109-00043
109-00043
    HELLERMAN(海尔曼太通)
    Q30LRBLK9.84"QTIE
109-00043 数据手册
Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Q-ties Innovative – Effective – Safe! The new Q-tie has not only innovative, but also has a revolutionary new design. The open head of the cable tie enables a simple and quick installation. Simply insert the ergonomically bent tail into the open side of the head and tighten the cable tie. With Q-ties you can save time and money! The head design makes the difference. Easy Application for every Situation! Q-tie provides the perfect solution for applications in difficult working conditions. It is ideal for use when working with gloves is necessary or for blind applications with a limited view of the work allowing for a quick and simple installation. Features for quick and easy application: • Large curved tail with easy-grip ribs • Open head with easily detectable slot This saves time and trouble! Even under difficult circumstances the Q-tie cable tie is very fast and easy to apply. Integrated Pre-locking Functionality! Due to several simultaneous working processes, it is not always possible to install all cables and conduits in one single step. Using standard cable ties means either removing the cable tie of the first installation or applying additional cable ties. The integrated pre-locking function offers both a temporary and final cable fastening solution. This saves material and time! Application video: Q-Series 52 Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 Without additional effort only Q-ties can be used for temporary and final cable bundling. Cable Ties and Fixings Cable Ties Inside Serrated 1.1 Features of Q-ties: 1. Open lock head for quick and easy insertion. 2. Two rails on the strap ensure perfect guidance for the tracks in the head. 3. The locking device interacts safely with the serration of the cable tie. 4. The tracks prevent a deformation of the head under load. 5. The thin part of the cable tie can be simply placed into the open lock head. 6. The large ribbed tail allows a safe and ergonomic installation. 7. Integrated pre-locking feature (starts with type Q30). Application Method: Please find more Q-Series products for your system solution on page 134 and 459. 1. Insert the thin part of the cable tie into the open lock head. 2. Pull the tie through the head until the bundle is fixed. 3. Cut off the remaining part of the tie with an application tool. Date of issue: October 2015 Pre-Locking Function of the Q-tie: 1. Insert tail into the open head and push the tail partly into the head. 2. To release the tie push the tail slightly out of the head. 3. When the installation is complete, the Q-tie can be tightened and cut off - either manually or with an application tool. Further information at www.HellermannTyton.com/fixings 53 Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties with open head Polyamide 6.6 standard Q-Series in PA66 natural and black Q-Series cable ties for bundling and securing cables, pipes and hoses. These innovative and effective cable ties enable a simple and quick installation, even in difficult applications. Features and Benefits • Open lock head for quick and easy insertion • Integrated pre-locking function • More than 25 % faster to apply than a standard cable tie • Inside serration for a strong hold around bundles • Easy application either manually or with a processing tool L Q-tie cable ties: choose from a wide product range in different sizes. W Q-Series TYPE Q18R Q18I Q18L Q30R Q30L Q30LR Q50R Q50I Q50L Q120I Q120R Q120M Width (W) Length (L) Bundle Ø max. Material Colour Pack Cont. 2.6 105.0 24.0 Tools Article-No. 80 PA66 Black (BK) 100 pcs. 2;4-6 2.6 105.0 109-00030 24.0 80 PA66 Natural (NA) 100 pcs. 2;4-6 2.6 109-00001 155.0 40.0 80 PA66 Black (BK) 100 pcs. 2;4-6 109-00033 2.6 155.0 40.0 80 PA66 Natural (NA) 100 pcs. 2;4-6 109-00004 2.6 195.0 50.0 80 PA66 Black (BK) 100 pcs. 2;4-6 109-00036 2.6 195.0 50.0 80 PA66 Natural (NA) 100 pcs. 2;4-6 109-00007 3.6 160.0 38.0 130 PA66 Black (BK) 100 pcs. 2;4-6 109-00039 3.6 160.0 38.0 130 PA66 Natural (NA) 100 pcs. 2;4-6 109-00010 3.6 200.0 50.0 130 PA66 Black (BK) 100 pcs. 2;4-6 109-00041 3.6 200.0 50.0 130 PA66 Natural (NA) 100 pcs. 2;4-6 109-00012 3.6 250.0 65.0 130 PA66 Black (BK) 100 pcs. 2;4-6 109-00043 3.6 250.0 65.0 130 PA66 Natural (NA) 100 pcs. 2;4-6 109-00014 4.7 210.0 50.0 220 PA66 Black (BK) 100 pcs. 2-10 109-00047 4.7 210.0 50.0 220 PA66 Natural (NA) 100 pcs. 2-10 109-00018 4.7 290.0 75.0 220 PA66 Black (BK) 100 pcs. 2-10 109-00049 4.7 290.0 75.0 220 PA66 Natural (NA) 100 pcs. 2-10 109-00020 4.7 410.0 110.0 220 PA66 Black (BK) 100 pcs. 2-10 109-00051 4.7 410.0 110.0 220 PA66 Natural (NA) 100 pcs. 2-10 109-00022 7.7 300.0 70.0 530 PA66 Black (BK) 100 pcs. 3;9-12 109-00053 7.7 300.0 70.0 530 PA66 Natural (NA) 100 pcs. 3;9-12 109-00024 7.7 420.0 110.0 530 PA66 Black (BK) 100 pcs. 3;9-12 109-00055 7.7 420.0 110.0 530 PA66 Natural (NA) 100 pcs. 3;9-12 109-00026 7.7 520.0 130.0 530 PA66 Black (BK) 100 pcs. 3;9-12 109-00057 7.7 520.0 130.0 530 PA66 Natural (NA) 100 pcs. 3;9-12 109-00028 7.7 520.0 130.0 530 PA66HS Black (BK) 100 pcs. 3;9-12 109-00115 7.7 520.0 130.0 530 PA66HS Natural (NA) 100 pcs. 3;9-12 109-00144 Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 MK9 MK9HT MK9P For more information on toolings please refer to the Application Tooling chapter. For product specific approvals and specifications please refer to the Appendix. 54 Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties with open head Polyamide 6.6 standard Q-Series in PA66 coloured Q-Series cable ties for bundling and securing cables, pipes and hoses. These innovative and effective cable ties enable a simple and quick installation, even in difficult applications. Features and Benefits • Coloured cable ties available in a wide range of sizes • Open lock head for quick and easy insertion • Integrated pre-locking function • More than 25 % faster to apply than a standard cable tie • Inside serration for a strong hold around bundles • Easy application either manually or with a processing tool Q-ties in different colours are ideal for marking and bundling in one step. Material specification please see page 24. Please find more Q-Series products for your system solution on page 134 and 459. Application video: Q-Series L W Q-Series TYPE Q18R Q18I Q18L Width (W) Length (L) Bundle Ø max. Colour Pack Cont. Tools Article-No. 2.6 105.0 24.0 80 2.6 105.0 24.0 80 PA66 Blue (BU) 100 pcs. 2;4-6 109-00147 PA66 Green (GN) 100 pcs. 2;4-6 109-00148 2.6 105.0 24.0 80 2.6 105.0 24.0 80 PA66 Red (RD) 100 pcs. 2;4-6 109-00149 PA66 Yellow (YE) 100 pcs. 2;4-6 109-00150 2.6 155.0 40.0 80 2.6 155.0 40.0 80 PA66 Blue (BU) 100 pcs. 2;4-6 109-00152 PA66 Green (GN) 100 pcs. 2;4-6 109-00153 2.6 155.0 40.0 80 2.6 155.0 40.0 80 PA66 Red (RD) 100 pcs. 2;4-6 109-00154 PA66 Yellow (YE) 100 pcs. 2;4-6 2.6 195.0 50.0 109-00155 80 PA66 Blue (BU) 100 pcs. 2;4-6 109-00157 2.6 195.0 2.6 195.0 50.0 80 PA66 Green (GN) 100 pcs. 2;4-6 109-00158 50.0 80 PA66 Red (RD) 100 pcs. 2;4-6 109-00159 2.6 195.0 50.0 80 PA66 Yellow (YE) 100 pcs. 2;4-6 109-00160 Material Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 MK9 MK9HT MK9P For more information on toolings please refer to the Application Tooling chapter. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/fixings 55 Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties with open head Polyamide 6.6 standard Q-Series in PA66 coloured L W TYPE Q30R Q30L Q30LR Q50R Q50I Q50L Q120I Q120R Q120M Width (W) Length (L) Bundle Ø max. Colour Pack Cont. Tools Article-No. 3.6 160.0 38.0 130 3.6 160.0 38.0 130 PA66 Blue (BU) 100 pcs. 2;4-6 109-00162 PA66 Green (GN) 100 pcs. 2;4-6 109-00163 3.6 160.0 38.0 130 3.6 160.0 38.0 130 PA66 Red (RD) 100 pcs. 2;4-6 109-00164 PA66 Yellow (YE) 100 pcs. 2;4-6 109-00165 3.6 200.0 50.0 130 3.6 200.0 50.0 130 PA66 Blue (BU) 100 pcs. 2;4-6 109-00167 PA66 Green (GN) 100 pcs. 2;4-6 109-00168 3.6 200.0 50.0 130 3.6 200.0 50.0 130 PA66 Red (RD) 100 pcs. 2;4-6 109-00169 PA66 Yellow (YE) 100 pcs. 2;4-6 3.6 250.0 65.0 109-00170 130 PA66 Blue (BU) 100 pcs. 2;4-6 109-00172 3.6 250.0 3.6 250.0 65.0 130 PA66 Green (GN) 100 pcs. 2;4-6 109-00173 65.0 130 PA66 Red (RD) 100 pcs. 2;4-6 109-00174 3.6 4.7 250.0 65.0 130 PA66 Yellow (YE) 100 pcs. 2;4-6 109-00175 210.0 50.0 220 PA66 Blue (BU) 100 pcs. 2-10 109-00182 4.7 210.0 50.0 220 PA66 Green (GN) 100 pcs. 2-10 109-00183 4.7 210.0 50.0 220 PA66 Red (RD) 100 pcs. 2-10 109-00184 4.7 210.0 50.0 220 PA66 Yellow (YE) 100 pcs. 2-10 109-00185 4.7 290.0 75.0 220 PA66 Blue (BU) 100 pcs. 2-10 109-00187 4.7 290.0 75.0 220 PA66 Green (GN) 100 pcs. 2-10 109-00188 4.7 290.0 75.0 220 PA66 Red (RD) 100 pcs. 2-10 109-00189 4.7 290.0 75.0 220 PA66 Yellow (YE) 100 pcs. 2-10 109-00190 4.7 410.0 110.0 220 PA66 Blue (BU) 100 pcs. 2-10 109-00192 4.7 410.0 110.0 220 PA66 Green (GN) 100 pcs. 2-10 109-00193 4.7 410.0 110.0 220 PA66 Red (RD) 100 pcs. 2-10 109-00194 4.7 410.0 110.0 220 PA66 Yellow (YE) 100 pcs. 2-10 109-00195 7.7 300.0 70.0 530 PA66 Blue (BU) 100 pcs. 3;9-12 109-00197 7.7 300.0 70.0 530 PA66 Green (GN) 100 pcs. 3;9-12 109-00198 7.7 300.0 70.0 530 PA66 Red (RD) 100 pcs. 3;9-12 109-00199 7.7 300.0 70.0 530 PA66 Yellow (YE) 100 pcs. 3;9-12 109-00200 7.7 420.0 110.0 530 PA66 Blue (BU) 100 pcs. 3;9-12 109-00202 7.7 420.0 110.0 530 PA66 Green (GN) 100 pcs. 3;9-12 109-00203 7.7 420.0 110.0 530 PA66 Red (RD) 100 pcs. 3;9-12 109-00204 7.7 420.0 110.0 530 PA66 Yellow (YE) 100 pcs. 3;9-12 109-00205 7.7 520.0 130.0 530 PA66 Blue (BU) 100 pcs. 3;9-12 109-00207 7.7 520.0 130.0 530 PA66 Green (GN) 100 pcs. 3;9-12 109-00208 7.7 520.0 130.0 530 PA66 Red (RD) 100 pcs. 3;9-12 109-00209 7.7 520.0 130.0 530 PA66 Yellow (YE) 100 pcs. 3;9-12 109-00210 Material All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. For product specific approvals and specifications please refer to the Appendix. 56 Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 Q-Series Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties with open head for outdoor use (UV-resistant) Q-Series in PA66W black Q-Series cable ties for bundling and securing cables, pipes and hoses. These innovative and effective cable ties enable a simple and quick installation, even in difficult applications. Features and Benefits • Weather-resistant black cable ties available in a wide range of sizes • Open lock head for quick and easy insertion • Integrated pre-locking function • More than 25 % faster to apply than a standard cable tie • Inside serration for a strong hold around bundles • Easy application either manually or with a processing tool • UV-resistant Q-tie cable ties: choose from a wide product range in different sizes. Material specification please see page 24. Please find more Q-Series products for your system solution on page 134 and 459. L W Q-Series TYPE Width (W) Length (L) Bundle Ø max. Material Pack Cont. Colour Tools Article-No. Q18R 2.6 105.0 24.0 80 PA66W Black (BK) 100 pcs. 2;4-6 109-00059 Q18I 2.6 155.0 40.0 80 PA66W Black (BK) 100 pcs. 2;4-6 109-00062 Q18L 2.6 195.0 50.0 80 PA66W Black (BK) 100 pcs. 2;4-6 109-00065 Q30R 3.6 160.0 38.0 130 PA66W Black (BK) 100 pcs. 2;4-6 109-00068 Q30L 3.6 200.0 50.0 130 PA66W Black (BK) 100 pcs. 2;4-6 109-00070 Q30LR 3.6 250.0 65.0 130 PA66W Black (BK) 100 pcs. 2;4-6 109-00072 Q50R 4.7 210.0 50.0 220 PA66W Black (BK) 100 pcs. 2-10 109-00076 Q50I 4.7 290.0 75.0 220 PA66W Black (BK) 100 pcs. 2-10 109-00078 Q50L 4.7 410.0 110.0 220 PA66W Black (BK) 100 pcs. 2-10 109-00080 Q120I 7.7 300.0 70.0 530 PA66W Black (BK) 100 pcs. 3;9-12 109-00082 Q120R 7.7 420.0 110.0 530 PA66W Black (BK) 100 pcs. 3;9-12 109-00084 Q120M 7.7 520.0 130.0 530 PA66W Black (BK) 100 pcs. 3;9-12 109-00086 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Date of issue: October 2015 Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 MK9 MK9HT MK9P For more information on toolings please refer to the Application Tooling chapter. Further information at www.HellermannTyton.com/fixings 57 Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties with open head for temperatures up to +105 °C (heat stabilised) Q-Series in PA66HS natural and black Q-Series cable ties for bundling and securing cables, pipes and hoses. These innovative and effective cable ties enable a simple and quick installation, even in difficult applications. Features and Benefits • Heat stabilised cable ties available in a wide range of sizes • Open lock head for quick and easy insertion • Integrated pre-locking function • More than 25 % faster to apply than a standard cable tie • Inside serration for a strong hold around bundles • Easy application either manually or with a processing tool • Higher temperature resistance up to +105 °C Q-tie cable ties: choose from a wide product range in different sizes. L Material specification please see page 24. W Q-Series TYPE Q18R Q18I Q18L Q30R Q30L Q30LR Q50R Q50I Q50L Q120I Q120R Q120M Width (W) Length (L) Bundle Ø max. Material Colour Pack Cont. 2.6 105.0 24.0 Tools Article-No. 80 PA66HS Black (BK) 100 pcs. 2;4-6 2.6 105.0 109-00088 24.0 80 PA66HS Natural (NA) 100 pcs. 2;4-6 2.6 109-00117 155.0 40.0 80 PA66HS Black (BK) 100 pcs. 2;4-6 109-00091 2.6 155.0 40.0 80 PA66HS Natural (NA) 100 pcs. 2;4-6 109-00120 2.6 195.0 50.0 80 PA66HS Black (BK) 100 pcs. 2;4-6 109-00094 2.6 195.0 50.0 80 PA66HS Natural (NA) 100 pcs. 2;4-6 109-00123 3.6 160.0 38.0 130 PA66HS Black (BK) 100 pcs. 2;4-6 109-00097 3.6 160.0 38.0 130 PA66HS Natural (NA) 100 pcs. 2;4-6 109-00126 3.6 200.0 50.0 130 PA66HS Black (BK) 100 pcs. 2;4-6 109-00099 3.6 200.0 50.0 130 PA66HS Natural (NA) 100 pcs. 2;4-6 109-00128 3.6 250.0 65.0 130 PA66HS Black (BK) 100 pcs. 2;4-6 109-00101 3.6 250.0 65.0 130 PA66HS Natural (NA) 100 pcs. 2;4-6 109-00130 4.7 210.0 50.0 220 PA66HS Black (BK) 100 pcs. 2-10 109-00105 4.7 210.0 50.0 220 PA66HS Natural (NA) 100 pcs. 2-10 109-00134 4.7 290.0 75.0 220 PA66HS Black (BK) 100 pcs. 2-10 109-00107 4.7 290.0 75.0 220 PA66HS Natural (NA) 100 pcs. 2-10 109-00136 4.7 410.0 110.0 220 PA66HS Black (BK) 100 pcs. 2-10 109-00109 4.7 410.0 110.0 220 PA66HS Natural (NA) 100 pcs. 2-10 109-00138 7.7 300.0 70.0 530 PA66HS Black (BK) 100 pcs. 3;9-12 109-00111 7.7 300.0 70.0 530 PA66HS Natural (NA) 100 pcs. 3;9-12 109-00140 7.7 420.0 110.0 530 PA66HS Black (BK) 100 pcs. 3;9-12 109-00113 7.7 420.0 110.0 530 PA66HS Natural (NA) 100 pcs. 3;9-12 109-00142 7.7 520.0 130.0 530 PA66HS Black (BK) 100 pcs. 3;9-12 109-00115 7.7 520.0 130.0 530 PA66HS Natural (NA) 100 pcs. 3;9-12 109-00144 Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 MK9 MK9HT MK9P For more information on toolings please refer to the Application Tooling chapter. 58 Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylene Tetrafluoroethylene E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV-resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6, high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6, high impact modified glass-fibre reinforced Polyamide 6.6, heat and UV stabilised Polyamide 6.6, UV-resistant Colour** Material Properties* Flammability Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • Resistance to radioactivity • UV-resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances 24 Material Specifications Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6 V0 MATERIAL Material Properties* Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions SP -50 °C to +150 °C Black (BK) Halogen free • UV-resistant • Good chemical resistance to: most acids, alkalis and oils PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyamide 6.6 V0, High Oxygen Index Polyester Polyetheretherketone Polypropylene, EthylenePropylene-DienTerpolymere-rubber free of Nitrosamine Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL94 HB • Floats in certain liquids • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Non burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL94 HB • High elasticity • Good chemical resistance to: acids, bases and oxidizing agents Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. 1.0 Material Specifications **More colours on request. Date of issue: October 2015 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 25
109-00043 价格&库存
很抱歉,暂时无法提供与“109-00043”相匹配的价格&库存,您可以联系我们找货
