GT.50X115P2
Article Number: 854-44329
Grip Tie, 11.0"x.5", Polyamide; Polyethylene, Green, 10/pkg
Download drawing
Download spec sheet
Base Data
Local Order Number GT.50X115P2
Type GT.50X11
Color Green (GN)
Features and Benefits • Features quick release for repetitive access to cable and wire.
• Can be opened and closed numerous times without failure.
• Adjustable so one size can accommodate multiple bundle sizes.
Product Description The Grip Tie is a low profile, one piece fastening device. Constructed of a hook and loop design, laminated back to
back, the Grip Tie features quick release for repetitive access to cable and wire. Grip Ties are available in a variety of
colors and are versatile enough for applications ranging from network installations to bundling power cords.
Short Description Grip Tie, 11.0"x.5", Polyamide; Polyethylene, Green, 10/pkg
Product Dimensions
Minimum Tensile Strength (Imperial) 40.0 lbs
Minimum Tensile Strength (Metric) 177.93 N
Length L (Imperial) 11.0 "
Length L (Metric) 279.4 mm
Length L2 (Imperial) 1.5 "
Length L2 (Metric) 38.1 mm
Width W (Imperial) 0.5 "
Width W (Metric) 12.7 mm
Width W2 (Imperial) 1.0 "
Width W2 (Metric) 25.4 mm
Bundle Diameter Max. (Imperial) 2.63 "
Bundle Diameter Max. (Metric) 66.802 mm
Logistics and Packaging
Quantity Per bag
Package Quantity 10
Package Quantity (Metric) 10
Carton Quantity 1000
Material and Specifications
Material Polyamide 6 (PA6)
Polyethylene (PE)
Material Shortcut PE
PA66
© HellermannTyton 2015
很抱歉,暂时无法提供与“GT.50X115P2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+16.8032410+2.18437
- 20+15.9997420+2.07992
- 30+15.5464930+2.02100
- 50+14.9939850+1.94917
- 70+14.6428570+1.90353
- 100+14.27807100+1.85611
