156-00541
156-00541
    HELLERMAN(海尔曼太通)
    CABLE TIE/EDGE CLIP 50LB 200MM
156-00541 数据手册
156-00541 Article Number: 156-00541 Description: Cable Tie and Edge Clip, 8.0" Long, EC5A, Panel Thickness ±50lb, PA66HS, Black, 500/bag Base Data Local Order Number 156-00541 Type T50REC5A Color Black (BK) Features and benefits ‡Edge Clip applies easily to plastic and metal sheets without the need for a mounting hole. ‡Edge Clip provides low insertion force and high extraction force ideal for assembly environments. ‡Two piece assembly allows the mount to slide along the strap ensuring proper orientation. Quantity Per bag Product Description The cable tie and edge clip assembly is ideal for use where holes are not acceptable or where adhesives will fail due to temperature problems. Edge clips are widely used for fixing and bundling cables and wires within automotive, trucking, heavy equipment, solar panel, wind power, and white goods equipment manufacturing. Short Description Cable Tie and Edge Clip, 8.0" Long, EC5A, Panel Thickness ±50lb, PA66HS, Black, 500/bag Minimum Tensile Strength (Imperial) 50.0lbs Minimum Tensile Strength (Metric) 225N Length L (Imperial) 8.0" Length L (Metric) 200.0mm Length L2 (Imperial) 0.55" Fixation Method EdgeClip, sideway, assembled, 2 piece Identification Plate Position none Length L2 (Metric) 14.0mm Variant Inside Serrated Width W (Imperial) 0.18" Width W (Metric) 4.6mm Width W2 (Imperial) 0.39" Width W2 (Metric) 10.0mm Product Dimensions generated on: 5/9/2017 156-00541 Product Dimensions Height H (Imperial) 0.05" Height H (Metric) 1.2mm Height H2 (Imperial) 0.61" Height H2 (Metric) 15.5mm Bundle Diameter Min. (Imperial) 0.06" Bundle Diameter Min. (Metric) 4.0mm Bundle Diameter Max. (Imperial) 2.0" Bundle Diameter Max. (Metric) 45.0mm Panel Thickness Max. (Imperial) 0.12" Panel Thickness Max. (Metric) 3.0mm Panel Thickness Min. (Imperial) 0.04" Panel Thickness Min. (Metric) 1.0mm Thickness T (Imperial) 0.05" Thickness T (Metric) 1.2mm Material Polyamide 6.6 high impact modified, heat stabilized, UV resistant (PA66HIRHS) Material Shortcut PA66HIRHS Material Cable Tie Polyamide 6.6 heat stabilized (PA66HS) Flammability UL 94 HB Operating Temperature -40°F to +221°F (-40°C to +105°C) ROHS Compliant Yes Package Quantity (Imperial) 500 Package Quantity (Metric) 500 Customs Number(Schedule B) 3926909987 Weight (Metric) 4.5kg Material and Specifications Logistic and Packaging generated on: 5/9/2017
156-00541 价格&库存
很抱歉,暂时无法提供与“156-00541”相匹配的价格&库存,您可以联系我们找货
  • 500+10.33252500+1.34064
