CTT60R0HSC2
CTT60R0HSC2
    HELLERMAN(海尔曼太通)
CTT60R0HSC2 数据手册
CTT60R0HSC2 Article Number: 112-52112 Compression Tie, 8" Long, 60lb Tensile Strength, PA66HS, Black, 100/pkg Download drawing Download spec sheet Base Data Local Order Number CTT60R0HSC2 Type CTT60R Color Black (BK) Features and Benefits • Heat stabilized cable ties provide excellent resistance to high heat exposures. • Head design contains clamping rails to provide full circumferential compression around bundles. • Bent tail allows for quick insertion into head. Product Description The 360 Degree compression ties were designed with underside clamping rails to allow for optimal surface contact and complete circumferential compression around the bundle. The bent tail design allows quick and simple installations by hand. For high volume applications, tensioning tools are available to ensure consistent and safe installation. Short Description Compression Tie, 8" Long, 60lb Tensile Strength, PA66HS, Black, 100/pkg Product Dimensions Minimum Tensile Strength (Imperial) 60.0 lbs Minimum Tensile Strength (Metric) 265.0 N Length L (Imperial) 8.0 " Length L (Metric) 205.0 mm Fixation Method None Identification Plate Position none Releasable Closure No Tie Closure plastic pawl Variant Inside Serrated Width W (Imperial) 0.19 " Width W (Metric) 4.7 mm Bundle Diameter Min. (Imperial) 0.06 " Bundle Diameter Min. (Metric) 1.5 mm Bundle Diameter Max. (Imperial) 1.8 " Bundle Diameter Max. (Metric) 45.0 mm Thickness T (Imperial) 0.05 " Thickness T (Metric) 1.2 mm Logistics and Packaging Quantity Per bag Package Quantity (Metric) 100 Pieces Carton Quantity 5000 Material and Specifications Material Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HS Flammability UL94 V2 Operating Temperature -40°F to +257°F (-40°C to +125°C) ROHS Compliant Yes Certification/Specification UL62275 UL Listed (US and Canada) No UL Recognized (US and Canada) Yes © HellermannTyton 2015
CTT60R0HSC2 价格&库存
很抱歉,暂时无法提供与“CTT60R0HSC2”相匹配的价格&库存,您可以联系我们找货
CTT60R0HSC2
  • 100+5.22692100+0.67836
