GT.50X80C2
GT.50X80C2
    HELLERMAN(海尔曼太通)
    GRIPTIE8X.5"BLACK
GT.50X80C2 数据手册
GT.50X80C2 Article Number: 854-44353 Grip Tie, 8.0"x.5", Polyamide; Polyethylene, Black, 100/pkg Download spec sheet Base Data Local Order Number GT.50X80C2 Type GT.50X8 Color Black (BK) Features and Benefits • Features quick release for repetitive access to cable and wire. • Can be opened and closed numerous times without failure. • Adjustable so one size can accommodate multiple bundle sizes. Product Description The Grip Tie is a low profile, one piece fastening device. Constructed of polyethylene hook and nylon loop and laminated back to back, the Grip Tie features quick release for repetitive access to cable and wire. Grip Ties are available in a variety of colors and are versatile enough for applications ranging from network installations to bundling power cords. Short Description Grip Tie, 8.0"x.5", Polyamide; Polyethylene, Black, 100/pkg Product Dimensions Minimum Tensile Strength (Imperial) 40.0 lbs Minimum Tensile Strength (Metric) 177.93 N Length L (Imperial) 8.0 " Length L (Metric) 203.2 mm Length L2 (Imperial) 1.5 " Length L2 (Metric) 38.1 mm Width W (Imperial) 0.5 " Width W (Metric) 12.7 mm Width W2 (Imperial) 1.0 " Width W2 (Metric) 25.4 mm Bundle Diameter Max. (Imperial) 1.75 " Bundle Diameter Max. (Metric) 44.45 mm Logistics and Packaging Quantity Per bag Package Quantity 100 Package Quantity (Metric) 100 Carton Quantity 1000 Material and Specifications Material Polyethylene (PE) Polyamide (PA) Material Shortcut PA66 PE © HellermannTyton 2015
GT.50X80C2 价格&库存
很抱歉,暂时无法提供与“GT.50X80C2”相匹配的价格&库存,您可以联系我们找货
