TERMINATIONS
& BUNDLING
Stainless Steel Cable Ties
10
20” - 100lb SSS20.0SV
27” - 100lb SSS27.0SV
5”
- 100lb SSS5.00SV 250lb SSH5.00SV
7½” - 100lb SSS7.50SV 250lb SSH7.50SV
14½” - 100lb SSS14.5SV 250lb SSH14.5SV
25
0lb
0lb
High temperature stainless steel cable ties are great for harsh environments. Perfect for installing
heavy duty and high temp sleeving.
250lb SSH20.0SV
250lb SSH27.0SV
Stainless Steel Cable Tie Tool
Cable Tie Gun for steel ties cuts off excess strap when the selected tension setting is achieved.
Produces consistent tension from tie to tie and saves installation time with one easy action.
Cable Tie Gun - SSTG
Chrome Ties
rS
V
Finish your custom application with genuine chrome cable ties from Techflex®. Perfect for finishing
wire or hose projects with Chrome or Metallic Mylar® sleeving. The highly polished finish matches
any metallic installation and provides a strong and attractive finish that resists wear, abrasion, and
damage.
Sil
ve
3¾” - CBC3.75SV
7½” - CBC7.50SV
Mylar® is a registered trademark of DuPont Corporation.
These cable ties are safer, smoother, and stronger than traditional cable ties. You can apply them to their
bundle with side cutters or any industry installation tool. Manufactured from dependable 6/6 nylon,
these unique cable ties are available in 7” and 14” lengths in either Clear (CL) or UV stabilized
Black (BK).
7” - LPR7.00
14” - LPR14.0
Cle
a
CL r
Bla
BK ck
Low Profile Cable Ties
Automatic Tension/Cutoff Cable Tie Tool
Single trigger tool tightens cable ties to a tension that the user presets with the tensioning wheel in the
grip. Easy, one-handed operation and low profile design for installations in tight or hard to reach
areas. For plastic cable ties up to 50 lb.
Cable Tie Gun - AP-200
High Strength Nylon Cable Ties
Bl
a
BK ck
W
h
W ite
H
Re
RD d
a
ORnge
Or
on
NYYell
ow
Ne
Gr
e
GN en
Bl
u
BL e
Pu
r
PP ple
Cle
CL ar
ro
BR wn
*B
r
GY ay
k
*G
eo
n
NP Pin
*N
eo
NRn Re
d
*N
*N
eo
n
NG Gre
en
Easy to use Nylon Cable Ties are perfect for virtually any bundling or management application! These economical, yet strong ties resist heat
and abrasion.
7½” - TYR7.50 Metal Barb
3¾” - TYR3.75 Metal Barb
7½” - CBR7.50 Plastic Barb*
3¾” - CBR3.75 Plastic Barb*
121
很抱歉,暂时无法提供与“VST8.00OR”相匹配的价格&库存,您可以联系我们找货
