156-00863
156-00863
    HELLERMAN(海尔曼太通)
    CABLE TIE/EDGE CLIP 50LB 5.9"
156-00863 数据手册
Specification Sheet Part Number: 156-00863 Outside Serrated Cable Tie & Edge Clip, 5.9" Long, EC5B, 1–3 mm Panel, 50lb, PA66HS, Black, 500/pkg Article Number 156-00863 Type T50SOSEC5B Color Black (BK) Features & Benefits •Edge Clip applies easily to plastic and metal sheets without the need for a mounting hole. •Edge Clip provides low insertion force and high extraction force ideal for assembly environments. •Two piece assembly allows the mount to slide along the strap ensuring proper orientation. •Cable tie is outside serrated to reduce bundle chafing. Quantity Per bag Product Description HellermannTyton's Two Piece Edge Clip with Cable Tie Assemblies are designed specifically to route bundles by securing them to the edge of a plastic or metal sheet without the need for a mountinig hole. The clip is easy to secure and the extraction force is high due to the integrated metal clamp that holds the edge clip in place. Short Description Outside Serrated Cable Tie & Edge Clip, 5.9" Long, EC5B, 1–3 mm Panel, 50lb, PA66HS, Black, 500/pkg Global Part Name T50SOSEC5B-PA66HS/PA66HIRHS-BK Minimum Tensile Strength (Imperial) 50.0 Minimum Tensile Strength (Metric) 225 Length L (Imperial) 6.0 Length L (Metric) 150.0 Fixation Method EdgeClip, sideway, assembled, 2 piece Identification Plate Position none Releasable Closure No Variant Outside Serrated Width W (Imperial) 0.18 Width W (Metric) 4.6 Bundle Diameter Min (Imperial) 0.20 Bundle Diameter Min (Metric) 5.0 Bundle Diameter Max (Imperial) 1.4 Bundle Diameter Max (Metric) 35.0 Thickness T (Imperial) 0.05 Thickness T (Metric) 1.2 Height H (Imperial) .50 Height H (Metric) 1.30 Panel Thickness Min(Imperial) 0.04 Panel Thickness Max(Imperial) 0.12 Panel Thickness Min (Metric) 1.0 Panel Thickness Max (Metric) 3.0 Material Polyamide 6.6, high impact modified, heat stabilized (PA66HIRHS) Polyamide 6.6 heat stabilized (PA66HS) Material Shortcut PA66HIRHS PA66HS Material Cable Tie Polyamide 6.6 heat stabilized (PA66HS) Flammability UL 94 HB Operating Temperature (Metric) -40°F to +230°F (-40°C to +110°C) -40°F to +221°F (-40°C to +105°C) ROHS Complaint Yes Package Quantity(Imperial) 500 Package Quantity (Metric) 500 Customs Number 3926909987 Weight (Metric) 4.5 © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
156-00863 价格&库存
很抱歉,暂时无法提供与“156-00863”相匹配的价格&库存,您可以联系我们找货
