CTT60R9C2
Article Number: 112-52104
Compression Tie, 8" Long, 60lb Tensile Strength, PA66, Natural, 100/pkg
Download spec sheet
Base Data
Local Order Number CTT60R9C2
Type CTT60R
Color Natural (NA)
Features and Benefits • Head design contains clamping rails to provide full circumferential compression around bundles.
• Bent tail allows for quick insertion into head.
Product Description The 360 Degree compression ties were designed with underside clamping rails to allow for optimal surface contact
and complete circumferential compression around the bundle. The bent tail design allows quick and simple
installations by hand. For high volume applications, tensioning tools are available to ensure consistent and safe
installation.
Short Description Compression Tie, 8" Long, 60lb Tensile Strength, PA66, Natural, 100/pkg
Product Dimensions
Minimum Tensile Strength (Imperial) 60.0 lbs
Minimum Tensile Strength (Metric) 265.0 N
Length L (Imperial) 8.0 "
Length L (Metric) 205.0 mm
Fixation Method None
Identification Plate Position none
Releasable Closure No
Tie Closure plastic pawl
Variant Inside Serrated
Width W (Imperial) 0.19 "
Width W (Metric) 4.7 mm
Bundle Diameter Min. (Imperial) 0.06 "
Bundle Diameter Min. (Metric) 1.5 mm
Bundle Diameter Max. (Imperial) 1.8 "
Bundle Diameter Max. (Metric) 45.0 mm
Logistics and Packaging
Quantity Per bag
Package Quantity (Metric) 100
Carton Quantity 5000
Material and Specifications
Material Polyamide 6.6 (PA66)
Material Shortcut PA66
Flammability UL94 V2
Operating Temperature -40°F to +185°F (-40°C to +85°C)
ROHS Compliant Yes
Certification/Specification UL
UL Listed (US and Canada) No
UL Recognized (US and Canada) Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“CTT60R9C2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+4.66886100+0.60681
- 200+4.44583200+0.57783
- 300+4.32016300+0.56149
- 500+4.16719500+0.54161
- 700+4.06935700+0.52890
- 1000+3.968161000+0.51574
