156-00091
156-00091
    HELLERMAN(海尔曼太通)
156-00091 数据手册
156-00091 Article Number: 156-00091 Fir Tree Mount and Cable Tie, 30lbs, 8.0" Long, Fixing Hole Dia .38"-.39", PA66HS, Black, 500/pkg Download drawing Download spec sheet Base Data Local Order Number 156-00091 Type T50RFT10 Color Black (BK) Features and Benefits • Friction tab inside of fir tree allows tie to sit in mount without falling out prior to installation. • Initial fir tree serves as a locating feature for assistance in blind assembly applications. • Disc feature provides anti-rattle protection in high vibration applications. Product Description Fir tree mounts with ties cables provide a secure grip in mounting holes and protect against dirt and other impurities. The mount provides low insertion and high extraction force, and slides along the cable tie for the proper orientation. This is sold as an assembly with the cable tie. Short Description Fir Tree Mount and Cable Tie, 30lbs, 8.0" Long, Fixing Hole Dia .38"-.39", PA66HS, Black, 500/pkg Product Dimensions Minimum Tensile Strength (Imperial) 50.0 lbs Minimum Tensile Strength (Metric) 225 N Length L (Imperial) 8.0 " Length L (Metric) 202.0 mm Length L2 (Imperial) 0.5 " Length L2 (Metric) 12.0 mm Length L3 (imperial) 0.8 " Length L3 (metric) 18.6 mm Fixation Method Fir Tree Identification Plate Position none Releasable Closure No Tie Closure plastic pawl Variant Inside Serrated Width W (Imperial) 0.18 " Width W (Metric) 4.6 mm Width W2 (Imperial) 0.5 " Width W2 (Metric) 11.6 mm Width W3 (Imperial) 0.2 " Width W3 (Metric) 5.0 mm Height H (Imperial) 0.05 " Height H (Metric) 1.2 mm Height H2 (Imperial) 0.5 " Height H2 (Metric) 12.1 mm Bundle Diameter Min. (Imperial) 0.06 " Bundle Diameter Min. (Metric) 1.5 mm Bundle Diameter Max. (Imperial) 1.8 " Bundle Diameter Max. (Metric) 50.0 mm Disc Diameter (Imperial) 0.71 " Disc Diameter (Metric) 18.0 mm Panel Thickness Max. (Imperial) 0.2 " Panel Thickness Max. (Metric) 5.0 mm Panel Thickness Min. (Imperial) 0.03 " Panel Thickness Min. (Metric) 0.8 mm Mounting Hole Diameter D (Imperial) 0.38 - 0.39 " Mounting Hole Diameter D (Metric) 9.7 - 10.0 mm Mounting Hole Diameter D Min. 0.38 " (Imperial) Mounting Hole Diameter D Max.0.39 " (Imperial) Mounting Hole Diameter D Min. (Metric) Logistics and Packaging Quantity Per bag Package Quantity (Metric) 500 Carton Quantity 2000 Material and Specifications Material Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HS Material Cable Tie Polyamide 6.6 (PA66) Flammability UL94 V2 Operating Temperature -40°F to +221°F (-40°C to +105°C) ROHS Compliant Yes © HellermannTyton 2015 Mounting Hole Diameter D Max.10.0 mm (Metric) 9.7 mm
156-00091 价格&库存
很抱歉,暂时无法提供与“156-00091”相匹配的价格&库存,您可以联系我们找货
  • 500+4.68831500+0.60961
  • 1000+4.464501000+0.58051
  • 1500+4.338561500+0.56414
  • 2500+4.184952500+0.54416
  • 3500+4.086773500+0.53140
  • 5000+3.985245000+0.51819
库存:2263
