Specification Sheet
Part Number: 156-00557
Cable Tie & Edge Clip, 8.0" Long, EC24, 3-6 mm Panel, 50lb, PA66UV/PA66HIRHSUV, Black, 500/pkg
Article Number
156-00557
Type
T50REC24
Color
Black (BK)
Features & Benefits
• Edge Clip applies easily to plastic and metal sheets without the need for a
mounting hole. • Edge Clip provides low insertion force and high extraction
force ideal for assembly environments. • Two piece assembly allows the mount
to slide along the strap ensuring proper orientation.
Quantity Per
bag
Product Description
The cable tie and edge clip assembly is ideal for use where holes are not
acceptable or where adhesives will fail due to temperature problems. Edge
clips are widely used for fixing and bundling cables and wires within
automotive, trucking, heavy equipment, solar panel, wind power, and white
goods equipment manufacturing.
Short Description
Global Part Name
T50REC24-PA66UV/PA66HIRHS-BK
Minimum Tensile Strength (Imperial)
50.0
Minimum Tensile Strength (Metric)
225
Length L (Imperial)
8.0
Length L (Metric)
202.0
Fixation Method
EdgeClip, sideway, assembled, 2 piece
Identification Plate Position
none
Variant
Inside Serrated
Width W (Imperial)
0.18
Width W (Metric)
4.6
Bundle Diameter Min (Imperial)
0.20
Bundle Diameter Min (Metric)
5.0
Bundle Diameter Max (Imperial)
2.0
Bundle Diameter Max (Metric)
50.0
Thickness T (Imperial)
0.05
Thickness T (Metric)
1.2
Height H (Imperial)
0.05
Height H (Metric)
1.2
Panel Thickness Min(Imperial)
0.12
Panel Thickness Max(Imperial)
0.24
Panel Thickness Min (Metric)
3.0
Panel Thickness Max (Metric)
6.0
Material
Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Polyamide
6.6 heat stabilized (PA66HS)
Material Shortcut
PA66HIRHS PA66UV
Material Cable Tie
Polyamide 6.6 UV-stabilized (PA66UV)
Flammability
UL 94 HB
Operating Temperature (Metric)
-40°F to +185°F (-40°C to +85°C) -40°F to +230°F (-40°C to +110°C)
ROHS Complaint
Yes
Package Quantity(Imperial)
500
Package Quantity (Metric)
500
Customs Number
3926909987
© 2018 HellermannTyton. All rights reserved.
Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
很抱歉,暂时无法提供与“156-00557”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+8.84728500+1.14678
