GT.75X150C2
GT.75X150C2
    HELLERMAN(海尔曼太通)
    GRIPTIE15X.75"BLACK
GT.75X150C2 数据手册
GT.75X150C2 Article Number: 854-44369 Grip Tie, 15.0"x.75", Polyamide; Polyethylene, Black, 100/pkg Download drawing Download spec sheet Base Data Local Order Number GT.75X150C2 Type GT.75X15 Color Black (BK) Features and Benefits • Features quick release for repetitive access to cable and wire. • Can be opened and closed numerous times without failure. • Adjustable so one size can accommodate multiple bundle sizes. Product Description The Grip Tie is a low profile, one piece fastening device. Constructed of a hook and loop design, laminated back to back, the Grip Tie features quick release for repetitive access to cable and wire. Grip Ties are available in a variety of colors and are versatile enough for applications ranging from network installations to bundling power cords. Short Description Grip Tie, 15.0"x.75", Polyamide; Polyethylene, Black, 100/pkg Product Dimensions Minimum Tensile Strength (Imperial) 50.0 lbs Minimum Tensile Strength (Metric) 222.41 N Length L (Imperial) 15.0 " Length L (Metric) 381.0 mm Length L2 (Imperial) 2.5 " Length L2 (Metric) 63.5 mm Width W (Imperial) 0.75 " Width W (Metric) 19.05 mm Width W2 (Imperial) 1.5 " Width W2 (Metric) 38.1 mm Bundle Diameter Max. (Imperial) 3.88 " Bundle Diameter Max. (Metric) 98.552 mm Logistics and Packaging Quantity Per bag Package Quantity 100 Package Quantity (Metric) 100 Carton Quantity 1000 Material and Specifications Material Polyamide 6 (PA6) Polyethylene (PE) Material Shortcut PA66 PE © HellermannTyton 2015
GT.75X150C2 价格&库存
很抱歉,暂时无法提供与“GT.75X150C2”相匹配的价格&库存,您可以联系我们找货
GT.75X150C2
  • 100+25.92292100+3.35545
  • 200+24.68587200+3.19533
  • 300+23.98936300+3.10518
  • 500+23.14007500+2.99524
  • 700+22.59739700+2.92500
  • 1000+22.036291000+2.85237
库存:400
