118-00032
118-00032
    HELLERMAN(海尔曼太通)
    PEEK TIE 5.7"L 52LB BEIGE
118-00032 数据手册
Cable Ties and Fixings 1.2 Cable Ties Outside Serrated Cable Ties for high temperature applications up to +240 °C PEEK Ties have been designed for the use in hazardous environment. Their suitablility for high temperature applications makes them ideal for use in the drilling industry, railway, offshore or automotive industry. The excellent chemical and radium ray resistance is predestined for applications in medical engineering, chemical industry and power stations. Within the aerospace industry, PEEK ties are suitable due to their good ratio weight to tensile strength. Because of this combination of different properties, PEEK ties can replace metal solutions. Features and benefits • For high temperature applications from -55 °C up to +240 °C • Outside serrated cable tie with smooth surface to the bundle • Close fit to the cable bundle due to the deepening head shape • Easy insertion combined with high tensile strength • Takes up less space due to curved head design • Combines the performance of a metal tie with the ease of use of a polyamide cable tie • Manual and/or pneumatic tools available for greater process reliability The contoured head takes up less space, gives a low insertion force and offers high strength. Please find more PEEK products for your system solutions: Foot Part P1SFT65, see page 108. Screw Mount CTAM, see page 149. L W PEEK-Series One Step to the Web! PEEK Ties, outside serrated TYPE Width (W) Length (L) Bundle Ø min. Bundle Ø max. PT2A 3.4 145.0 4.0 35.0 PT3B 4.7 250.0 4.0 65.0 Colour Material Pack Cont. Tools Article-No. 230 Beige (BGE) PEEK 100 pcs. 6-8 118-00032 300 Beige (BGE) PEEK 100 pcs. 6-8 118-00116 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. PEEK Ties, inside serrated TYPE Width (W) Length (L) Bundle Ø min. Bundle Ø max. PT220 4.7 220.0 8.0 56.0 380 Material Colour Pack Cont. Tools Article-No. PEEK Beige (BGE) 100 pcs. 8;12;15 111-01235 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 15 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 EVO9 EVO9HT MK9P MK9SST 551 551 552 552 554 555 556 557 554 554 558 560 Date of issue: 10/2017 For more information on toolings please refer to the Application Tooling chapter. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/fixings 69 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Colour** Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Material Properties* E/TFE -80 °C to +170 °C Blue (BU) UL 94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL 94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV- resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL 94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitiv Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL 94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL 94 V2 • High yield strength Polyamide 6.6, glass-fibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL 94 HB • Good resistance to: lubricants, vehicle fuel, salt water and a lot of solvent Polyamide 6.6, heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL 94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL 94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL 94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL 94 HB Polyamide 6.6, high impact modified, ScanBlack PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 V2 • High yield strength • UV-resistant Polyamide 6.6 Polyamide 6.6, UV-resistant Material Specifications • Resistance to radioactivity • UV- resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistanc Ethylene Tetrafluoroethylene (Tefzel®) Polyamide 6, high impact modified 26 Flammability • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Further information at www.HellermannTyton.com/fixings Date of issue: 10/2017 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6, with metal particles Polyamide 6.6 V0 MATERIAL Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL 94 HB • High yield strength • Metal and X-Ray detectable PA66MP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and x-ray detectable PA66V0 -40 °C to +85 °C White (WH) UL 94 V0 • High yield strength • Low smoke emission SP -50 °C to +150 °C Black (BK) halogen free • UV-resistant • Good chemical resistance to: most acids, alkaliks and oils PEEK -55 °C to +240 °C Beige (BGE) UL 94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL 94 HB • Low moisture absorption • Good chemical oilsresistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL 94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL 94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL 94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL 94 HB • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polypropylene with metal particles PPMP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and x-ray detectable Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL 94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) non-burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL 94 HB • High elastic • Good chemical resistance to: acids, bases and oxidizing agents Polyester Polyetheretherketone Polypropylene, Ethylene-PropyleneDien-Terpolymererubber free of Nitrosamine Date of issue: 10/2017 Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®-Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. *These details are only rough guide values. They should not be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. Material Properties* 1.0 Material Specifications **More colours on request. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 27
118-00032 价格&库存
很抱歉,暂时无法提供与“118-00032”相匹配的价格&库存,您可以联系我们找货
