111-12301
Article Number: 111-12301
Heavy Duty Cable Tie, 12.1" Long, 120lb Tensile Strength, PA66HIRHSUV, Black, 300/pkg
Download drawing
Download spec sheet
Base Data
Local Order Number 111-12301
Type WSI
Color Black (BK)
Features and Benefits • Wider and thinner strap design increases flexibility, provides low insertion and minimizes pinching of bundles.
• Low profile head with clamping rails provide compact bundling with a full circumferential compression around
bundles.
• Bent tail allows for quick insertion into head or mounts.
• High impact, heat and UV stabilized heavy duty cable ties contain an impact modifier allowing greater flexibility and
greater resistance to vibration.
Product Description The Heavy Duty Wide Strap Cable Tie was designed to minimize the pinching of soft bundles and the potential of
lateral movement along the bundle. The low profile head and underside clamping rails increase the grip around the
bundle and provide a better fit than traditional cable ties. These are used primarily in the trucking and heavy
equipment industries, but can be used in a wide variety of applications where strength is needed.
Short Description Heavy Duty Cable Tie, 12.1" Long, 120lb Tensile Strength, PA66HIRHSUV, Black, 300/pkg
Product Dimensions
Minimum Tensile Strength (Imperial) 120.0 lbs
Minimum Tensile Strength (Metric) 535.0 N
Length L (Imperial) 12.1 "
Length L (Metric) 307.0 mm
Fixation Method None
Identification Plate Position none
Releasable Closure No
Tie Closure plastic pawl
Variant Inside Serrated
Width W (Imperial) 0.5 "
Width W (Metric) 12.7 mm
Bundle Diameter Min. (Imperial) 0.38 "
Bundle Diameter Min. (Metric) 9.7 mm
Bundle Diameter Max. (Imperial) 3.3 "
Bundle Diameter Max. (Metric) 83.8 mm
Thickness T (Imperial) 0.055 "
Cable Tie Head Length (Imperial) 0.393 "
Cable Tie Head Width (Imperial) 0.78 "
Thickness T (Metric) 1.4 mm
Logistics and Packaging
Quantity Per bag
Package Quantity (Metric) 300 Pieces
Carton Quantity 1200
Weight (Metric) 2 kg
Material and Specifications
Material Polyamide 6.6 high impact modified, heat and UV stabilized (PA66HIRHSUV)
Material Shortcut PA66HIRHSUV
Flammability UL94 HB
Operating Temperature -40°F to +230°F (-40°C to +110°C)
ROHS Compliant Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“111-12301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1200+7.933251200+1.02830
- 6000+7.323006000+0.94920
- 18000+6.3640418000+0.82490
- 国内价格 香港价格
- 300+9.06751300+1.17533
