156-00538
Article Number:
156-00538
Description:
Cable Tie and Edge Clip, 8.0" Long, EC4B, Panel
Thickness ±50lb, PA66HS, Black, 500/bag
Base Data
Local Order Number
156-00538
Type
T50REC4B
Color
Black (BK)
Features and benefits
Edge Clip applies easily to plastic and metal sheets without the need for a
mounting hole.
Edge Clip provides low insertion force and high extraction force ideal for assembly
environments.
Two piece assembly allows the mount to slide along the strap ensuring proper
orientation.
Cable tie is outside serrated to reduce bundle chafing.
Quantity Per
bag
Product Description
The cable tie and edge clip assembly is ideal for use where holes are not acceptable
or where adhesives will fail due to temperature problems. Edge clips are widely used
for fixing and bundling cables and wires within automotive, trucking, heavy
equipment, solar panel, wind power, and white goods equipment manufacturing.
Short Description
Cable Tie and Edge Clip, 8.0" Long, EC4B, Panel Thickness ±50lb,
Minimum Tensile Strength (Imperial)
50.0lbs
Minimum Tensile Strength (Metric)
225N
Length L (Imperial)
8.0"
Length L (Metric)
200mm
Length L2 (Imperial)
0.55"
Fixation Method
EdgeClip, top, assembled, 2 piece
Identification Plate Position
none
Length L2 (Metric)
14.0mm
Releasable Closure
No
Variant
Inside Serrated
Width W (Imperial)
0.18"
Width W (Metric)
4.6mm
Product
Dimensions
generated on:
5/9/2017
156-00538
Product
Dimensions
Width W2 (Imperial)
0.45"
Width W2 (Metric)
11.5mm
Height H (Imperial)
0.05"
Height H (Metric)
1.2mm
Height H2 (Imperial)
0.4"
Height H2 (Metric)
10.8mm
Bundle Diameter Min. (Imperial)
0.06"
Bundle Diameter Min. (Metric)
4.0mm
Bundle Diameter Max. (Imperial)
2.0"
Bundle Diameter Max. (Metric)
45.0mm
Panel Thickness Max. (Imperial)
0.12"
Panel Thickness Max. (Metric)
3.0mm
Panel Thickness Min. (Imperial)
0.04"
Panel Thickness Min. (Metric)
1.0mm
Thickness T (Imperial)
0.05"
Thickness T (Metric)
1.2mm
Material
Polyamide 6.6 heat stabilized (PA66HS)
Material Shortcut
PA66HIRHS
Material Cable Tie
Flammability
UL 94 HB
Operating Temperature
-40°F to +221°F (-40°C to +105°C)
ROHS Compliant
Yes
Package Quantity (Imperial)
500
Package Quantity (Metric)
500
Customs Number(Schedule B)
3926909987
Weight (Metric)
4.5kg
Material and
Specifications
Logistic and
Packaging
generated on:
5/9/2017
很抱歉,暂时无法提供与“156-00538”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+10.26935500+1.33447
- 1000+9.779261000+1.27079
- 1500+9.503511500+1.23495
- 2500+9.167262500+1.19126
- 3500+8.952333500+1.16333
- 5000+8.730075000+1.13445
