156-00554
156-00554
    HELLERMAN(海尔曼太通)
    CABLETIE/EDGECLIP50LB200MM
156-00554 数据手册
Specification Sheet Part Number: 156-00554 Cable Tie & Edge Clip, 8.0" Long, EC22, 1–3 mm Panel, 50lb, PA66HS/PA66HIRHSUV, Black, 500/pkg Article Number 156-00554 Type T50REC22 Color Black (BK) Features & Benefits • Edge Clip applies easily to plastic and metal sheets without the need for a mounting hole. • Edge Clip provides low insertion force and high extraction force ideal for assembly environments. • Two piece assembly allows the mount to slide along the strap ensuring proper orientation. Quantity Per bag Product Description The cable tie and edge clip assembly is ideal for use where holes are not acceptable or where adhesives will fail due to temperature problems. Edge clips are widely used for fixing and bundling cables and wires within automotive, trucking, heavy equipment, solar panel, wind power, and white goods equipment manufacturing. Short Description Cable Tie & Edge Clip, 8.0" Long, EC22, 1–3 mm Panel, 50lb, PA66HS/PA66HIRHSUV, Black, 500/pkg Global Part Name T50REC22-PA66HS/PA66HIRHS-BK Minimum Tensile Strength (Imperial) 50.0 Minimum Tensile Strength (Metric) 225 Length L (Imperial) 8.0 Length L (Metric) 202.0 Fixation Method EdgeClip, sideway, assembled, 2 piece Identification Plate Position none Variant Inside Serrated Width W (Imperial) 0.18 Width W (Metric) 4.6 Bundle Diameter Min (Imperial) 0.20 Bundle Diameter Min (Metric) 1.0 Bundle Diameter Max (Imperial) 2.0 Bundle Diameter Max (Metric) 45.0 Thickness T (Imperial) 0.05 Height H (Imperial) 0.05 Height H (Metric) 1.2 Panel Thickness Min(Imperial) 0.04 Panel Thickness Max(Imperial) 0.12 Panel Thickness Min (Metric) 1.0 Panel Thickness Max (Metric) 3.0 Material Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HS PA66HIRHS Material Cable Tie Polyamide 6.6 heat stabilized (PA66HS) ROHS Complaint Yes Package Quantity(Imperial) 500 Package Quantity (Metric) 500 Customs Number 3926909987 © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
156-00554
物料型号:156-00554 器件简介:该产品为一种电缆扎带和边缘夹,长度为8英寸,适用于1-3毫米的面板,具有50磅的最小拉伸强度,材质为PA66HS/PA66HIRHSUV,颜色为黑色,每包500个。 引脚分配:无相关信息 参数特性:最小拉伸强度为50磅(225牛顿),长度为8英寸(202毫米),宽度为0.18英寸(4.6毫米),最小束径为0.20英寸(1毫米),最大束径为2英寸(45毫米),厚度和高度均为0.05英寸(1.2毫米),面板厚度最小为0.04英寸(1毫米),最大为0.12英寸(3毫米)。 功能详解:边缘夹易于应用于塑料和金属板,无需安装孔;提供低插入力和高提取力,适合装配环境;两片组装允许支架沿带子滑动,确保正确定位。 应用信息:广泛应用于汽车、卡车、重型设备、太阳能板、风力发电和白色家电设备制造中,用于固定和捆绑电缆和电线。 封装信息:每包500个,符合RoHS标准。
156-00554 价格&库存
很抱歉,暂时无法提供与“156-00554”相匹配的价格&库存,您可以联系我们找货
