156-00551
156-00551
    HELLERMAN(海尔曼太通)
156-00551 数据手册
Specification Sheet Part Number: 156-00551 Cable Tie & Edge Clip, 8.0" Long, EC9, 1–3 mm Panel, 50lb, PA66HS/PA66HIRHSUV, Black, 500/pkg Article Number 156-00551 Type T50REC9SD Color Black (BK) Features & Benefits • Edge Clip applies easily to plastic and metal sheets without the need for a mounting hole. • Edge Clip provides low insertion force and high extraction force ideal for assembly environments. Quantity Per bag Product Description The cable tie and edge clip assembly is ideal for use where holes are not acceptable or where adhesives will fail due to temperature problems. Edge clips are widely used for fixing and bundling cables and wires within automotive, trucking, heavy equipment, solar panel, wind power, and white goods equipment manufacturing. Short Description Cable Tie & Edge Clip, 8.0" Long, EC9, 1–3 mm Panel, 50lb, PA66HS/PA66HIRHSUV, Black, 500/pkg Global Part Name T50REC9SD-PA66HS/PA66HIRHS-BK Minimum Tensile Strength (Imperial) 50.0 Minimum Tensile Strength (Metric) 225 Length L (Imperial) 8.0 Length L (Metric) 202.0 Fixation Method EdgeClip, top, assembled, 2 piece Identification Plate Position none Variant Inside Serrated Width W (Imperial) 0.18 Width W (Metric) 4.6 Bundle Diameter Min (Imperial) 0.20 Bundle Diameter Min (Metric) 5.0 Bundle Diameter Max (Imperial) 2.0 Bundle Diameter Max (Metric) 50.0 Thickness T (Imperial) 0.05 Thickness T (Metric) 1.2 Height H (Imperial) 0.047 Height H (Metric) 1.2 Panel Thickness Min(Imperial) 0.04 Panel Thickness Max(Imperial) 0.12 Panel Thickness Min (Metric) 1.0 Panel Thickness Max (Metric) 3.0 Material Polyamide 6.6 heat stabilized (PA66HS) Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Material Shortcut PA66HIRHS PA66HS Material Cable Tie Polyamide 6.6 heat stabilized (PA66HS) Flammability UL 94 HB Operating Temperature (Metric) -40°F to +221°F (-40°C to +105°C) -40°F to +230°F (-40°C to +110°C) Minimum Extraction Force (Imperial) 50.0 Minimum Extraction Force (Metric) 225 ROHS Complaint Yes Package Quantity(Imperial) 500 Package Quantity (Metric) 500 Customs Number 3926909987 © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
156-00551 价格&库存
很抱歉,暂时无法提供与“156-00551”相匹配的价格&库存,您可以联系我们找货
