GT.50X60C2
Article Number: 854-44336
Grip Tie, 6.0"x.5", Polyamide; Polyethylene, Black, 100/pkg
Download spec sheet
Base Data
Local Order Number GT.50X60C2
Type GT.50X6
Color Black (BK)
Features and Benefits • Features quick release for repetitive access to cable and wire.
• Can be opened and closed numerous times without failure.
• Adjustable so one size can accommodate multiple bundle sizes.
Product Description The Grip Tie is a low profile, one piece fastening device. Constructed of a hook and loop design, laminated back to
back, the Grip Tie features quick release for repetitive access to cable and wire. Grip Ties are available in a variety of
colors and are versatile enough for applications ranging from network installations to bundling power cords.
Short Description Grip Tie, 6.0"x.5", Polyamide; Polyethylene, Black, 100/pkg
Product Dimensions
Minimum Tensile Strength (Imperial) 40.0 lbs
Minimum Tensile Strength (Metric) 177.93 N
Length L (Imperial) 6.0 "
Length L (Metric) 152.4 mm
Length L2 (Imperial) 1.5 "
Length L2 (Metric) 38.1 mm
Width W (Imperial) 0.5 "
Width W (Metric) 12.7 mm
Width W2 (Imperial) 1.0 "
Width W2 (Metric) 25.4 mm
Bundle Diameter Max. (Imperial) 1.0 "
Bundle Diameter Max. (Metric) 25.4 mm
Logistics and Packaging
Quantity Per bag
Package Quantity 100
Package Quantity (Metric) 100
Carton Quantity 1000
Material and Specifications
Material Polyethylene (PE)
Polyamide 6 (PA6)
Material Shortcut PA66
PE
© HellermannTyton 2015
很抱歉,暂时无法提供与“GT.50X60C2”相匹配的价格&库存,您可以联系我们找货
