GT.50X80P2
Article Number: 854-44355
Grip Tie, 8.0"x.5", Polyamide; Polyethylene, Black, 10/pkg
Download spec sheet
Base Data
Local Order Number GT.50X80P2
Type GT.50X8
Color Black (BK)
Features and Benefits • Features quick release for repetitive access to cable and wire.
• Can be opened and closed numerous times without failure.
• Adjustable so one size can accommodate multiple bundle sizes.
Product Description The Grip Tie is a low profile, one piece fastening device. Constructed of a hook and loop design, laminated back to
back, the Grip Tie features quick release for repetitive access to cable and wire. Grip Ties are available in a variety of
colors and are versatile enough for applications ranging from network installations to bundling power cords.
Short Description Grip Tie, 8.0"x.5", Polyamide; Polyethylene, Black, 10/pkg
Product Dimensions
Minimum Tensile Strength (Imperial) 40.0 lbs
Minimum Tensile Strength (Metric) 177.93 N
Length L (Imperial) 8.0 "
Length L (Metric) 203.2 mm
Length L2 (Imperial) 1.5 "
Length L2 (Metric) 38.1 mm
Width W (Imperial) 0.5 "
Width W (Metric) 12.7 mm
Width W2 (Imperial) 1.0 "
Width W2 (Metric) 25.4 mm
Bundle Diameter Max. (Imperial) 1.75 "
Bundle Diameter Max. (Metric) 44.45 mm
Logistics and Packaging
Quantity Per bag
Package Quantity 10
Package Quantity (Metric) 10
Carton Quantity 1000
Material and Specifications
Material Polyamide (PA)
Polyethylene (PE)
Material Shortcut PE
PA66
© HellermannTyton 2015
很抱歉,暂时无法提供与“GT.50X80P2”相匹配的价格&库存,您可以联系我们找货
