156-00074
Article Number: 156-00074
Heavy Duty Fir Tree with Cable Tie, 15.1" Length, Panel Thickness .04"-.62", PA66HIRHSUV, Black, 100/pkg
Download drawing
Download spec sheet
Base Data
Local Order Number 156-00074
Type WSRFT9B
Color Black (BK)
Features and Benefits • The “H” profile provides a broad surface contact to minimize the pinching of bundles.
• Heavy duty fir tree mounts are equipped with a friction tab that will hold the tie in the mount, allowing them to be
preassembled prior to installation.
• Designed specifically for HellermannTyton 120 - 250 lb. cable ties for heavy duty applications.
Product Description HellermannTyton heavy duty fir tree mounts are designed with heavy duty applications in mind. These are optimized
for up to 3 to 1 extraction versus insertion force to make assembly fast and easy. These mounts are sold as an
assembly with a cable tie.
Short Description Heavy Duty Fir Tree with Cable Tie, 15.1" Length, Panel Thickness .04"-.62", PA66HIRHSUV, Black, 100/pkg
Product Dimensions
Minimum Tensile Strength (Imperial) 120.0 lbs
Minimum Tensile Strength (Metric) 534 N
Length L (Imperial) 15.0 "
Length L (Metric) 380.0 mm
Fixation Method Fir Tree
Identification Plate Position none
Tie Closure plastic pawl
Variant Inside Serrated
Width W (Imperial) 0.5 "
Width W (Metric) 12.7 mm
Width W2 (Imperial) 0.51 "
Width W2 (Metric) 13.0 mm
Height H (Imperial) 1.12 "
Height H (Metric) 28.4 mm
Height H2 (Imperial) 0.73 "
Height H2 (Metric) 18.4 mm
Bundle Diameter Max. (Imperial) 4.1 "
Bundle Diameter Max. (Metric) 105.0 mm
Disc Diameter (Imperial) 0.85 "
Disc Diameter (Metric) 21.6 mm
Panel Thickness Max. (Imperial) 0.62 "
Panel Thickness Max. (Metric) 15.8 mm
Panel Thickness Min. (Imperial) 0.04 "
Panel Thickness Min. (Metric) 1.0 mm
Mounting Hole Diameter D (Metric) 8.75 - 9.25 mm
Mounting Hole Diameter D Min. 0.34 "
(Imperial)
Mounting Hole Diameter D Max.0.36 "
(Imperial)
Mounting Hole Diameter D Min. (Metric)
Mounting Hole Diameter D Max.9.25 mm
(Metric)
8.75 mm
Logistics and Packaging
Quantity Per bag
Package Quantity (Metric) 100
Carton Quantity 500
Material and Specifications
Material Polyamide 6.6 high impact modified, heat and UV stabilized (PA66HIRHSUV)
Material Shortcut PA66HIRHSUV
Flammability UL94 HB
Operating Temperature -67°F to +212°F (-55°C to +100°C)
ROHS Compliant Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“156-00074”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+18.76558100+2.43662
- 200+17.86956200+2.32028
- 300+17.36531300+2.25480
- 500+16.75048500+2.17497
- 700+16.35754700+2.12395
- 1000+15.951171000+2.07118
