118-04800
118-04800
    HELLERMAN(海尔曼太通)
118-04800 数据手册
Cable Ties and Fixings 1.2 Cable Ties Outside Serrated Cable Ties for thin-walled bundles OS-Series OS-Series cable ties are used in many areas where thin-walled or soft insulation wires and cables are being installed, e. g. automotive and aircraft industry. OS ties made from PA66V0 material are suitable for applications where safety regulations are required, e.g. reduction of smoke and dangerous gases. Features and Benefits • Outside serrated cable tie with smooth surface to the bundle • Tie follows the contours of the cable bundle perfectly • Takes up less space due to curved head • Easy insertion and high tensile strength • For higher temperature or Limited Fire Hazard demand: Material PA46 or PA66V0 • Easy application either manually or with a processing tool The contoured head needs less installation space, provides low insertion force and offers high strength. L W The new head design of the OS-Series TYPE T18ROS T30ROS T30LOS T50SOS T50ROS T50MOS T50LOS T120ROS OS-Series Width (W) Length (L) Bundle Ø min. Bundle Ø max. 2.5 100.0 1.6 20.0 80 PA66HS Black (BK) 500 pcs. 2;4-6 118-04701 2.5 100.0 1.6 20.0 80 PA66HS Natural (NA) 1,000 pcs. 2;4-6 118-00035 2.5 100.0 1.6 20.0 80 PA66V0-HOI White (WH) 100 pcs. 2;4-6 118-00079 3.4 145.0 1.6 35.0 135 PA66HS Natural (NA) 100 pcs. 2;4-6 118-00064 3.4 145.0 1.6 35.0 135 PA66HS Black (BK) 100 pcs. 2;4-6 118-04800 3.4 200.0 1.6 50.0 135 PA66HS Natural (NA) 100 pcs. 2;4-6 118-00044 3.4 200.0 1.6 50.0 135 PA66V0-HOI White (WH) 100 pcs. 2;4-6 118-00080 3.4 200.0 1.6 50.0 135 PA66HS Black (BK) 100 pcs. 2;4-6 118-04900 4.6 150.0 1.6 35.0 225 PA66HS Black (BK) 100 pcs. 2;4-8 118-05850 4.6 200.0 1.6 50.0 225 PA46 Grey (GY) 500 pcs. 2;4-8 118-05078 4.6 200.0 1.6 50.0 225 PA66HS Black (BK) 500 pcs. 2;4-8 118-05040 4.6 200.0 1.6 50.0 225 PA66HS Natural (NA) 100 pcs. 2;4-8 118-05059 4.6 245.0 1.6 66.0 225 PA66HS Black (BK) 100 pcs. 2;4-8 118-00018 4.6 245.0 1.6 66.0 225 PA66HS Natural (NA) 100 pcs. 2;4-8 118-00055 4.6 245.0 1.6 66.0 225 PA66V0-HOI White (WH) 100 pcs. 2;4-8 118-00081 4.6 384.0 1.6 110.0 225 PA66HS Black (BK) 100 pcs. 2;4-8 118-05900 7.6 385.0 5.0 105.0 535 PA66HS Black (BK) 100 pcs. 3;9-12 118-00066 7.6 385.0 5.0 105.0 535 PA66HS Natural (NA) 100 pcs. 3;9-12 118-00067 7.6 385.0 5.0 105.0 535 PA66V0-HOI White (WH) 100 pcs. 3;9-12 118-00082 Material Pack Cont. Colour Tools Article-No. Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 MK9 MK9HT MK9P For more information on toolings please refer to the Application Tooling chapter. Further information at www.HellermannTyton.com/fixings 65 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylene Tetrafluoroethylene E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV-resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6, high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6, high impact modified glass-fibre reinforced Polyamide 6.6, heat and UV stabilised Polyamide 6.6, UV-resistant Colour** Material Properties* Flammability Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • Resistance to radioactivity • UV-resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances 24 Material Specifications Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6 V0 MATERIAL Material Properties* Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions SP -50 °C to +150 °C Black (BK) Halogen free • UV-resistant • Good chemical resistance to: most acids, alkalis and oils PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyamide 6.6 V0, High Oxygen Index Polyester Polyetheretherketone Polypropylene, EthylenePropylene-DienTerpolymere-rubber free of Nitrosamine Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL94 HB • Floats in certain liquids • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Non burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL94 HB • High elasticity • Good chemical resistance to: acids, bases and oxidizing agents Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. 1.0 Material Specifications **More colours on request. Date of issue: October 2015 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 25
118-04800 价格&库存
很抱歉,暂时无法提供与“118-04800”相匹配的价格&库存,您可以联系我们找货
  • 100+1.39363100+0.18024
  • 200+1.32731200+0.17166
  • 300+1.28972300+0.16680
  • 500+1.24409500+0.16090
  • 700+1.21471700+0.15710
  • 1000+1.184521000+0.15319
库存:18400
