150-55850
150-55850
    HELLERMAN(海尔曼太通)
150-55850 数据手册
Specification Sheet Part Number: 150-55850 2-Piece Cable Tie/Fir Tree Mount, 6.0"L, .17"–.20" Mounting Hole Diameter, PA66HS, Black, 500/pkg Article Number 150-55850 Type T30RFT5 Color Black (BK) Features & Benefits •Friction tab inside the fir tree allows the tie to sit in mount without falling out prior to installation. •Fir tree provides low insertion effort yet demonstrates high extraction resistance. •Disc feature prevents rattling in high-vibration applications and protects against debris ingress. Quantity Per bag Product Description HellermannTyton’s fir tree mounts provide a secure grip in a mounting hole. The mount can slide along the cable tie to adjust orientation as needed. Fir tree mounts are designed to provide a low insertion force and high extraction force. This mount is sold as an assembly with the cable tie. Short Description 2-Piece Cable Tie/Fir Tree Mount, 6.0"L, .17"–.20" Mounting Hole Diameter, PA66HS, Black, 500/pkg Global Part Name T30RFT5-PA66HS/PA66HIRHS-BK Minimum Tensile Strength (Imperial) 30.0 Minimum Tensile Strength (Metric) 135 Length L (Imperial) 6.0 Length L (Metric) 150.0 Fixation Method Fir Tree Identification Plate Position none Tie Closure plastic pawl Variant Inside Serrated Width W (Imperial) 0.14 Width W (Metric) 3.5 Bundle Diameter Min (Imperial) 0.20 Bundle Diameter Min (Metric) 5.0 Bundle Diameter Max (Imperial) 1.4 Bundle Diameter Max (Metric) 34.0 Thickness T (Imperial) 0.043 Thickness T (Metric) 1.1 Height H (Imperial) 0.04 Height H (Metric) 1.2 Panel Thickness Min(Imperial) 0.03 Panel Thickness Max(Imperial) 0.12 Panel Thickness Min (Metric) 0.7 Panel Thickness Max (Metric) 3.0 Mounting Hole Diameter D (Imperial) 0.17 - 0.2 Mounting Hole Diameter D (Metric) 4.5 - 5.0 mm Mounting Hole Diameter D Min (Imperial) 0.177 Mounting Hole Diameter D Max (Imperial) 0.197 Mounting Hole Diameter D Max (Metric) 5.0 Disc Diameter(Metric) 16.0 Disc Diameter (Imperial) 0.63 Material Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HS PA66HIRHS Material Cable Tie Polyamide 6.6 heat stabilized (PA66HS) Flammability UL 94 HB Operating Temperature (Metric) -40°F to +221°F (-40°C to +105°C) Reach Complaint(Article 33) Yes ROHS Complaint Yes Package Quantity(Imperial) 500 Package Quantity (Metric) 500 Customs Number 3926909988 Content Unit(BMEcat) pcs. Weight (Metric) 1.5 © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
150-55850 价格&库存
很抱歉,暂时无法提供与“150-55850”相匹配的价格&库存,您可以联系我们找货
