118-05050
118-05050
    HELLERMAN(海尔曼太通)
118-05050 数据手册
118-05050 Article Number: 118-05050 Outside Serrated Cable Ties, 50lb. 8" Max. Bun. Dia 1.95" PA66HS, Black, 100/pk Download spec sheet Base Data Local Order Number 118-05050 Type T50ROS Color Black (BK) Features and Benefits • Outside serrations minimize damage to cables, while still providing high tensile strength and low insertion force. • Contour style head design provides additional space in constrained areas. • Heat stabilized material provides excellent resistance to high heat exposures. Product Description HellermannTyton outside serrated cable ties are designed with a smooth inside surface to help minimize indentation or damage to wire and cable insulation, while offering high tensile strength and low insertion force. The contour style head takes up less space than traditional style cable ties making it ideal for space constrained areas. For high volume applications, tensioning tools are available to ensure consistent and safe installation. Short Description Outside Serrated Cable Ties, 50lb. 8" Max. Bun. Dia 1.95" PA66HS, Black, 100/pk Product Dimensions Minimum Tensile Strength (Imperial) 50.0 lbs Minimum Tensile Strength (Metric) 225 N Length L (Imperial) 8.0 " Length L (Metric) 200 mm Fixation Method None Identification Plate Position none Releasable Closure No Tie Closure plastic pawl Variant Outside Serrated Width W (Imperial) 0.18 " Width W (Metric) 4.6 mm Height H (Imperial) 0.051 " Height H (Metric) 1.3 mm Bundle Diameter Min. (Imperial) 0.063 " Bundle Diameter Min. (Metric) 1.6 mm Bundle Diameter Max. (Imperial) 1.95 " Bundle Diameter Max. (Metric) 50.0 mm Thickness T (Imperial) 0.05 " Cable Tie Head Length (Imperial) 0.26 " Cable Tie Head Width (Imperial) 0.31 " Thickness T (Metric) 1.3 mm Logistics and Packaging Quantity Per bag Package Quantity (Metric) 100 Pieces Carton Quantity 7000 Pieces Weight (Metric) 1.3 kg Material and Specifications Material Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HS Flammability UL94 V2 Halogenfree Yes Operating Temperature -40°F to +221°F (-40°C to +105°C) ROHS Compliant Yes Certification/Specification PAN6481 © HellermannTyton 2015
118-05050 价格&库存
很抱歉,暂时无法提供与“118-05050”相匹配的价格&库存,您可以联系我们找货
  • 100+1.44064100+0.18645
  • 500+1.31840500+0.17063
  • 1500+1.161241500+0.15029
库存:1000
