111-01671
111-01671
    HELLERMAN(海尔曼太通)
111-01671 数据手册
Specification Sheet Part Number: 111-01671 Article Number 111-01671 Type TAS120M Color Black (BK) Features & Benefits • UV resistant materials contain an inhibitor that prolongs the life of the tie in outdoor environments. • One-piece design reduces installation time. • Outside serrations prevent cable damage. Quantity Per bag Product Description Aerial Support Ties feature a built-in spacer to separate cables from the support wire and prevent abrasion. A one-piece design, combining the tie and spacer into one part, reduces installation time and inventory costs. The outside serrations along the strap prevent damage to cables. Formulated from a special nylon blend, these ties are specifically suited for long-term outdoor use. The bent tail allows for quick and simple installation by hand. Short Description Aerial Support Tie, 12.4" Long, PA66HIRHSUV, Black, 500/bag Global Part Name TAS120M-PA66HIRHSUV-BK Minimum Tensile Strength (Imperial) 120.0 Minimum Tensile Strength (Metric) 535.0 Length L (Imperial) 12.4 Length L (Metric) 270.0 Fixation Method Others Identification Plate Position none Releasable Closure No Tie Closure plastic pawl Variant Outside Serrated Width W (Imperial) 0.5 Width W (Metric) 12.7 Bundle Diameter Max (Imperial) 2.7 Bundle Diameter Max (Metric) 70.0 Thickness T (Metric) 1.58 Cable Tie Head Width (Imperial) 1.3 Height H (Imperial) .76 Height H (Metric) 19.0 Material Polyamide 6.6 high impact modified, heat and UV stabilized (PA66HIRHSUV) Material Shortcut PA66HIRHSUV Flammability UL 94 HB Operating Temperature (Metric) -40°F to +221°F (-40°C to +105°C) Reach Complaint(Article 33) Yes ROHS Complaint Yes Package Quantity(Imperial) 500 Package Quantity (Metric) 500 Customs Number 3926909988 Content Unit(BMEcat) pcs. © 2020 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
111-01671 价格&库存
很抱歉,暂时无法提供与“111-01671”相匹配的价格&库存,您可以联系我们找货
  • 500+23.62539500+3.06230
  • 2500+21.620282500+2.80240
  • 7500+18.917757500+2.45210
