156-00878
156-00878
    HELLERMAN(海尔曼太通)
156-00878 数据手册
Specification Sheet Part Number: 156-00878 Outside Serrated Cable Tie & Edge Clip, 8.0" Long, EC24, 3-6 mm Panel, 50lb, PA66HS, Black, 500/pkg Article Number 156-00878 Type T50ROSEC24 Color Black (BK) Features & Benefits •Edge Clip applies easily to plastic and metal sheets without the need for a mounting hole. •Edge Clip provides low insertion force and high extraction force ideal for assembly environments. •Two piece assembly allows the mount to slide along the strap ensuring proper orientation. •Cable tie is outside serrated to reduce bundle chafing. Quantity Per bag Product Description HellermannTyton's Two Piece Edge Clip with Cable Tie Assemblies are designed specifically to route bundles by securing them to the edge of a plastic or metal sheet without the need for a mountinig hole. The clip is easy to secure and the extraction force is high due to the integrated metal clamp that holds the edge clip in place. Short Description Outside Serrated Cable Tie & Edge Clip, 8.0" Long, EC24, 3-6 mm Panel, 50lb, PA66HS, Black, 500/pkg Global Part Name T50ROSEC24-PA66HS/PA66HIRHS-BK Minimum Tensile Strength (Imperial) 50.0 Minimum Tensile Strength (Metric) 225 Length L (Imperial) 8.0 Length L (Metric) 200.0 Fixation Method EdgeClip, sideway, assembled, 2 piece Identification Plate Position none Releasable Closure No Variant Outside Serrated Width W (Imperial) 0.18 Width W (Metric) 4.6 Bundle Diameter Min (Imperial) 0.20 Bundle Diameter Min (Metric) 1.5 Bundle Diameter Max (Imperial) 2.0 Bundle Diameter Max (Metric) 45.0 Thickness T (Imperial) 0.05 Thickness T (Metric) 1.3 Height H (Imperial) 0.05 Height H (Metric) 1.3 Panel Thickness Min(Imperial) 0.12 Panel Thickness Max(Imperial) 0.24 Panel Thickness Min (Metric) 3.0 Panel Thickness Max (Metric) 6.0 Material Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HIRHS PA66HS Material Cable Tie Polyamide 6.6 heat stabilized (PA66HS) Flammability UL 94 HB Operating Temperature (Metric) -40°F to +221°F (-40°C to +105°C) ROHS Complaint Yes Package Quantity(Imperial) 500 Package Quantity (Metric) 500 Customs Number 3926909987 Weight (Metric) 2.73 © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
156-00878
物料型号:156-00878 器件简介:海拉曼·泰顿的两片式边缘夹带扎带组件,专为固定塑料或金属板上的束线而设计,无需安装孔。 引脚分配:无 参数特性: - 最小拉伸强度:50磅(约225牛顿) - 长度:8.0英寸(200毫米) - 固定方式:两片式边缘夹,侧向组装 - 可释放闭合:否 - 扎带宽度:0.18英寸(4.6毫米) - 扎带直径范围:最小0.20英寸(1.5毫米)至最大2.0英寸(45毫米) - 面板厚度范围:最小0.12英寸(3毫米)至最大0.24英寸(6毫米) 功能详解:边缘夹容易安装在塑料和金属板上,无需安装孔;提供低插入力和高提取力,适合装配环境;两片式组装允许支架沿扎带滑动,确保正确定位;扎带外部为锯齿状,减少束线磨损。 应用信息:用于固定塑料或金属板上的束线。 封装信息:黑色(BK),每包500个。
材料:聚酰胺6.6,高冲击改性,热稳定(PA66HIRHS);聚酰胺6.6热稳定(PA66HS)。 阻燃性:UL 94 HB 工作温度:-40°F至+221°F(-40°C至+105°C) 符合RoHS:是 包装数量:500 海关编号:3926909987 重量:2.73(单位未指定)
156-00878 价格&库存
很抱歉,暂时无法提供与“156-00878”相匹配的价格&库存,您可以联系我们找货
