150-77940
T30RFT6
156-00156 156-00156
T50SFT6
156-00157 156-00157
T50RFT6
156-00066 156-00066
T50LFT6
30 lbs
(135)
50 lbs
(225)
50 lbs
(225)
50 lbs
(225)
1.38 ″
(35)
1.38 ″
(35)
1.75 ″
(44.5)
4″
(101.6)
5.8 ″
(148)
6.3 ″
(160)
8″
(203.2)
15 ″
(380)
.14 ″
(3.6)
.18 ″
(4.6)
.18 ″
(4.6)
.18 ″
(4.7)
.63 ″
(16.0)
.63 ″
(16.0)
.63 ″
(16.0)
.63 ″
(16)
.46 ″
(11.6)
.46 ″
(11.6)
.46 ″
(11.6)
.46 ″
(11.6)
500
500
500
500
Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and
Type for specification purposes.
37
Fasteners
Fir Tree Mount and Cable Tie Assemblies (continued)
Product Selection
Cable Tie
Article No.
Part No.
Type
Max. Ø
Min.
Tensile Bundle
in.
Strength
(mm)
lbs. (N)
Length
(L)
in.
(mm)
Width
(W)
in.
(mm)
Mount
Disc Ø
in.
(mm)
Length
(L2)
in.
(mm)
Length
(L3)
in.
(mm)
Width Height
(H2)
(W3)
in.
in.
(mm)
(mm)
Pkg. Qty.
FT6LG - Mounting Hole Ø: .256″″ - .276″″ (6.4-7.1mm) - Panel Thickness: .03″″ - .24″″ (0.75 - 6.0mm)
150-31090 150-31090 T30RFT6LG
30 lbs
(135)
1.38 ″
(35)
5.8 ″
(148)
.14 ″
(3.6)
.63 ″
(16)
.46 ″
(11.6)
.69 ″
(17.5)
.19 ″
(5)
.44 ″
(11.1)
500
150-31093 150-31093 T50SFT6LG
50 lbs
(225)
1.38 ″
(35)
6.3 ″
(160)
.18 ″
(4.6)
.63 ″
(16)
.46 ″
(11.6)
.69 ″
(17.5)
.19 ″
(5)
.44 ″
(11.1)
500
150-31091 150-31091 T50RFT6LG
50 lbs
(225)
1.75 ″
(44)
8″
(203.2)
.18 ″
(4.6)
.63 ″
(16)
.46 ″
(11.6)
.69 ″
(17.5)
.19 ″
(5)
.44 ″
(11.1)
500
156-00054 156-00054 T50IFT6LG
50 lbs
(225)
3.35 ″
(85)
11.8 ″
(300)
.18 ″
(4.6)
.63 ″
(16)
.46 ″
(11.6)
.69 ″
(17.5)
.19 ″
(5)
.44 ″
(11.1)
500
FT7 - Mounting Hole Ø: .256″″ - .276″″ (6.5-7.0mm) - Panel Thickness: .031″″ - .276″″ (0.8 - 7.0mm)
156-00057 156-00057
T30RFT7
30 lbs
(135)
1.38 ″
(35)
5.8 ″
(148)
.14 ″
(3.6)
.63 ″
(16)
.46 ″
(11.6)
.75 ″
(19)
.20 ″
(5)
.5 ″
(12.7)
500
156-00056 156-00056
T50SFT7
50 lbs
(225)
1.38 ″
(35)
6.3 ″
(160)
.18 ″
(4.6)
.63 ″
(16)
.46 ″
(11.6)
.75 ″
(19)
.20 ″
(5)
.5 ″
(12.7)
500
111-85871 111-85871
T50RFT7
50 lbs
(225)
1.75 ″
(44)
8″
(203.2)
.18 ″
(4.6)
.63 ″
(16)
.46 ″
(11.6)
.75 ″
(19)
.20 ″
(5)
.5 ″
(12.7)
500
111-05350 111-05350
T50IFT7
50 lbs
(225)
3.35 ″
(85)
11.8 ″
(300)
.18 ″
(4.6)
.63 ″
(16)
.46 ″
(11.6)
.75 ″
(19)
.20 ″
(5)
.5 ″
(12.7)
500
156-00055 156-00055
T50LFT7
50 lbs
(225)
4.33 ″
(110)
15 ″
(380)
.18 ″
(4.7)
.63 ″
(16)
.46 ″
(11.6)
.75 ″
(19)
.20 ″
(5)
.5 ″
(12.7)
500
FT8 - Mounting Hole Ø: .3″″ - .31″″ (7.7-8.0mm) - Panel Thickness: .03″″ - .31″″ (0.8 - 8.0mm)
156-00058 156-00058
T30RFT8
30 lbs
(135)
1.38 ″
(35)
5.8 ″
(148)
.14 ″
(3.6)
.63 ″
(16)
.47 ″
(12.0)
.7 ″
(17.8)
.35 ″
(9)
.45 ″
(11.5)
500
156-00158 156-00158
T50RFT8
50 lbs
(225)
1.75 ″
(44)
8″
(203.2)
.18 ″
(4.6)
.63 ″
(16)
.47 ″
(12.0)
.7 ″
(17.8)
.35 ″
(9)
.45 ″
(11.5)
500
156-00060 156-00060
T50IFT8
50 lbs
(225)
3.35 ″
(81)
11.8 ″
(300)
.18 ″
(4.6)
.63 ″
(16)
.47 ″
(12.0)
.7 ″
(17.8)
.35 ″
(9)
.45 ″
(11.5)
500
156-00061 156-00061
T50LFT8
50 lbs
(225)
4.33 ″
(110)
15 ″
(380)
.18 ″
(4.7)
.63 ″
(16)
.47 ″
(12.0)
.7 ″
(17.8)
.35 ″
(9)
.45 ″
(11.5)
500
FT10 - Mounting Hole Ø: .38″″ - .39″″ (9.7-10.0mm) - Panel Thickness: .031″″ - .236″″ (0.8 - 5.0mm)
156-00089 156-00089 T30RFT10
30 lbs
(135)
1.38 ″
(35)
5.8 ″
(148)
.14 ″
(3.6)
.71 ″
(18)
.47 ″
(12)
.75 ″
(18.6)
.20 ″
(5)
.48 ″
(12.1)
500
156-00090 156-00090 T50SFT10
50 lbs
(225)
1.38 ″
(35)
6.3 ″
(160)
.18 ″
(4.6)
.71 ″
(18)
.47 ″
(12)
.75 ″
(18.6)
.20 ″
(5)
.48 ″
(12.1)
500
156-00091 156-00091 T50RFT10
50 lbs
(225)
1.75 ″
(44)
8″
(203.2)
.18 ″
(4.6)
.71 ″
(18)
.47 ″
(12)
.75 ″
(18.6)
.20 ″
(5)
.48 ″
(12.1)
500
156-00092 156-00092
T50IFT10
50 lbs
(225)
3.35 ″
(81)
11.8 ″
(300)
.18 ″
(4.6)
.71 ″
(18.0)
.47 ″
(12)
.75 ″
(18.6)
.20 ″
(5)
.48 ″
(12.1)
500
156-00093 156-00093 T50LFT10
50 lbs
(225)
4.33 ″
(110)
15 ″
(380)
.18 ″
(4.7)
.71 ″
(18)
.47 ″
(12)
.75 ″
(18.6)
.20 ″
(5)
.48 ″
(12.1)
500
Use Part No. for ordering and Type for specification purposes.
38
Fasteners
Heavy Duty Fir Tree Mounts and Cable Tie Assemblies
Designed specifically for 120 - 250 lb. cable ties, the
heavy duty fir tree mounts are optimized for up to 3 to 1
extraction versus insertion force. The “H” profile provides
a broad surface contact to minimize the pinching of
bundles and will easily hold bundles ranging from 3/8”
to 3”. Heavy duty fir tree mounts are equipped with a
friction tab that will hold the tie in the mount, allowing
them to be preassembled prior to installation. These
Material Data
Material
Operating
Temperature
continuous
Flammability
UL94 HB
Disc
Ø
W2
H
L
H2
W
FT9A
FT9A
Product Selection
Cable Tie
Article
No.
Part No.
Type
Min.
Tensile
Strength
lbs. (N)
Length
(L)
in.
(mm)
Max. Ø
Bundle
in.
(mm)
Mount
Width
(W)
in.
(mm)
Disc Ø
in.
(mm)
Width
(W2)
in.
(mm)
Height
(H)
in.
(mm)
Height
(H2)
in.
Pkg.
(mm) Qty.
FT9A - Mounting Hole Ø: .343”- .363” (8.75 - 9.25mm) - Panel Thickness: .04” - .26” (1.0 - 6.5mm)
156-00067 T120RFT9A0ZC2 T120RFT9A 120 lbs (534)
4” (101.6)
15.25” (387.4)
.30” (7.6)
.85" (21.6)
.51" (13) .75" (19.1) .36 ″ (9) 100
156-00068 WSSFT9A0ZC2
WSSFT9A 120 lbs (534) 2.25” (57.1)
9” (228.6)
.50” (12.7) .85" (21.6)
156-00069 WSIFT9A0ZC2
WSIFT9A 120 lbs (534) 3.25” (82.5)
12” (304.8)
.51" (13) .75" (19.1) .36″ (9)
100
156-00070 WSRFT9A0ZC2
WSRFT9A 120 lbs (534) 4.13” (104.8)
15” (381)
.51" (13) .75" (19.1) 36″ (9)
100
Disc
Ø
W2
L
H
H2
W
FT9B
FT9B
Product Selection
Cable Tie
Article
No.
Part No.
Type
Min.
Tensile
Strength
lbs. (N)
Max. Ø
Bundle
in.
(mm)
Length
(L)
in.
(mm)
Mount
Width
(W)
in.
(mm)
Disc Ø
in.
(mm)
Width
(W2)
in.
(mm)
Height
(H)
in.
(mm)
Height
(H2)
in.
(mm)
Pkg.
Qty.
FT9B - Mounting Hole Ø: .343”- .363” (8.75 - 9.25mm) - Panel Thickness: .04” - .62” (1.0 - 15.8 mm)
156-00071 T120RFT9B0ZC2 T120RFT9B 120 lbs (534)
4” (101.6)
15.25” (387.4)
.30” (7.6)
.85" (21.6)
.51" (13) 1.12" (28.4) .73" (18.4) 100
156-00072 WSSFT9B0ZC2
WSSFT9B 120 lbs (534) 2.25” (57.1)
9” (228.6)
156-00073 WSIFT9B0ZC2
WSIFT9B
12” (304.8)
156-00074 WSRFT9B0ZC2
WSRFT9B 120 lbs (534) 4.13” (104.8)
15” (381)
39
Fasteners
Fir Tree Push Mount Ties
Fir tree design grips to the inside of a hole. They can be used on sheet metal, wood, and cast iron. Type T50RTM25E has a
longer fir tree for larger panel thicknesses.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Min. Tensile
Strength
Mounting
Hole Ø
Panel
Thickness
Length (L)
Max. Ø
Bundle
in.
(mm)
in.
(mm)
in. (mm)
in. (mm)
lbs.
126-03501 T50RTM250HSM4
T50RTM25
50 lbs
(225)
.25″ - .26″ .052″ - .28″
8.27″ (210) 1.97″ (50.0) .19″ (4.7)
(6.5 - 6.6) (1.32 - 7.0)
Black
1000
157-01400 T50RTM25E8HSM4
T50RTM25E
50 lbs
(225)
.25″ - .26″ .09″ - .55″
8.43″ (214) 1.97″ (50.0) .19″ (4.7)
(6.5 - 6.6) (2.3 - 13.94)
Gray
1000
Part No.
in. (mm) Color
Pkg.
Qty.
Type
Article No.
(N)
Width (W)
Fir Tree Mount with Disc Tie
This fir tree mount tie provides a low insertion force with a high extraction force. The outside serrations present a smooth
surface to the cables preventing damage to the insulation. The unique head design allows the cable tie to firmly hold
bundles as small as .06” diameter and the disc offers added water protection.
Material Data
Material
Operating
Temperature
Flammability
UL94 HB
Product Selection
Min. Tensile
Strength
Article No.
Part No.
Type
155-05800 155-05800 T50SOSFT6E
lbs.
50 lbs
(N)
(225)
Mounting
Hole Ø
Panel
Thickness
Length
(L)
Max. Ø
Bundle
in.
(mm)
in.
(mm)
in. (mm)
in. (mm)
.26″ - .28″
(6.5-7.0)
.03″ - .12″
(0.75 - 3.0)
6.30″ (160) 1.38″ (35)
Width
(W)
in. (mm) Color
Pkg.
Qty.
.18″ (4.6)
500
Black
40
Fasteners
Domed Fir Tree Mount
The domed head tie provides a tight, rattle-free installation and the outside serrated strap has ribs designed for convoluted
tubing. The dome also acts as a seal to keep out dust and liquid.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Article No.
Part No.
Type
Min. Tensile
Strength
Mounting
Hole Ø
Panel
Thickness
lbs. (N)
in.
(mm)
in.
(mm)
.25″ - .28″
(6.3-7.0)
.03″ - .28″
(0.8 - 7.0)
157-01100 T50SDP6.HB6P T50SDP6 45 lbs (200)
Length (L)
in.
(mm)
6.69″
(170)
Max. Ø
Bundle
Width (W)
in. (mm)
in. (mm)
1.22″ (31)
.20″ (5.1)
Color
Pkg.
Qty.
Black
500
Domed Push Mount Tie
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Min. Tensile
Strength
Article No.
Part No.
Type
lbs.
(N)
111-85350
111-85350
T50SD6
50 lbs
(225)
Mounting
Hole Ø
Panel
Thickness
Length (L)
Max. Ø
Bundle
Width (W)
in.
(mm)
in.
(mm)
in. (mm)
in. (mm)
in. (mm)
.25″ - .30″
(6.3-7.5)
.023″ - .047″
(0.6 - 1.2)
6.30″ (160) 1.22″ (31) .20″
(5.1)
Color
Pkg.
Qty.
Black
500
41
Fasteners
Push Mount Ties
One-piece, all plastic ties for quick, simple cable mounting.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
File# E64139
Product Selection
Min. Tensile
Strength
Article
No.
T30RSF
Mounting
Hole Ø
Panel
Thickness
Length (L)
Max. Ø
Bundle
Width (W)
in.
(mm)
in.
(mm)
in. (mm)
in. (mm)
in. (mm)
Color
Pkg.
Qty.
6.34″ (161) 1.25″ (31.8) .14″ (3.6)
Natural
100
.04″ - .09″
(0.9-2.36)
Natural
1000
.19″ - .22″
(4.76-5.59)
.04″ - .09″
(0.9-2.36)
Black
100
(135)
.19″ - .22″
(4.76-5.59)
.04″ - .09″
(0.9-2.36)
Black
1000
50 lbs
(225)
.25″ - .28″
(6.4-7.1)
.04″ - .14″
(1.0-3.56)
6.26″ (159) 1.38″ (35)
.19″ (4.7)
Natural
100
T50SSF
50 lbs
(225)
.25″ - .28″
(6.4-7.1)
.04″ - .14″
(1.0-3.56)
.19″ (4.7)
Natural
1000
126-00045 126-00045
T50SSF
50 lbs
(225)
.25″ - .28″
(6.4-7.1)
.04″ - .14″
(1.0-3.56)
.19″ (4.7)
Black
100
126-00046 126-00046
T50SSF
50 lbs
(225)
.25″ - .28″
(6.4-7.1)
.04″ - .14″
(1.0-3.56)
.19″ (4.7)
Black
1000
111-85789 T50RSF9C2
T50RSF(U)
50 lbs
(225)
.25″ - .28″
(6.4-7.1)
.04″ - .14″
(1.0-3.56)
8.27″ (210) 1.73″ (44)
.19″ (4.7)
Natural
100
126-01011 T50RSF9M4
T50RSF(U)
50 lbs
(225)
.25″ - .28″
(6.4-7.1)
.04″ - .14″
(1.0-3.56)
.19″ (4.7)
Natural
1000
126-01003 T50RSF0C2
T50RSF(U)
50 lbs
(225)
.25″ - .28″
(6.4-7.1)
.04″ - .14″
(1.0-3.56)
.19″ (4.7)
Black
100
126-01004 T50RSF0M4
T50RSF(U)
50 lbs
(225)
.25″ - .28″
(6.4-7.1)
.04″ - .14″
(1.0-3.56)
.19″ (4.7)
Black
1000
Part No.
Type
lbs.
(N)
111-85603 T30RSF9C2
T30RSF(U)
30 lbs
(135)
.19″ - .22″
(4.76-5.59)
.04″ - .09″
(0.9-2.36)
126-00704 T30RSF9M4
T30RSF(U)
30 lbs
(135)
.19″ - .22″
(4.76-5.59)
126-00700 T30RSF0C2
T30RSF(U)
30 lbs
(135)
126-00702 T30RSF0M4
T30RSF(U)
30 lbs
126-00043 126-00043
T50SSF
126-00044 126-00044
T50SSF
T50RSF
42
Fasteners
Wing Push Mount Ties
Wing design helps stabilize the tie in high vibration
applications. They can be used on sheet metal, wood,
and cast iron.
Material Data
Material
Operating
Temperature
-40 °F to +185 °F
Flammability
UL94 V2
Material Data
Material
Material Data
Polyamide 6.6 high
Material
(PA66HS)
Operating
Temperature
+110 °C) continuous
Operating
Temperature
continuous
Flammability
UL94 HB
Flammability
UL94 V2
File# E64139 File# E64139
Product Selection
Min.
Tensile
Strength
Mounting
Hole Ø
Panel
Thickness
Length (L)
Max. Ø
Bundle
Width (W)
lbs. (N)
in.
(mm)
in.
(mm)
in. (mm)
in. (mm)
in. (mm)
.19″ - .22″
(4.76-5.59)
.07″ - .13″
(1.85 - 3.18)
4.45″ (113)
.87″ (22)
.10″ (2.5)
126-00603 T18RWPM9M4 T18RWPM 18 lbs (80)
.19″ - .22″
(4.76-5.59)
.07″ - .13″
(1.85 - 3.18)
4.45″ (113)
.87″ (22)
126-00042 126-00042*
T18RWPM 18 lbs (80)
.19″ - .22″
(4.76-5.59)
.07″ - .13″
(1.85 - 3.18)
4.45″ (113)
.87″ (22) .10″ (2.5)
Black
T50SSFM 50 lbs (225)
.24″ - .25″
(6.0 - 6.4)
.04″ - .12″
(1.0 - 3.0)
5.71″ (145)
.98″ (25)
.19″ (4.7)
Black
Article No.
T18RWPM
Part No.
126-00041 126-00041
Type
T18RWPM 18 lbs (80)
Color
Material
Pkg.
Qty.
PA66
100
PA66
1000
PA66HS
1000
Natural
.10″ (2.5)
T50SSFM
126-00049 T50SSFM
PA66HIRHS 500
T50SL6
111-85469 T50SL6.NN6P
T50SL6
50 lbs (225)
.24″ - .26″
(6.1 - 6.5)
.03″ - .10″
(0.8 - 2.5)
6.50″ (165) 1.34″ (34)
.18″ (4.6)
Natural
PA66
500
T50SL7
50 lbs (225)
.27″ - .28″
(6.9 - 7.1)
.03″ - .10″
(0.8 - 2.5)
.18″ (4.6)
Natural
PA66
500
T50SL7
111-85479 T50SL7.NN6P
for ordering and Type for specification purposes. UL recognition applies to T18RWPM ties.
* UL listing applies to 126-00042.
43
Fasteners
Arrowhead Mount Ties with Seal
The arrowhead design of these ties offers a positive, low
insertion force and a high extraction force. These ties
feature a foam rubber seal which provides additional
protection against moisture, dirt and other impurities.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Min. Tensile Mounting
Panel
Strength
Hole Ø Thickness Length (L)
Article No.
Part No.
Type
lbs.
(N)
in. (mm)
in. (mm)
in. (mm)
Max. Ø
Bundle
Width
(W)
in. (mm) in. (mm)
Color
Pkg.
Qty.
126-03100 126-03100
T50SOSSFT6.5E-MD
50 lbs (225)
.25″ - .26″ .02″ - .07″
6.30″ (160) 1.38″ (35) .18″ (4.6)
(6.3-6.7) (0.6 - 1.8)
Green
500
156-00264 156-00264
T50SOSSFT6.5E-MD
50 lbs (225)
Black
500
44
Fasteners
Center Mount, Domed Push Mount Ties
The center mount, domed push mount tie centers the mount on all
bundle diameters. The mount is molded in a stationary position for easy
assembly. A tab extends beyond the head for easy strap insertion.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Article No.
Part No.
150-35930 150-35930
Type
T50RSP
Min. Tensile
Strength
Mounting
Hole Ø
Panel
Thickness
Length (L)
Max. Ø
Bundle
Width (W)
lbs. (N)
in.
(mm)
in.
(mm)
in. (mm)
in. (mm)
in. (mm)
Color
Pkg.
Qty.
.24″ - .26″
(6.0-6.5)
.03″ - .05″
(0.75 - 1.3)
1.77″ (45)
.18″ (4.6)
Black
1000
50 lbs
(222)
7.48″ (190)
Ladder Style Push Mount Ties
The unique ladder style design eliminates the need for various sizes of clamps and allows for easy re-entry to access bundle.
Wings on the side of the tie provide stabilization.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Type
Mounting
Hole Ø
Panel
Thickness
in.
(mm)
in.
(mm)
Length (L)
Max. Ø Bundle
Width (W)
in.
(mm)
in.
(mm)
in.
(mm)
Color
Pkg.
Qty.
.03″ - .15″
(0.7 - 3.9)
4.53″
(115)
1.06″
(27)
.40″
(10)
Black
500
.26″ - .25″
(6.3-6.7)
.03″ - .15″
(0.7 - 3.9)
6.30″
(160)
1.65″
(42)
.40″
(10)
Black
500
.26″ - .25″
(6.3-6.7)
.03″ - .15″
(0.7 - 3.9)
7.87″
(200)
2.09″
(53)
.40″
(10)
Black
500
Article No.
Part No.
150-26100
FBS1000H4
FBS100
.25″ - .26″
(6.3-6.7)
150-26140
FBS1400H4
FBS140
150-26180
FBS1850H4
FBS185
45
Fasteners
Wide Strap Heavy Duty Stud Mount Cable Ties
The wide strap stud mount cable tie minimizes pinching on soft bundles and
features a low profile head to provide compact bundling. A thinner strap
provides increased flexibility for improved ergonomics. Available with a 1/4”
and 3/8″ stud mount, the wide strap tie utilizes a strong hinge between the
stud mount and head to provide superior holding ability on a threaded stud.
Wide strap to minimize pinching of soft hoses and convoluted tubing
Clamping rails to increase grip on round bundles
Wide variation of bundle diameters: .375” - 4.125” (9.5mm - 104.7mm)
Flexible strap
Flexible hinge
Mount provides low insertion and high extraction forces
Material Data
Material
modified, heat stabilized (PA66HIRHS)
Operating
Temperature
continuous
Flammability
UL94 HB
Product Selection
Article No.
Part No.
Type
Wide Strap Ties with 1/4″″ Stud Mount
Min. Tensile
Strength
Length (L)
Max. Ø Bundle
Width (W)
lbs. (N)
in. (mm)
in. (mm)
in. (mm)
Color
Pkg. Qty.
157-00400 157-00400
WSS250
120 lbs
(534)
9.7″
(246.38)
2.25″
(57.15)
.5″
(12.7)
Black
300
157-00401 157-00401
WSI250
120 lbs
(534)
12.7″ (322.58)
3.25″
(82.55)
.5″
(12.7)
Black
300
157-00402 157-00402
WSR250
120 lbs
(534)
15.7″ (398.78)
4.125″ (104.78)
.5″
(12.7)
Black
300
Wide Strap Ties with 3/8″″ Stud Mount
WSS38
157-00406 157-00406
WSS380
120 lbs
(534)
9.7″
(246.38)
2.25″
(57.15)
.5″
(12.7)
Black
60
157-00403 157-00403
WSS380
120 lbs
(534)
9.7″
(246.38)
2.25″
(57.15)
.5″
(12.7)
Black
300
WSI38
157-00407 157-00407
WSI380
120 lbs
(534)
12.7″ (322.58)
3.25″
(82.55)
.5″
(12.7)
Black
60
157-00404 157-00404
WSI380
120 lbs
(534)
12.7″ (322.58)
3.25″
(82.55)
.5″
(12.7)
Black
300
WSR38
157-00408 157-00408
WSR380
120 lbs
(534)
15.7″ (398.78)
4.125″ (104.78)
.5″
(12.7)
Black
60
157-00405 157-00405
WSR380
120 lbs
(534)
15.7″ (398.78)
4.125″ (104.78)
.5″
(12.7)
Black
300
purposes.
46
Fasteners
Stud Mount Ties
The stud mount tie mounts and secures a cable bundle in one
component. The stud mount tie is designed for use on a 1/4″ - 20 UNC
threaded stud or the exposed threads of a machine screw.
Material Data
Material
Operating
Temperature
Flammability
UL94 HB
Product Selection
Stud Ø
Article No.
Part No.
Type
157-01300 T120RSM0HIRK2
in.
(mm)
.25 ″ (6.25)
T120RSM
Min. Tensile
Strength
lbs.
Length (L)
(N)
120 lbs (535)
in.
(mm)
15.94″ (405)
Max. Ø
Bundle
in.
Width (W)
(mm)
in.
3.98″ (101)
.30″
(mm)
Color
Pkg.
Qty.
(7.6)
Black
50
Standoff Stud Mount Tie
This tie is easily mounted on the top of the stud, and the additional height
gained by this design gives the bundle added clearance from the panel.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Stud Ø
Article No.
Part No.
155-30602 155-30602
Type
T50SSBS50TE
in.
.20 ″
(mm)
(5)
Min. Tensile
Strength
lbs.
45 lbs
(N)
(200)
Length (L)
in.
(mm)
6.30″ (160)
Max. Ø
Bundle
in.
(mm)
1.38″
(35)
Width (W)
(mm)
Color
Pkg.
Qty.
.181″ (4.6)
Black
500
in.
47
Fasteners
Oval Shaped Variable Stud Mount Ties
The special oval shape provides for an approximate .20”
(5.5mm) lateral adjustment, allowing for any misalignment of
the stud or incorrect positioning of the tie on the cables. The
“soft push” mount allows it to be installed onto a weld stud
without the use of any tools.
T50SOSSB5HEC
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
T50SOSSB6HE
Product Selection
Article No.
Part No.
Type
Stud Ø
Min. Tensile
Strength
in. (mm)
lbs. (N)
Max. Ø
Bundle
Length (L)
in.
(mm)
in.
(mm)
Width (W)
in. (mm)
Color
Pkg.
Qty.
155-05400 155-05400
T50SOSSB5HEC
.20 ″
(5)
38 lbs
(170)
6.30″
(160)
1.38″
(35)
.18″
(4.6)
Black
500
155-46302 155-46302
T50SOSSB6HE
.24 ″
(6)
38 lbs
(170)
6.30″
(160)
1.38″
(35)
.18″
(4.6)
Black
500
Stud Mount Tie with Outside Serrations
Providing an especially secure hold and the ability to mount the cables very close to the stud, this tie is outside serrated
preventing damage to the insulation of the cable.
T50SOSSBS5E
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Stud Ø
Article No.
Part No.
155-12300 155-12300
Type
T50SOSSBS5E
in.
.20 ″
(mm)
(5)
Min. Tensile
Strength
lbs.
(N)
50 lbs (225)
Length (L)
Max. Ø
Bundle
Width (W)
in.
(mm)
in. (mm)
in.
(mm)
Color
Pkg. Qty.
6.30″
(160)
1.38″ (35)
.18″ (4.6)
Black
500
48
Fasteners
Flexible Head Stud Mount Tie
Flexible head wraps around cable bundle for easy installation. Tie
mounts onto #10-24” stud.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Stud Ø
Article No.
Part No.
111-07110 T50RS5.NB3P
Type
in.
T50RS5
#10-24”
Min. Tensile
Strength
lbs.
50 lbs
Length (L)
Max. Ø
Bundle
Width (W)
(N)
in.
(mm)
in.
(mm)
in.
(mm)
Color
Pkg.
Qty.
(225)
7.5″
(190)
1.5″
(40)
.18″
(4.6)
Black
100
Stud Mount Tie with Disc
Offering the opportunity to retain both insulation material and cable
bundles with one product, this cable tie can be installed onto a weld stud
without the use of any tools. The unique head design allows the cable tie
to firmly hold bundles as small as .062” (1.6 mm) in diameter.
The new head design offers a secure mount on
soft materials.
Product Selection
Stud Ø
Article No.
Part No.
155-30602 155-30602
Type
T50SSBS50TE
in.
.20 ″
(mm)
(5)
Min. Tensile
Strength
lbs.
45 lbs
(N)
(200)
Length (L)
in.
(mm)
6.30″ (160)
Max. Ø
Bundle
in.
(mm)
1.38″
(35)
Width (W)
(mm)
Color
Pkg.
Qty.
.181″ (4.6)
Black
500
in.
49
Fasteners
Stud Mount Lateral Adjustment Tie
The special shape of this mount provides a .20” (5-6 mm)
lateral adjustment to allow for any misalignment of the stud
or incorrect positioning of the tie on the cables. The low
profile of the mount allows for several ties to be installed
one-on-top of the other (on the same stud) to accommodate
different cable bundles.
T50SOSWSP5E, parallel installation using two
stud mount lateral ties.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Stud Ø
Article No.
Part No.
Type
in. (mm)
155-23601
155-23601
T50S0SWSP5E
.20” (5)
Min. Tensile
Strength
lbs.
50 lbs
(N)
(225)
Length (L)
in.
(mm)
6.35″ (163)
Max. Ø
Bundle
Width (W)
in.
(mm)
in.
(mm)
Color
Pkg.
Qty.
1.4″
(35)
.18″
(4.6)
Black
500
50
Fasteners
Cable Ties and Edge Clips
HellermannTyton’s edge clips are designed specifically to route bundles by securing them to the edge of a plastic or metal
sheet without the need for a mounting hole. The clip is easy to secure and the extraction force is high due to the integrated
metal clamp that holds the edge clip in place. Edge clips are available in three configurations: a two piece clip and tie
assembly, a one piece clip and tie combination and a edge clip and tape bar combination. When noted (*), cable ties are
outside serrated which can reduce bundle chafing.
Two Piece Edge Clip and Cable Tie Assemblies
Material Data- Cable Tie
Material
Color
Black
Operating
Temperature
Flammability
UL94 V2
Material Data - Edge Clip
Material
T50ROSEC4A - the cable bundle runs parallel with
the edge.
Color
Min. Tensile
Strength
Article No.
Part No.
Type
Panel Thickness, — .039″″ - .117″″ (1-3mm)
lbs.
(N)
Black
Operating
Temperature
Flammability
UL94 HB
Max. Ø
Bundle
Length (L)
in.
(mm)
in.
(mm)
Pkg. Qty.
T30REC4A
30 lbs
(135)
5.9″
(150)
1.3″
(33)
500
T50SOSEC4A
50 lbs
(225)
5.9″
(150)
1.2″
(31)
500
T50REC4A
50 lbs
(225)
8″
(202)
1.8″
(45)
500
T50ROSEC4A
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
T30REC4B
50 lbs
(135)
5.9″
(150)
1.3″
(33)
500
156-00109 *
T50SOSEC4B
50 lbs
(225)
6.5″
(165)
1.2″
(31)
500
150-76079
150-76079 *
T50ROSEC4B
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
150-40593
150-40593 *
T50SOSEC5A
50 lbs
(225)
5.9″
(150)
1.2″
(31)
500
150-40592
150-40592
T50REC5A
50 lbs
(225)
8″
(202)
1.8″
(45)
500
150-40591
150-40591
T50ROSEC5A
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
156-01007
156-01007
T50RDHEC5A
50 lbs
(225)
8.3″
(210)
1.8″
(45)
500
156-05000
156-05000
T30REC5B
30 lbs
(135)
5.9″
(150)
1.3″
(33)
500
150-40583
150-40583 *
T50SOSEC5B
50 lbs
(225)
5.9″
(150)
1.2″
(31)
500
150-40582
150-40582
T50REC5B
50 lbs
(225)
8″
(202)
1.8″
(45)
500
150-40581
150-40581 *
T50ROSEC5B
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
150-76090
150-76090
150-76093
150-76093 *
150-76091
150-76091
150-76099
150-76099 *
150-76080
150-76080
156-00109
Drawing
Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes.
* outside serrated cable tie
51
Fasteners
Two Piece Edge Clip and Cable Tie Assemblies (continued)
Material
Color
Black
Operating
Temperature
Flammability
UL94 V2
Material
Color
Min. Tensile
Strength
Article No.
Part No.
Type
lbs.
(N)
Black
Operating
Temperature
Flammability
UL94 HB
Max. Ø
Bundle
Length (L)
in.
(mm)
in.
(mm)
Pkg. Qty.
T18REC9
18 lbs
(80)
3.9″
(100)
.75″
(19)
500
T50SOSEC9SD
50 lbs
(225)
5.9″
(150)
1.2″
(31)
500
156-05903
T50ROSEC9
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
155-38304
155-38304
T18R-EC10
18 lbs
(80)
3.9″
(100)
.79″
(20)
500
156-05904
156-05904 *
T50ROSEC10
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
156-00017
156-00017
T50SOSEC21
50 lbs
(225)
5.9″
(150)
1.3″
(33)
500
156-00010
156-00010
T50ROSEC21
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
156-00018
156-00018
T50SOSEC22
50 lbs
(225)
5.9″
(150)
1.3″
(33)
500
156-00011
156-00011
T50ROSEC22
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
156-01601
156-01601
CBTO-50R
50 lbs
(225)
8″
(202)
1.85″
(47)
500
155-37104
155-37104
156-00019
156-00019 *
156-05903
Drawing
52
Fasteners
Article No.
Part No.
Type
Panel Thickness — .117″″ - .234″″ (3-6 mm)
Min. Tensile
Strength
Length (L)
lbs.
(N)
in.
(mm)
in.
(mm)
Pkg. Qty.
Max. Ø Bundle
156-04600 156-04600
T18ROSEC19
18 lbs
(80)
3.9″
(100)
.79″
(20)
500
156-04601 156-04601
T50SOSEC19
50 lbs
(225)
5.9″
(150)
1.2″
(31)
500
156-04602 156-04602
T50ROSEC19
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
156-00016 156-00016
T50SOSEC20
50 lbs
(225)
5.9″
(150)
1.3″
(33)
500
156-00020 156-00020
T50ROSEC20
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
156-00006 156-00006
T50ROSEC23
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
156-00007 156-00007
T50ROSEC24
50 lbs
(225)
7.9″
(200)
1.8″
(45)
500
Drawing
One Piece Edge Clip and Cable
Tie Combinations
Material Data
Material
Color
The plastic area of the edge clips and the cable
ties are molded together.
Black
Operating
Temperature
Flammability
UL94 HB
Length (L)
Max. Ø
Bundle
Product Selection
Min. Tensile
Strength
Article No.
Part No.
Type
Panel Thickness — .039″″ - .117″″ (1-3 mm)
lbs.
(N)
in.
(mm)
in.
(mm)
Pkg. Qty.
133-00059 133-00059
T40XEC5SP-E
40 lbs
(178)
4.05″
(103)
.59″
(15)
500
148-00200 148-00200
T50SOSEC12E
50 lbs
(225)
6.30″
(160)
1.38″
(35)
500
126-00000 126-00000
T50SOSEC13E
50 lbs
(225)
6.30″
(160)
1.38″
(35)
500
Drawing
53
Fasteners
Edge Clip and Tape Clip Combination
These clips can be secured to cables with cable ties or tape.
Material Data - Cable Tie and Tape Clip Combination
Material
Color
Black
Operating
Temperature
Flammability
UL94 HB
Product Selection
Article No.
Part No.
Type
Length (L)
Width (W)
in.
in.
(mm)
(mm)
Pkg. Qty.
151-03404
151-03404
EC14
1.57″ (40.0)
.39″ (10.0)
500
151-03401
151-03401
EC15
1.57″ (40.0)
.39″ (10.0)
500
151-03402
151-03402
EC16
1.57″ (40.0)
.39″ (10.0)
500
151-03403
151-03403
EC17
1.57″ (40.0)
.39″ (10.0)
500
Drawing
54
Fasteners
Screw Mount Ties
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
File# E64139
Product Selection
Article No.
T18MR
Part No.
Type
Mounting
Min. Tensile
Strength
lbs.
(N)
Length (L)
in.
(mm)
Max. Ø Bundle
in. (mm)
Width (W)
in. (mm)
Color
Pkg.
Qty.
113-00026 T18MR9C2
T18MR
18 lbs
(80)
4.33″
(110)
.79″
(20)
.10″
(2.5)
Natural
100
113-00028 T18MR9M4
T18MR
18 lbs
(80)
4.33″
(110)
.79″
(20)
.10″
(2.5)
Natural
1000
113-00022 T18MR0C2
T18MR
18 lbs
(80)
4.33″
(110)
.79″
(20)
.10″
(2.5)
Black
100
113-00024 T18MR0M4
T18MR
18 lbs
(80)
4.33″
(110)
.79″
(20)
.10″
(2.5)
Black
1000
# 4 screw
T30MR
113-03019 T30MR9C2
T30MR
30 lbs
(135)
6.30″
(160)
1.26″
(32)
.14″
(3.5)
Natural
100
113-00036 T30MR9M4
T30MR
30 lbs
(135)
6.30″
(160)
1.26″
(32)
.14″
(3.5)
Natural
1000
113-03010 T30MR0C2
T30MR
113-03011 T30MR0M4
T30MR
# 8 screw
30 lbs
(135)
6.30″
(160)
1.26″
(32)
.14″
(3.5)
Black
100
30 lbs
(135)
6.30″
(160)
1.26″
(32)
.14″
(3.5)
Black
1000
T50MR
113-05004 T50MR9C2
T50MR
48 lbs
(215)
8.46″
(215)
1.77″
(45)
.18″
(4.6)
Natural
100
113-05007 T50MR9M4
T50MR
48 lbs
(215)
8.46″
(215)
1.77″
(45)
.18″
(4.6)
Natural
1000
113-05000 T50MR0C2
T50MR
113-05002 T50MR0M4
T50MR
# 10 screw
48 lbs
(215)
8.46″
(215)
1.77″
(45)
.18″
(4.6)
Black
100
48 lbs
(215)
8.46″
(215)
1.77″
(45)
.18″
(4.6)
Black
1000
T50MRT
50 lbs
(225)
8.47″
(215)
1.77″
(45)
.19″
(4.7)
Natural
100
113-05102 T50MRT9M4 T50MRT
50 lbs
(225)
8.47″
(215)
1.77″
(45)
.19″
(4.7)
Natural
1000
T50MRT
113-05101 T50MRT9C2
113-05100 T50MRT0C2
T50MRT
#6-32 tap
thru screw
113-00037 T50MRT0M4 T50MRT
50 lbs
(225)
8.47″
(215)
1.77″
(45)
.19″
(4.7)
Black
100
50 lbs
(225)
8.47″
(215)
1.77″
(45)
.19″
(4.7)
Black
1000
T50MI
113-00032 T50MI9C2
T50MI
50 lbs
(225)
12.40″
(315)
3.35″
(85)
.19″
(4.7)
Natural
100
113-00033 T50MI9M4
T50MI
50 lbs
(225)
12.40″
(315)
3.35″
(85)
.19″
(4.7)
Natural
1000
113-00038 T50MI0C2
T50MI
50 lbs
(225)
12.40″
(315)
3.35″
(85)
.19″
(4.7)
Black
100
113-00031 T50MI0M4
T50MI
50 lbs
(225)
12.40″
(315)
3.35″
(85)
.19″
(4.7)
Black
1000
# 10 screw
T50ML
113-05419 T50ML9C2
T50ML
50 lbs
(225)
15.35″
(390)
4.00″
(100)
.18″
(4.6)
Natural
100
113-05403 T50ML9M4
T50ML
50 lbs
(225)
15.35″
(390)
4.00″
(100)
.18″
(4.6)
Natural
1000
113-00007 T50ML0C2
T50ML
50 lbs
(225)
15.35″
(390)
4.00″
(100)
.18″
(4.6)
Black
100
113-00035 T50ML0M4
T50ML
50 lbs
(225)
15.35″
(390)
4.00″
(100)
.18″
(4.6)
Black
1000
# 10 screw
T120MR
113-12029 T120MR9K2
T120MR
113-00018 T120MR9H4
T120MR
113-12020 T120MR0K2
T120MR
113-00011 T120MR0H4
T120MR
#1/4″
screw
120 lbs
(535)
15.55″
(395)
4.02″
(102)
.30″
(7.6)
Natural
50
120 lbs
(535)
15.55″
(395)
4.02″
(102)
.30″
(7.6)
Natural
500
120 lbs
(535)
15.55″
(395)
4.02″
(102)
.30″
(7.6)
Black
50
120 lbs
(535)
15.55″
(395)
4.02″
(102)
.30″
(7.6)
Black
500
55
Fasteners
Clamp Ties
The clamp tie has triangular shaped tabs extending beneath the head, allowing for optimal surface contact and complete
circumferential compression to 360 degrees. The clamps are recommended for soft rubber hose applications including fuel,
water, and air vacuum lines.
Material Data
Color
Natural
Material
Operating
Temperature
Flammability
UL94 V2
Material Data
Color
Black
Material
Operating
Temperature
Flammability
UL94 V2
File# E64139
Product Selection
Min. Tensile
Strength
Article No.
CTT20R
Part No.
Type
lbs.
(N)
Length (L)
in.
Max. Ø Bundle
(mm)
in.
(mm)
Width (W)
in.
(mm)
112-51919
CTT20R9C2
CTT20R
20 lbs
(90)
4″
(100)
.50″
(13)
.10″
(2.5)
112-51904
CTT20R9M4
CTT20R
20 lbs
(90)
4″
(100)
.50″
(13)
.10″
(2.5)
112-51905
CTT20R0HSC2
CTT20R
20 lbs
(90)
4″
(100)
.50″
(13)
.10″
(2.5)
112-51960
CTT20R0HSM4 CTT20R
20 lbs
(90)
4″
(100)
.50″
(13)
.10″
(2.5)
Color
Natural
Black
Pkg. Qty.
100
1000
100
1000
CTT60R
112-52104
CTT60R9C2
CTT60R
60 lbs
(265)
8″
(205)
1.77″
(45)
.19″
(4.7)
112-52106
CTT60R9M4
CTT60R
60 lbs
(265)
8″
(205)
1.77″
(45)
.19″
(4.7)
112-52112
CTT60R0HSC2
CTT60R
60 lbs
(265)
8″
(205)
1.77″
(45)
.19″
(4.7)
112-52114
CTT60R0HSM4 CTT60R
60 lbs
(265)
8″
(205)
1.77″
(45)
.19″
(4.7)
Natural
Black
100
1000
100
1000
56
Fasteners
Branch Tie
The Branch Tie is ideal for wire harness applications where wires
“branch” away from the main assembly. The Branch tie reduces
wire harness assembly time by eliminating the need to use
electrical tape. After the tie is placed on the main assembly, the
strap is inserted through the oval opening and then through the
cable tie head. Once applied, the Branch Tie holds the branch in
its proper position on the wire harness.
Material Data
Material
Operating
Temperature
-40 °F to +185 °F
Flammability
UL94 V2
L
W
Product Selection
Main Bundle Ø
Article No.
Part No.
115-00042 115-00042
Type
YT200
in.
Branch Bundle Ø
(mm)
.63″ − 1.57″
in.
(mm)
(16 - 40) .59″ − 1.18″ (15 - 30)
Min. Tensile
Strength
lbs.
(N)
33 lbs (147)
Length (L)
Width (W)
in.
in.
(mm)
7.87″ (200) .18″
(mm)
Color
Pkg.
Qty.
(4.7)
Black
100
Kabelrap Bundling System
The patented Kabelrap bundling system offers a very high bundling strength and is particularly resistant to saltwater,
oils, greases, and hydraulic fluids. Special hand tool required for installation.
Material Data
Material
Required Tool - 121-00680
Polyamide 6.6 UV-resistant (PA66UV)
Operating
Temperature
Flammability
UL94 V2
Kabelrap Application
W
Product Selection
Type
lbs.
(N)
Length (L)
in.
Max. Ø Bundle
Width (W)
Article No.
Part No.
(mm)
in.
(mm)
in.
(mm)
Color
Pkg. Qty.
121-61860
121-61860
KR6/18
110 lbs
(490)
7.25″
(183)
1.5″
(39)
.24″
(6)
Black
50
121-63560
121-63560
KR6/35
110 lbs
(490)
14″
(356)
3.75″
(93)
.25″
(6)
Black
50
121-82160
121-82160
KR8/21
175 lbs
(785)
8.25″
(210)
1.75″
(47)
.31″
(8)
Black
50
121-83360
121-83360
KR8/33
175 lbs
(785)
13.25″
(337)
3.37″
(86)
.31″
(8)
Black
50
Required Installation Tool - 121-00680. Black is the standard color. Natural is available based upon minimums, custom terms and lead times.
57
Fasteners
Standard Cable Ties
T18 - T30 Series - Natural and Black
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
File# E64139
Product Selection
Min. Tensile
Strength
Length (L)
Max. Ø
Bundle
lbs.
(N)
in.
(mm)
in.
Width (W)
Type
US Gov.
Designation
111-02805 T18S9C2
T18S
MS3367-4-9
18 lbs
(80)
3.27″
(83)
.63″
(16)
.09″
(2.3)
111-02809 T18S9M4
T18S
MS3367-4-9
18 lbs
(80)
3.27″
(83)
.63″
(16)
.09″
(2.3)
111-02810 T18S0C2
T18S
18 lbs
(80)
3.27″
(83)
.63″
(16)
.09″
(2.3)
111-02811 T18S0M4
T18S
18 lbs
(80)
3.27″
(83)
.63″
(16)
.09″
(2.3)
112-01819 T18R9C2
T18R
MS3367-4-9
18 lbs
(80)
4″
(100)
.87″
(22)
.10″
(2.5)
111-01872 T18R9M4
T18R
MS3367-4-9
18 lbs
(80)
4″
(100)
.87″
(22)
.10″
(2.5)
111-00405 T18R0C2
T18R
18 lbs
(80)
4″
(100)
.87″
(22)
.10″
(2.5)
111-01841 T18R0M4
T18R
18 lbs
(80)
4″
(100)
.87″
(22)
.10″
(2.5)
111-02311 T18I9C2
T18I
18 lbs
(80)
5.51″
(140)
1.38″
(35)
.10″
(2.5)
111-02322 T18I9M4
T18I
18 lbs
(80)
5.51″
(140)
1.38″
(35)
.10″
(2.5)
111-02308 T18I0C2
T18I
18 lbs
(80)
5.51″
(140)
1.38″
(35)
.10″
(2.5)
111-02315 T18I0M4
T18I
18 lbs
(80)
5.51″
(140)
1.38″
(35)
.10″
(2.5)
111-02189 T18L9C2
T18L
18 lbs
(80)
8.0″
(205)
2.17″
(55)
.10″
(2.5)
111-02026 T18L9M4
T18L
18 lbs
(80)
8.0″
(205)
2.17″
(55)
.10″
(2.5)
111-00401 T18L0C2
T18L
18 lbs
(80)
8.0″
(205)
2.17″
(55)
.10″
(2.5)
111-02015 T18L0M4
T18L
18 lbs
(80)
8.0″
(205)
2.17″
(55)
.10″
(2.5)
112-03019 T30R9C2
T30R
MS3367-5-9
30 lbs
(135)
5.9″
(150)
1.38″
(35)
.14″
(3.5)
111-03047 T30R9M4
T30R
MS3367-5-9
30 lbs
(135)
5.9″
(150)
1.38″
(35)
.14″
(3.5)
111-00438 T30R0C2
T30R
30 lbs
(135)
5.9″
(150)
1.38″
(35)
.14″
(3.5)
111-03034 T30R0M4
T30R
30 lbs
(135)
5.9″
(150)
1.38″
(35)
.14″
(3.5)
111-03325 T30L9C2
T30L
30 lbs
(135)
7.48″
(190)
1.97″
(50)
.14″
(3.5)
111-03327 T30L9M4
T30L
30 lbs
(135)
7.48″
(190)
1.97″
(50)
.14″
(3.5)
111-03313 T30L0C2
T30L
30 lbs
(135)
7.48″
(190)
1.97″
(50)
.14″
(3.5)
111-03315 T30L0M4
T30L
30 lbs
(135)
7.48″
(190)
1.97″
(50)
.14″
(3.5)
Article No.
T18S
Part No.
(mm)
File# E64139
in. (mm)
Color
Natural
Black
Pkg. Qty.
100
1000
100
1000
T18R
Natural
Black
100
1000
100
1000
T18I
Natural
Black
100
1000
100
1000
T18L
Natural
Black
100
1000
100
1000
T30R
Natural
Black
100
1000
100
1000
T30L
Natural
Black
100
1000
100
1000
T30LL
T30LL
30 lbs
(135)
11.42″
(290)
3.15″
(80)
.14″
(3.5)
111-03517 T30LL9M4 T30LL
30 lbs
(135)
11.42″
(290)
3.15″
(80)
.14″
(3.5)
111-03501 T30LL0C2
T30LL
30 lbs
(135)
11.42″
(290)
3.15″
(80)
.14″
(3.5)
111-03511 T30LL0M4 T30LL
30 lbs
(135)
11.42″
(290)
3.15″
(80)
.14″
(3.5)
111-02900 T30XL9C2 T30XL
MS3367-5-9
30 lbs
(135)
14.37″
(365)
4.13″
(105)
.14″
(3.5)
111-02907 T30XL9M4 T30XL
MS3367-5-9
30 lbs
(135)
14.37″
(365)
4.13″
(105)
.14″
(3.5)
111-02901 T30XL0C2 T30XL
30 lbs
(135)
14.37″
(365)
4.13″
(105)
.14″
(3.5)
111-02903 T30XL0M4 T30XL
30 lbs
(135)
14.37″
(365)
4.13″
(105)
.14″
(3.5)
111-03515 T30LL9C2
Natural
Black
100
1000
100
1000
T30XL
Natural
Black
Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. MK9 and MK9P cannot be used with T18S cable ties.
* Military black available. Contact HellermannTyton for more information.
58
100
1000
100
1000
Fasteners
Standard Cable Ties
T40 - T50 Series - Natural and Black
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
File# E64139
Product Selection
US Gov.
Designation
Min. Tensile
Strength
Length (L)
lbs.
in.
(mm)
in.
(mm)
112-04019 T40R9C2 T40R(U)
40 lbs
(180)
8.27″
(210)
2.16″
(55)
.16″
(4.0)
111-04131 T40R9M4 T40R(U)
40 lbs
(180)
8.27″
(210)
2.16″
(55)
.16″
(4.0)
112-04060 T40R0C2 T40R(U)
40 lbs
(180)
8.27″
(210)
2.16″
(55)
.16″
(4.0)
111-04122 T40R0M4 T40R(U)
40 lbs
(180)
8.27″
(210)
2.16″
(55)
.16″
(4.0)
Article No. Part No.
T40R
Type
(N)
Max. Ø
Bundle
File# E64139
Width (W)
in.
(mm)
Color
Natural
Black
Pkg. Qty.
100
1000
100
1000
T40I
111-04609 T40I9C2
T40I
40 lbs
(180)
11.42″
(290)
3.15″
(80)
.16″
(4.0)
111-04612 T40I9M4
T40I
40 lbs
(180)
11.42″
(290)
3.15″
(80)
.16″
(4.0)
111-04600 T40I0C2
T40I
40 lbs
(180)
11.42″
(290)
3.15″
(80)
.16″
(4.0)
111-04604 T40I0M4
T40I
40 lbs
(180)
11.42″
(290)
3.15″
(80)
.16″
(4.0)
111-04300 T40L9C2
T40L
40 lbs
(180)
14.4″
(365)
4.13″
(105)
.16″
(4.0)
111-04311 T40L9M4
T40L
40 lbs
(180)
14.4″
(365)
4.13″
(105)
.16″
(4.0)
111-04301 T40L0C2
T40L
40 lbs
(180)
14.4″
(365)
4.13″
(105)
.16″
(4.0)
111-04305 T40L0M4
T40L
40 lbs
(180)
14.4″
(365)
4.13″
(105)
.16″
(4.0)
111-05811 T50S9C2
T50S
50 lbs
(225)
5.9″
(150)
1.38″
(35)
.18″
(4.6)
111-05813 T50S9M4
T50S
50 lbs
(225)
5.9″
(150)
1.38″
(35)
.18″
(4.6)
111-05806 T50S0C2
T50S
50 lbs
(225)
5.9″
(150)
1.38″
(35)
.18″
(4.6)
111-05808 T50S0M4
T50S
50 lbs
(225)
5.9″
(150)
1.38″
(35)
.18″
(4.6)
112-05019 T50R9C2
T50R
MS3367-1-9
50 lbs
(225)
7.9″
(200)
1.97″
(50)
.18″
(4.6)
111-04862 T50R9M4
T50R
MS3367-1-9
50 lbs
(225)
7.9″
(200)
1.97″
(50)
.18″
(4.6)
111-04878 T50R0C2
T50R
50 lbs
(225)
7.9″
(200)
1.97″
(50)
.18″
(4.6)
111-04846 T50R0M4
T50R
50 lbs
(225)
7.9″
(200)
1.97″
(50)
.18″
(4.6)
112-05219 T50I9C2
T50I
MS3367-7-9
50 lbs
(225)
11.8″
(300)
3.35″
(85)
.18″
(4.6)
111-05230 T50I9M4
T50I
MS3367-7-9
50 lbs
(225)
11.8″
(300)
3.35″
(85)
.18″
(4.6)
111-00444 T50I0C2
T50I
50 lbs
(225)
11.8″
(300)
3.35″
(85)
.18″
(4.6)
111-05216 T50I0M4
T50I
50 lbs
(225)
11.8″
(300)
3.35″
(85)
.18″
(4.6)
112-05419 T50L9C2
T50L
MS3367-2-9
50 lbs
(225)
15.35″
(390)
4.33″
(110)
.18″
(4.6)
111-05449 T50L9M4
T50L
MS3367-2-9
50 lbs
(225)
15.35″
(390)
4.33″
(110)
.18″
(4.6)
111-00445 T50L0C2
T50L
50 lbs
(225)
15.35″
(390)
4.33″
(110)
.18″
(4.6)
111-00504 T50L0M4
T50L
50 lbs
(225)
15.35″
(390)
4.33″
(110)
.18″
(4.6)
Natural
Black
100
1000
100
1000
T40L
Natural
Black
100
1000
100
1000
T50S
Natural
Black
100
1000
100
1000
T50R
Natural
Black
100
1000
100
1000
T50I
Natural
Black
100
1000
100
1000
T50L
Natural
Black
100
1000
100
1000
59
Fasteners
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
T120 Series
File# E64139
Product Selection
Article No.
T120S
Part No.
Type
Min. Tensile
Strength
US Gov.
Designation
lbs.
Length (L)
(N)
Max. Ø Bundle
in.
(mm)
in.
File# E64139
Width (W)
(mm)
in. (mm)
111-12819 T120S9K2 T120S
120 lbs
(535)
8.85″
(225)
2.17″
(55)
.30″
(7.6)
111-12813 T120S9H4 T120S
120 lbs
(535)
8.85″
(225)
2.17″
(55)
.30″
(7.6)
111-12803 T120S0K2 T120S
120 lbs
(535)
8.85″
(225)
2.17″
(55)
.30″
(7.6)
111-12808 T120S0H4 T120S
120 lbs
(535)
8.85″
(225)
2.17″
(55)
.30″
(7.6)
Color
Pkg. Qty.
50
Natural
500
50
Black
500
T120I
111-12211 T120I9K2
T120I
120 lbs
(535)
11.81″
(300)
3.15″
(80)
.30″
(7.6)
111-12213 T120I9H4
T120I
120 lbs
(535)
11.81″
(300)
3.15″
(80)
.30″
(7.6)
111-12201 T120I0K2
T120I
120 lbs
(535)
11.81″
(300)
3.15″
(80)
.30″
(7.6)
111-12206 T120I0H4
T120I
120 lbs
(535)
11.81″
(300)
3.15″
(80)
.30″
(7.6)
50
Natural
500
50
Black
500
T120R
112-12019 T120R9K2 T120R MS3367-3-9
120 lbs
(535)
15.24″
(387)
4.13″
(105)
.30″
(7.6)
111-12036 T120R9H4 T120R MS3367-3-9
120 lbs
(535)
15.24″
(387)
4.13″
(105)
.30″
(7.6)
112-12060 T120R0K2 T120R
120 lbs
(535)
15.24″
(390)
4.13″
(105)
30″
(7.6)
111-12013 T120R0H4 T120R
120 lbs
(535)
15.24″
(387)
4.13″
(105)
.30″
(7.6)
50
Natural
500
50
Black
500
T120L
111-12419 T120L9K2
T120L MS3367-6-9
120 lbs
(535)
30.0″
(760)
8.85″
(225)
.30″
(7.6)
Natural
50
111-12405 T120L0K2
T120L
120 lbs
(535)
30.0″
(760)
8.85″
(225)
.30″
(7.6)
Black
50
purposes. *Military black available. Contact HellermannTyton for more information.
T150 Series
File# E64139
Product Selection
Min. Tensile
Strength
Type
US Gov.
Designation
111-15203 T150R9X2
T150R(U)
175 lbs
111-15200 T150R0X2
T150R(U)
175 lbs
111-15619 T150M9X2
T150M
111-00124 T150M0X2
T150M
111-15419 T150L9X2
T150L
111-15405 T150L0X2
T150L
111-15719 T150LL9X2
111-15700 T150LL0X2
Article No.
T150R
Part No.
lbs.
(N)
Length (L)
Max. Ø Bundle
Width (W)
(mm)
Color
Pkg.
Qty.
in.
(mm)
in.
(mm)
in.
(780)
15.35″
(390)
4.13″
(105)
.35″
(8.8)
Natural
25
(780)
15.35″
(390)
4.13″
(105)
.35″
(8.8)
Black
25
175 lbs
(780)
21.00″
(530)
5.91″
(150)
.35″
(8.9)
Natural
25
175 lbs
(780)
21.00″
(530)
5.91″
(150)
.35″
(8.9)
Black
25
175 lbs
(780)
32.28″
(820)
9.65″
(245)
.35″
(8.9)
Natural
25
175 lbs
(780)
32.28″
(820)
9.65″
(245)
.35″
(8.9)
Black
25
T150LL
175 lbs
(780)
36.42″
(925)
10.83″
(275)
.35″
(8.9)
Natural
25
T150LL
175 lbs
(780)
36.42″
(925)
10.83″
(275)
.35″
(8.9)
Black
25
111-15519 T150XL9X2
T150XL
175 lbs
(780)
43.11″ (1095)
13.00″
(330)
.35″
(8.9)
Natural
25
111-15500 T150XL0X2
T150XL
175 lbs
(780)
43.11″ (1095)
13.00″
(330)
.35″
(8.9)
Black
25
111-15304 T150XLL9X2 T150XLL
175 lbs
(780)
52.17″ (1325)
15.95″
(405)
.35″
(8.9)
Natural
25
111-15300 T150XLL0X2 T150XLL
175 lbs
(780)
52.17″ (1325)
15.95″
(405)
.35″
(8.9)
Black
25
T150M
T150L
T150LL
T150XL
T150XLL
purposes.
60
Fasteners
Standard Cable Ties- Specialty Materials
T18 - T120 Series - Heat Stabilized
HellermannTyton's heat stabilized cable ties provide excellent resistance when exposed to high heat applications.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
File# E64139
File# E64139
Product Selection
Article No.
T18S
Part No.
Type
lbs.
111-02815
T18S0HSM4
T18S
18 lbs
111-01905
T18R0HSC2
T18R
111-00476
T18R0HSM4
T18R
T18I0HSM4
111-00403
111-00404
(N)
Length (L)
Max. Ø Bundle
in.
(mm)
in.
(mm)
(80)
3.27″
(83)
.63″
(16)
18 lbs
(80)
4″
(100)
.87″
18 lbs
(80)
4″
(100)
.87″
T18I
18 lbs
(80)
5.5″
(140)
T18L0HSC2
T18L
18 lbs
(80)
8.0″
T18L0HSM4
T18L
18 lbs
(80)
8.0″
111-03067
T30R0HSC2
T30R
30 lbs
(135)
111-03068
T30R0HSM4
T30R
30 lbs
(135)
111-04900
T50R0HSC2
T50R
50 lbs
111-04901
T50R0HSM4
T50R
50 lbs
111-05248
T50I0HSC2
T50I
111-05251
T50I0HSM4
T50I
111-05470
T50L0HSC2
111-05471
T50L0HSM4
111-12061
111-12058
Width (W)
in.
(mm)
Color
Pkg. Qty.
.09″
(2.3)
Black
1000
(22)
.10″
(2.5)
Black
100
(22)
.10″
(2.5)
Black
1000
1.38″
(35)
.10″
(2.5)
Black
1000
(205)
2.17″
(55)
.10″
(2.5)
Black
100
(205)
2.17″
(55)
.10″
(2.5)
Black
1000
5.9″
(150)
1.38″
(35)
.14″
(3.5)
Black
100
5.9″
(150)
1.38″
(35)
.14″
(3.5)
Black
1000
(225)
7.9″
(200)
1.97″
(50)
.18″
(4.6)
Black
100
(225)
7.9″
(200)
1.97″
(50)
.18″
(4.6)
Black
1000
50 lbs
(225)
11.8″
(300)
3.35″
(85)
.18″
(4.6)
Black
100
50 lbs
(225)
11.8″
(300)
3.35″
(85)
.18″
(4.6)
Black
1000
T50L
50 lbs
(225)
15.35″
(390)
4.33″
(110)
.18″
(4.6)
Black
100
T50L
50 lbs
(225)
15.35″
(390)
4.33″
(110)
.18″
(4.6)
Black
1000
T120R0HSK2
T120R
120 lbs
(535)
15.24″
(387)
4.13″
(105)
.30″
(7.6)
Black
50
T120R0HSH4
T120R
120 lbs
(535)
15.24″
(387)
4.13″
(105)
.30″
(7.6)
Black
500
T18R
T18I
111-02305
T18L
T30R
T50R
T50I
T50L
T120R
Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. MK9, MK9HT, and MK9P tools cannot be used with T18S cable ties.
61
Fasteners
T18 -T50 Series - Flame Retardant
HellermannTyton's flame retardant cable ties meet the UL 94V0 flammability requirements.
Material Data
Material
Polyamide 6.6 V0 (PA66V0)
Operating
Temperature
Flammability
UL94 V0
File# E64139
Product Selection
Article No.
T18R
Part No.
Type
lbs.
(N)
Length (L)
in.
Max. Ø Bundle
(mm)
File# E64139
Width (W)
in.
(mm)
in.
(mm)
Color
Pkg. Qty.
111-01834
T18R9VOC2
T18R
18 lbs
(80)
4″
(100)
.87″
(22)
.10″
(2.5)
White
100
111-01835
T18R9VOM4
T18R
18 lbs
(80)
4″
(100)
.87″
(22)
.10″
(2.5)
White
1000
111-01833
T18R0VOC2
T18R
18 lbs
(80)
4″
(100)
.87″
(22)
.10″
(2.5)
Black
100
T18I9VOM4
T18I
18 lbs
(80)
5.5″
(144)
1.38″
(35)
.10″
(2.5)
White
1000
111-02045
T18L9VOC2
T18L
18 lbs
(80)
7.95″
(202)
2.17″
(55)
.10″
(2.5)
White
100
111-02046
T18L9VOM4
T18L
18 lbs
(80)
7.95″
(202)
2.17″
(55)
.10″
(2.5)
White
1000
111-02044
T18L0VOC2
T18L
18 lbs
(80)
7.95″
(202)
2.17″
(55)
.10″
(2.5)
Black
100
111-03073
T30R9VOC2
T30R
30 lbs
(135)
5.83″
(148)
1.38″
(35)
.14″
(3.6)
White
100
111-03074
T30R9VOM4
T30R
30 lbs
(135)
5.83″
(148)
1.38″
(35)
.14″
(3.6)
White
1000
111-03072
T30R0VOC2
T30R
30 lbs
(135)
5.83″
(148)
1.38″
(35)
.14″
(3.6)
Black
100
111-04909
T50R9VOC2
T50R
50 lbs
(225)
7.95″
(202)
1.97″
(50)
.18″
(4.6)
White
100
111-04911
T50R9VOM4
T50R
50 lbs
(225)
7.95″
(202)
1.97″
(50)
.18″
(4.6)
White
1000
111-04887
T50R0VOC2
T50R
50 lbs
(225)
7.95″
(202)
1.97″
(50)
.18″
(4.6)
Black
100
111-04908
T50R0VOM4
T50R
50 lbs
(225)
7.95″
(202)
1.97″
(50)
.18″
(4.6)
Black
1000
111-05254
T50I9VOC2
T50I
50 lbs
(225)
11.82″
(300)
3.35″
(85)
.18″
(4.6)
White
100
111-05255
T50I9VOM4
T50I
50 lbs
(225)
11.82″
(300)
3.35″
(85)
.18″
(4.6)
White
1000
111-05258
T50I0VOC2
T50I
50 lbs
(225)
11.82″
(300)
3.35″
(85)
.18″
(4.6)
Black
100
111-05438
T50L9VOC2
T50L
50 lbs
(225)
15.35″
(390)
4.33″
(110)
.19″
(4.7)
White
100
111-05476
T50L9VOM4
T50L
50 lbs
(225)
15.35″
(390)
4.33″
(110)
.19″
(4.7)
White
1000
111-05475
T50L0VOC2
T50L
50 lbs
(225)
15.35″
(390)
4.33″
(110)
.19″
(4.7)
Black
100
T18I
111-02304
T18L
T30R
T50R
T50I
T50L
62
Fasteners
T18 - T120 Series - Polypropylene
HellermannTyton's polypropylene cable ties offer added resistance to most chemicals.
Material Data
Material
Polypropylene (PP)
Operating
Temperature
-40 °F to +239 °F (-40 °C to +115 °C) continuous
Flammability
UL94 HB
Product Selection
Min. Tensile
Strength
Article No.
T18R
Part No.
Type
lbs.
(N)
Length (L)
in.
Max. Ø Bundle
(mm)
in.
(mm)
Width (W)
in. (mm)
Color
Pkg. Qty.
111-01921
T18R9PPC2
T18R
11 lbs
(49)
4″
(100)
.75″
(19)
.10″
(2.5)
Natural
100
111-01922
T18R9PPM4
T18R
11 lbs
(49)
4″
(100)
.75″
(19)
.10″
(2.5)
Natural
1000
111-01917
T18R0PPC2
T18R
11 lbs
(49)
4″
(100)
.75″
(19)
.10″
(2.5)
Black
100
111-01918
T18R0PPM4
T18R
11 lbs
(49)
4″
(100)
.75″
(19)
.10″
(2.5)
Black
1000
T30R9PPC2
T30R
20 lbs
(89)
5.83″
(148)
1.26″
(32)
.14″
(3.6)
Natural
100
111-04931
T50R9PPC2
T50R
30 lbs
(133)
8.0″
(203.8)
1.75″
(44.5)
.19″
(4.7)
Natural
100
111-04928
T50R0PPC2
T50R
30 lbs
(133)
8.0″
(203.8)
1.75″
(44.5)
.19″
(4.7)
Black
100
111-04929
T50R0PPM4
T50R
30 lbs
(133)
8.0″
(203.8)
1.75″
(44.5)
.19″
(4.7)
Black
1000
T50I9PPM4
T50I
30 lbs
(133)
11.8″
(300)
3.35″
(85)
.18″
(4.6)
Natural
1000
111-05483
T50L9PPM4
T50L
30 lbs
(133)
15.35″
(390)
4.33″
(110)
.18″
(4.7)
Natural
1000
111-05482
T50L0PPC2
T50L
30 lbs
(133)
15.35″
(390)
4.33″
(110)
.18″
(4.7)
Black
100
T30R
111-03017
T50R
T50I
111-05262
T50L
T120R
111-12067
T120R0PPK2
T120R
60 lbs
(267)
15.35″
(390)
4.13″
(105)
.30″
(7.6)
Black
50
111-12066
T120R0PPH4
T120R
60 lbs
(267)
15.35″
(390)
4.13″
(105)
.30″
(7.6)
Black
500
63
Fasteners
PEEK Ties For High
Temperature Applications
HellermannTyton’s high performance PEEK cable ties
withstand temperatures up to +500°F (+260°C).
PEEK ties are also highly resistant to chemicals and
abrasion. PEEK ties offer a tensile strength of 52 lbs.
with the minimal insertion force of 1 lb. The
contoured head makes the tie ideal for space
restricted areas and the outside serrations minimize
any damage to the cable insulation.
The contoured head takes up less space, gives a low insertion force, and offers high strength.
Material Data
Material
Polyetheretherketone (PEEK)
Operating
Temperature
-67 °F to +500 °F (-55 °C to +260 °C)
continuous
Flammability
UL94 V0
The head design of PEEK Ties
Product Selection
Article No.
Part No.
118-00032 118-00032
Length (L)
Width (W)
Min. Ø
Bundle
Max. Ø
Bundle
Min. Tensile
Strength
Type
lbs. (N)
lbs. (N)
lbs. (N)
lbs. (N)
lbs. (N)
Color
Pkg. Qty.
PT2A
5.7
(145)
.13
(3.4)
.06
(1.6)
1.38
(35)
52 lbs
(230)
Brown
100
Installation tools - MK7, MK7P. Use Part No. for ordering and Type for specification purposes.
64
Fasteners
Tefzel® Cable Ties
Tefzel ties provide excellent protection against radiation, ultraviolet light, and a wide range of chemicals. They are also rated
for low outgassing applications. HellermannTyton’s Tefzel ties come in a standard color of blue for easy identification.
Material Data
Material
Ethylenterafluorineethylene Tefzel (E/TFE)
Operating
Temperature
-112 °F to +302 °F
(-80 °C to +150 °C) continuous
Flammability
UL94 V0
Product Selection
Article No.
Part No.
Length (L)
(N)
in.
Max. Ø Bundle
(mm)
Width (W)
Type
lbs.
in.
(mm)
in.
(mm)
Color
111-01923
T18R6TZC2
T18R(U)
9.0 lbs
(40)
4″
(100)
.87″
(22)
.10″
(2.5)
Blue
Pkg. Qty.
100
111-01924
T18R6TZM4
T18R(U)
9.0 lbs
(40)
4″
(100)
.87″
(22)
.10″
(2.5)
Blue
1000
111-05026
T50R6TZC2
T50R(U)
35.5 lbs
(158)
8″
(200)
1.75″
(50)
.18″
(4.6)
Blue
100
111-04933
T50R6TZM4
T50R(U)
35.5 lbs
(158)
8″
(200)
1.75″
(50)
.18″
(4.6)
Blue
1000
111-12026
T120R6TZK2
T120R
70 lbs
(311)
15″
(380)
4.0″
(100)
.30″
(7.6)
Blue
50
Tefzel is a registered trademark of E.I. DuPont Corporation. Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P.
Outside Serrated Cable Ties
The outside serrated cable ties are for specific applications where thin
walled or soft insulation is used (such as in aircraft, trains, etc.) and for
applications that are very sensitive to the amount of force applied to
the cable.
Material Data
Material
Outside serrated cable ties are also available in
natural. Contact HellermannTyton for more
information.
Operating
Temperature
-40 °F to +221 °F
Flammability
UL94 V2
Product Selection
Min. Tensile
Strength
Article No.
Part No.
Type
lbs.
(N)
Length (L)
Max. Ø Bundle
Width (W)
in.
(mm)
in.
(mm)
in.
(mm)
Color
Pkg. Qty.
118-04700
118-04700
T18ROS
18 lbs
(80)
3.94″
(100)
.79″
(20)
.10″
(2.5)
Black
100
118-04800
118-04800
T30ROS
30 lbs
(135)
5.71″
(145)
1.34″
(35)
.13″
(3.4)
Black
100
118-04900
118-04900
T30LOS
30 lbs
(135)
7.87″
(200)
2.0″
(50)
.13″
(3.4)
Black
100
118-05850
118-05850
T50SOS
50 lbs
(225)
5.9″
(150)
1.38″
(35)
.18″
(4.6)
Black
100
118-05050
118-05050
T50ROS
50 lbs
(225)
8″
(200)
1.95″
(50)
.18″
(4.6)
Black
100
118-05900
118-05900
T50LOS
50 lbs
(225)
15″
(384)
4.29″
(110)
.18″
(4.6)
Black
100
65
Fasteners
Releasable Ties
The extended pawl allows for simple and quick release of
the ties. Perfect for prototype construction and service
requiring the addition of wires on existing harnesses.
Material Data
Material
Operating
Temperature
-40 °F to +185 °F
Flammability
UL94 V2
RT50S and RT50LL
RT40R
File# E64139
Product Selection
Min. Tensile
Strength
Article No.
RT40R
Part No.
Type
lbs.
(N)
Length (L)
in.
Max. Ø Bundle
(mm)
Width (W)
in.
(mm)
in.
(mm)
115-06219
RT40R9C2
RT40R
34 lbs
(150)
8.46″
(215)
2.0″
(51)
.16″
(4.0)
115-06204
RT40R9M4
RT40R
34 lbs
(150)
8.46″
(215)
2.0″
(51)
.16″
(4.0)
115-06200
RT40R0C2
RT40R
34 lbs
(150)
8.46″
(215)
2.0″
(51)
.16″
(4.0)
115-06202
RT40R0M4
RT40R
34 lbs
(150)
8.46″
(215)
2.0″
(51)
.16″
(4.0)
115-06319
RT50S9C2
RT50S
50 lbs
(225)
6.5″
(165)
1.38″
(35)
.18″
(4.6)
115-06304
RT50S9M4
RT50S
50 lbs
(225)
6.5″
(165)
1.38″
(35)
.18″
(4.6)
115-06300
RT50S0C2
RT50S
50 lbs
(225)
6.5″
(165)
1.38″
(35)
.18″
(4.6)
115-00035
RT50S0M4
RT50S
50 lbs
(225)
6.5″
(165)
1.38″
(35)
.18″
(4.6)
Color
Natural
Black
Pkg.
Qty.
100
1000
100
1000
RT50S
Natural
Black
100
1000
100
1000
RT50LL
115-06102
RT50LL9C2
RT50LL
50 lbs
(225)
15″
(380)
3.98″
(101)
.18″
(4.6)
115-06104
RT50LL9M4
RT50LL
50 lbs
(225)
15″
(380)
3.98″
(101)
.18″
(4.6)
115-00039
RT50LL0C2
RT50LL
50 lbs
(225)
15″
(380)
3.98″
(101)
.18″
(4.6)
115-06101
RT50LL0M4
RT50LL
50 lbs
(225)
15″
(380)
3.98″
(101)
.18″
(4.6)
Natural
Black
66
100
1000
100
1000
Fasteners
REL Releasable Ties
Ideal for use in applications where there is the need to repeatedly open and close the tie.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Article No.
Part No.
Type
lbs.
(N)
Length (L)
Max. Ø Bundle
in.
(mm)
in.
(mm)
Width (W)
in. (mm)
Color
Pkg. Qty.
REL50R
115-00503 REL50R9C2
REL50R
50 lbs
(225)
5.5″
(140)
1.38″
(35)
.29″
(7.4)
115-00505 REL50R9L4
REL50R
50 lbs
(225)
5.5″
(140)
1.38″
(35)
.29″
(7.4)
115-00500 REL50R0C2
REL50R
50 lbs
(225)
5.5″
(140)
1.38″
(35)
.29″
(7.4)
115-00502 REL50R0L4
REL50R
50 lbs
(225)
5.5″
(140)
1.38″
(35)
.29″
(7.4)
115-00605 REL50L9C2
REL50L
50 lbs
(225)
9.84″
(250)
2.76″
(70)
.29″
(7.4)
115-00607 REL50L9L4
REL50L
50 lbs
(225)
9.84″
(250)
2.76″
(70)
.29″
(7.4)
115-00600 REL50L0C2
REL50L
50 lbs
(225)
9.84″
(250)
2.76″
(70)
.29″
(7.4)
115-00602 REL50L0L4
REL50L
50 lbs
(225)
9.84″
(250)
2.76″
(70)
.29″
(7.4)
Natural
Black
100
200
100
200
REL50L
Natural
Black
100
200
100
200
Pinch Releasable Ties
Patented pinch release mechanism for easy handling allows tie to be released using one hand.
Material Data
Material
Operating
Temperature
Flammability
UL94 V2
Product Selection
Article No.
Part No.
Type
lbs.
(N)
Length (L)
in.
Max. Ø Bundle
Width (W)
(mm)
in.
(mm)
in.
(mm)
Color
Pkg. Qty.
115-40200
REZ200.NB3P
REZ200
30 lbs
(135)
7.88″
(200)
1.97″
(50)
.19″
(4.7)
Black
100
115-40300
REZ300.NB3P
REZ300
30 lbs
(135)
12.00″
(305)
3.15″
(80)
.19″
(4.7)
Black
100
67
Fasteners
Heavy Duty Releasable Cable Ties
The RT150 and RT250 heavy duty releasable cable ties feature an extended pawl which allows for simple and quick release
of the ties.
RT150 Heavy Duty Releasable Cable Ties
Material Data
Material
Operating
Temperature
-40 °F to +185 °F
Flammability
UL94 V2
Product Selection
Min. Tensile
Strength
(mm)
in.
(mm)
Color
Pkg. Qty.
175 lbs
(780)
15.35″
(390)
4″
(105)
.346″
(8.8)
Black
25
115-00037 RT150MEP0X2
RT150MEP
175 lbs
(780)
21.06″
(535)
5.90″
(150)
.346″
(8.8)
Black
25
115-00038 RT150LEP0X2
RT150LEP
175 lbs
(780)
32.28″
(820)
9.65″
(245)
.346″
(8.8)
Black
25
Type
in.
(mm)
in.
Width (W)
RT150REP
Part No.
(N)
Max. Ø Bundle
115-00036 RT150REP0X2
Article No.
lbs.
Length (L)
RT250 Heavy Duty Releasable Cable Ties
Material Data
Material
Operating
Temperature
-40 °F to +185 °F
Flammability
UL94 V2
File# E64139
Product Selection
Min. Tensile
Strength
Article No.
Part No.
Type
lbs.
(N)
Length (L)
in.
(mm)
Max. Ø Bundle
in.
(mm)
Width (W)
in.
(mm)
Color
Pkg. Qty.
RT250S
131-75819 RT250S9X2
RT250S
250 lbs
(1115)
9.05″
(230)
2.17″
(55)
.49″
(12.5 )
Natural
25
115-41800 RT250S0X2
RT250S
250 lbs
(1115)
9.05″
(230)
2.17″
(55)
.49″
(12.5 )
Black
25
RT250R
131-75019 RT250R9X2
RT250R
250 lbs
(1115)
20.47″
(520)
5.71″
(145)
.49″
(12.5)
Natural
25
115-41300 RT250R0X2
RT250R
250 lbs
(1115)
20.47″
(520)
5.71″
(145)
.49″
(12.5 )
Black
25
RT250M
131-75619 RT250M9X2
RT250M
250 lbs
(1115)
22.24″
(565)
5.90″
(150)
.49″
(12.5 )
Natural
25
131-75610 RT250M0X2
RT250M
250 lbs
(1115)
22.24″
(565)
5.90″
(150)
.49″
(12.5 )
Black
25
RT250I
131-75219 RT250I9X2
RT250I
250 lbs
(1115)
28.54″
(725)
8.00″
(203)
.49″
(12.5 )
Natural
25
115-41401 RT250I0X2
RT250I
250 lbs
(1115)
28.54″
(725)
8.00″
(203)
.49″
(12.5 )
Black
25
131-75419 RT250L9X2
RT250L
250 lbs
(1115)
34.65″
(880)
10.00″
(254)
.49″
(12.5)
Natural
25
115-41500 RT250L0X2
RT250L
250 lbs
(1115)
34.65″
(880)
10.00″
(254)
.49″
(12.5 )
Black
25
RT250L
RT250XL
131-75519 RT250XL9X2
RT250XL
250 lbs
(1115)
40″
(1016.0)
12″
(304.8)
.49″
(12.5 )
Natural
25
131-75510 RT250XL0X2
RT250XL
250 lbs
(1115)
40″
(1016.0)
12″
(304.8)
.49″
(12.5 )
Black
25
68
Engineered Fastening Solutions
Fasteners
RT255 Heavy Duty Releasable Ties
Material Data
Material
Operating
Temperature
continuous
Flammability
UL94 HB
Product Selection
Min. Tensile
Strength
Article No.
Part No.
Type
lbs.
Length (L)
(N)
Max. Ø Bundle
Width (W)
in.
(mm)
in.
(mm)
in.
Color
Pkg. Qty.
115-01200 RT255S0HIRX2
RT255S
250 lbs
(1112)
8.86″
(225)
2.16″
(55)
.49″
(12.5)
(mm)
Black
25
115-01300 RT255R0HIRX2
RT255R
250 lbs
(1112)
20.28″
(515)
5.71″
(145)
.49″
(12.5)
Black
25
115-01400 RT255M0HIRX2
RT255M
250 lbs
(1112)
22.05″
(560)
6.30″
(160)
.49″
(12.5)
Black
25
SR255 Heavy Duty Sub-Releasable Ties
The SR255 series releasable heavy duty cable tie
offers a release that is lower than the head of
the cable tie, facilitating easy installation with
the use of a HellermannTyton cable tie tool.
Material Data
Material
Operating
Temperature
continuous
Flammability
UL94 HB
Product Selection
Min. Tensile
Strength
Width (W)
in.
(mm)
in.
(mm)
in.
(mm)
Color
Pkg. Qty.
SR255S
250 lbs
(1112)
8.86″
(225)
2.16″
(50)
.49″
(12.5)
Black
25
115-42101 SR255X0HIHSUVX2
SR255X
250 lbs
(1112)
14″
(372)
3.94″
(100)
.49″
(12.5)
Black
25
Part No.
Type
(N)
Max. Ø Bundle
115-42002 SR255S0HIHSUVX2
Article No.
lbs.
Length (L)
Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification
purposes.
w w w . h e l l e r m a n n . t y t o n . c o m
1 - 8 0 0 - 5 3 7 - 1 5 1 2
69
Fasteners
Speedy Tie
An entirely new design in cable management, the SpeedyTie is a fully re-usable, easily
releasable lashing tie. The SpeedyTie’s unique design allows it to be released with one
hand.
Just one click to tie and untie
Fully re-usable
Once applied, the tail can be neatly tucked away for added safety
Highly visible yellow color — also available in black, high impact modified material
Versatile design allows use for multiple applications
The SpeedyTie is a versatile tool for countless applications:
- Electrical Contractors
- Heating & Ventilation Contractors
- Residential Construction
- General and Heavy Industry
- Packaging
- Tubing and Pipe Bundling
- An “Extra Hand” for Overhead Installations
- In Plant Transfer of Products
Speedy Tie is particularly suited for
temporary but safe bundling or fixing.
SpeedyTie - Quick and easy.
Packaging Configurations
Material Data
Material
Color
Polyamide 6.6 (PA66)
Yellow , Red
Operating
Temperature
-40 °F to +185 °F
(-40 °C to +85 °C) continuous
Flammability
UL94 V2
Distributor Packs
- Printed bag with a hang hole
- Display box
- 60 SpeedyTies - 12 bags of 5
OEM Packs
- Plain bag (no hang hole)
- Standard box
- 300 SpeedyTies - 12 bags of 25
Distributor Pack - point of purchase
display for the SpeedyTie.
Product Selection
Min. Tensile
Strength
Article No.
Part No.
Type
115-00001 RTT750HR.NX900 RTT750HR
115-00000 RTT750HR.NX1P
RTT750HR
Description
lbs.
(N)
Distributor Pack - order
200 lbs (888)
in carton qty. only
OEM Pack - order in
carton qty. only
200 lbs (888)
Max. Ø
Bundle
Width (W)
(mm)
in. (mm)
in. (mm)
29.52″ (750)
8.27″ (210)
.51″
29.52″ (750)
8.27″ (210)
.51″
Length (L)
in.
Pkg.
Qty.
Carton
Qty.
(13)
5
60
(13)
25
300
70
Fasteners
Stainless Steel Cable Ties
HellermannTyton’s stainless steel ties are designed to secure hoses, cables, poles, pipes, and more when harsh environmental
conditions may adversely affect the bundling application. Used where corrosion, vibration, weathering, radiation, and
temperature extremes are a concern, HellermannTyton’s stainless steel ties can be used in virtually any indoor, outdoor, and
underground application.
MK9SST Stainless Steel Cable Tie Installation Tool
Product Selection
Type
Description
Adapted for use with stainless steel ties, the MK9 Stainless Steel tool
retains the same design features as the MK9 series. The MK9SST accommodates all
110-95000 MK9SST MK9SST
HellermannTyton stainless steel ties. Comes standard with padded foam grips for
comfort and control and a hook for hanging on a belt or tether.
Cable Tie Series
Pkg. Qty.
All MBT Series
for both 304
and 316
materials
1
304 Material
Grade 304 material is commonly used for stainless steel bundling applications and
suits most general purpose requirements. It features the ability to withstand most
environmental conditions, particularly in applications where vibration, general
weathering, radiation and temperature extremes are a concern.
• Self locking, ball bearing mechanism for quick and easy installation,
either by hand or by tensioning tool
• Fully enclosed head does not allow dirt or grit to interfere with
locking mechanism
• High tensile strength option for added strength and safety on
heavy duty applications
HellermannTyton's MK9SST tool is durable and
lightweight, offering superior stainless steel
cable tie installation.
Material Data
Material
Operating
Temperature
Stainless Steel Type SS304 (SS304)
-112 °F to +1000 °F (-80 °C to +538 °C)
Product Selection
Min. Tensile Strength
Article No.
Part No.
Type
lbs.
(N)
Length (L)
in. (mm)
Max. Ø Bundle
in.
Width (W)
(mm)
in.
(mm)
Pkg. Qty.
150 lb. Stainless Steel Ties
111-93058
MBT5S-S
MBT5SS
150 lbs
(670)
5.0″
(127)
1″
(25)
.18″
(4.6)
111-93088
MBT8S-S
MBT8SS
150 lbs
(670)
7.9″
(201)
2″
(50)
.18″
(4.6)
100
111-93148
MBT14S-S
MBT14SS
150 lbs
(670)
14.3″
(362)
4″
(102)
.18″
(4.6)
100
100
111-93208
MBT20S-S
MBT20SS
150 lbs
(670)
20.5″
(521)
6″
(152)
.18″
(4.6)
100
111-93278
MB27S-S
MBT27SS
150 lbs
(670)
26.8″
(681)
8″
(203)
.18″
(4.6)
100
111-93338
MBT33S-S
MBT33SS
150 lbs
(670)
33″
(838)
10″
(254)
.18″
(4.6)
100
250 lb. Stainless Steel Ties
111-94088
MBT8H-S
MBT8HS
250 lbs
(1115)
7.9″
(201)
2″
(50)
.31″
(7.9)
50
111-94148
MBT14H-S
MBT14HS
250 lbs
(1115)
14.3″
(362)
4″
(102)
.31″
(7.9)
50
111-94208
MBT20H-S
MBT20HS
250 lbs
(1115)
20.5″
(521)
6″
(152)
.31″
(7.9)
50
111-94278
MBT27H-S
MBT27HS
250 lbs
(1115)
26.8″
(681)
8″
(203)
.31″
(7.9)
50
111-94338
MBT33H-S
MBT33HS
250 lbs
(1115)
33″
(838)
10″
(254)
.31″
(7.9)
50
Installation tools for the above cable ties - MK9SST. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for
specification purposes. Stainless steel ties and materials should be tested thoroughly under end use conditions to determine suitability for the application.
71
Fasteners
Stainless Steel Cable Ties (continued)
316 Material
Grade 316 material is highly resistant to corrosion and widely used
in marine environments where chemicals, salts, acids, and
temperature extremes may affect the bundling application. MBT
stainless steel ties in 316 steel material are also available with a
nylon 11 protective coating. This coating creates a barrier and
protectant from chemical reactions of dissimilar metals.
locking mechanism
• High tensile strength option available for added strength and safety
on heavy duty applications
Material Data
Material
Operating
Temperature
Stainless Steel Type SS316 (SS316)
Product Selection
Article No.
Part No.
Type
lbs.
(N)
Length (L)
in.
Max. Ø Bundle
(mm)
in.
(mm)
Width (W)
in.
(mm)
Pkg. Qty.
111-93959
MBT5S
MBT5S
150 lbs
(670)
5.0″
(127)
1.0″
(25.4)
.18″
(4.6)
100
111-93089
MBT8S
MBT8S
150 lbs
(670)
7.9″
(201)
2.0″
(50)
.18″
(4.6)
100
111-93149
MBT14S
MBT14S
150 lbs
(670)
14.3″
(362)
4.0″
(102)
.18″
(4.6)
100
111-93209
MBT20S
MBT20S
150 lbs
(670)
20.5″
(521)
6.0″
(152)
.18″
(4.6)
100
111-93279
MBT27S
MBT27S
150 lbs
(670)
26.8″
(681)
8.0″
(203)
.18″
(4.6)
100
111-93339
MBT33S
MBT33S
150 lbs
(670)
33.0″
(838)
10.0″
(254)
.18″
(4.6)
100
111-94089
MBT8H
MBT8H
250 lbs
(1115)
7.9″
(201)
2.0″
(50.8)
.31″
(7.9)
50
111-94149
MBT14H
MBT14H
250 lbs
(1115)
14.3″
(362)
4.0″
(102)
.31″
(7.9)
50
111-94209
MBT20H
MBT20H
250 lbs
(1115)
20.5″
(521)
6.0″
(152)
.31″
(7.9)
50
111-94279
MBT27H
MBT27H
250 lbs
(1115)
26.8″
(681)
8.0″
(203)
.31″
(7.9)
50
111-94339
MBT33H
MBT33H
250 lbs
(1115)
33.0″
(838)
10.0″
(254)
.31″
(7.9)
50
72
