126-00042
126-00042
    HELLERMAN(海尔曼太通)
    ARROWHEAD WING 18LBS 4.45"L BLK
126-00042 数据手册
126-00042 Article Number: 126-00042 Arrowhead Wing Push Mount Tie, 4.5" Long, 18lb, Panel Thickness 0.19"- 0.22", PA66, Black, 1,000/pkg Download drawing Download spec sheet Base Data Local Order Number 126-00042 Type T18RWPM Color Black (BK) Features and Benefits • Easy and quick insertion ideal for production environment. • Tie "clicks" into place upon final installation signaling installer insertion is complete. • Arrowhead style mount provides low insertion and high extraction force. Product Description Arrowhead Wing Push Ties design helps stabilize the tie in high vibration applications. This can be used on sheet metal, wood, and cast iron. Short Description Arrowhead Wing Push Mount Tie, 4.5" Long, 18lb, Panel Thickness 0.19"- 0.22", PA66, Black, 1,000/pkg Product Dimensions Minimum Tensile Strength (Imperial) 18.0 lbs Minimum Tensile Strength (Metric) 80 N Length L (Imperial) 4.5 " Length L (Metric) 113.0 mm Fixation Method Arrowhead Identification Plate Position none Releasable Closure No Tie Closure plastic pawl Variant Inside Serrated Width W (Imperial) 0.1 " Width W (Metric) 2.5 mm Width W2 (Imperial) 0.25 " Width W2 (Metric) 6.4 mm Height H (Imperial) 0.23 " Height H (Metric) 5.8 mm Bundle Diameter Min. (Imperial) 0.06 " Bundle Diameter Min. (Metric) 1.5 mm Bundle Diameter Max. (Imperial) 0.86 " Bundle Diameter Max. (Metric) 22.0 mm Disc Diameter (Imperial) 0.5 " Disc Diameter (Metric) 13.2 mm Panel Thickness Max. (Imperial) 0.13 " Panel Thickness Max. (Metric) 3.2 mm Panel Thickness Min. (Imperial) 0.06 " Panel Thickness Min. (Metric) 1.52 mm Mounting Hole Diameter D (Imperial) 0.19 - 0.22 " Mounting Hole Diameter D (Metric) 4.8 - 5.6 mm Mounting Hole Diameter D Min. 0.19 " (Imperial) Mounting Hole Diameter D Max.0.22 " (Imperial) Mounting Hole Diameter D Max. 5.6 mm (Metric) Mounting Hole Diameter D Min. (Metric)4.8 mm Thickness T (Metric) 1.1 mm Logistics and Packaging Quantity Per bag Package Quantity (Metric) 1000 Carton Quantity 10000 Material and Specifications Material Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HS Flammability UL94 V2 Operating Temperature -40°F to +221°F (-40°C to +105°C) ROHS Compliant Yes Certification/Specification UL © HellermannTyton 2015 Thickness T (Imperial)0.043 "
126-00042 价格&库存
很抱歉,暂时无法提供与“126-00042”相匹配的价格&库存,您可以联系我们找货
