148-00200
148-00200
    HELLERMAN(海尔曼太通)
148-00200 数据手册
148-00200 Article Number: 148-00200 Description: Cable Tie and Edge Clip, 50 lbs, 8" Long, EC12, Panel Thickness .04"-.12", PA66HS, Black, 500/bag Base Data Local Order Number 148-00200 Type T50SOSEC12E Color Black (BK) Features and benefits ‡Edge Clip applies easily to plastic and metal sheets without the need for a mounting hole. ‡Edge Clip provides low insertion force and high extraction force ideal for assembly environments. ‡Two piece assembly allows the mount to slide along the strap ensuring proper orientation. ‡Cable tie is outside serrated to reduce bundle chafing. Quantity Per bag Product Description The cable tie and edge clip assembly is ideal for use where holes are not acceptable or where adhesives will fail due to temperature problems. Edge clips are widely used for fixing and bundling cables and wires within automotive, trucking, heavy equipment, solar panel, wind power, and white goods equipment manufacturing. Short Description Cable Tie and Edge Clip, 50 lbs, 8" Long, EC12, Panel Thickness .04"-.12", PA66HS, Black, 500/bag Minimum Tensile Strength (Imperial) 40.0lbs Minimum Tensile Strength (Metric) 150N Length L (Imperial) 6.0" Length L (Metric) 160.0mm Length L2 (Imperial) 0.6" Fixation Method Edge Clips Identification Plate Position none Length L2 (Metric) 15.0mm Releasable Closure No Tie Closure plastic pawl Variant Outside Serrated Width W (Imperial) 0.18" Product Dimensions generated on: 5/9/2017 148-00200 Product Dimensions Width W (Metric) 4.6mm Width W2 (Imperial) 0.43" Width W2 (Metric) 11.0mm Height H (Imperial) 0.06" Height H (Metric) 1.35mm Height H2 (Imperial) 0.591" Bundle Diameter Min. (Imperial) 0.04" Bundle Diameter Min. (Metric) 1.0mm Bundle Diameter Max. (Imperial) 1.4" Bundle Diameter Max. (Metric) 35.0mm Panel Thickness Max. (Imperial) 0.12" Panel Thickness Max. (Metric) 3.0mm Panel Thickness Min. (Imperial) 0.04" Panel Thickness Min. (Metric) 1.0mm Thickness T (Imperial) 0.05" Thickness T (Metric) 1.35mm Material Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HS Flammability UL 94 V2 Operating Temperature -40°F to +221°F (-40°C to +105°C) REACH Compliant (Article 33) Yes ROHS Compliant Yes Package Quantity (Metric) 500Pieces Customs Number(Schedule B) 3926909987 Content Unit (BMEcat) pieces Weight (Metric) 2.2kg Material and Specifications Logistic and Packaging generated on: 5/9/2017
148-00200 价格&库存
很抱歉,暂时无法提供与“148-00200”相匹配的价格&库存,您可以联系我们找货
  • 500+6.52916500+0.84877
  • 1000+6.217501000+0.80826
  • 1500+6.042091500+0.78546
  • 2500+5.828252500+0.75766
  • 3500+5.691563500+0.73989
  • 5000+5.597565000+0.72767
库存:6000
