132-00008
132-00008
    HELLERMAN(海尔曼太通)
    BUTTONHEADTIE130LB10.5"
132-00008 数据手册
Specification Sheet Part Number: 132-00008 Button Head Cable Tie with Retainers and Pilot Bushings, 10.5" Long, PA66HIRHSUV, Black, 50/pkg Article Number 132-00008 Type BT130RDP Color Black (BK) Features & Benefits • Unique two piece tie allows parallel entry and exit through the head for easy assembly. • High impact, heat stabilized material gives strength needed for trucking and heavy equipment applications. Quantity Per bag Product Description The button head tie is a two piece tie providing for parallel entry and exit through the head. The strap contains serrations on both sides, and has two opposed pawls recessed within a domed head. This design allows the strap to be directed clockwise or counter-clockwise prior to insertion into the head, enabling bi-directional looping. Short Description Button Head Cable Tie with Retainers and Pilot Bushings, 10.5" Long, PA66HIRHSUV, Black, 50/pkg Global Part Name BT130RDP-PA66HIRHSUV-BK Minimum Tensile Strength (Imperial) 130 Minimum Tensile Strength (Metric) 578 Length L (Imperial) 10.5 Length L (Metric) 267.0 Fixation Method Connector Clip Identification Plate Position none Releasable Closure No Tie Closure plastic pawl Variant Outside Serrated Width W (Imperial) 0.3 Width W (Metric) 7.6 Bundle Diameter Min (Imperial) 0.06 Bundle Diameter Min (Metric) 1.5 Bundle Diameter Max (Imperial) 2.9 Bundle Diameter Max (Metric) 73.0 Mounting Hole Diameter D (Metric) 25.4 mm Material Polyamide 6.6 high impact modified, heat and UV stabilized (PA66HIRHSUV) Material Shortcut PA66HIRHSUV Material Head Polyamide 6.6 heat stabilized (PA66HS) Flammability UL 94 HB Operating Temperature (Metric) -40°F to +185°F (-40°C to +85°C) Package Quantity(Imperial) 50 Package Quantity (Metric) 50 Customs Number 3926909988 © 2019 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
132-00008 价格&库存
很抱歉,暂时无法提供与“132-00008”相匹配的价格&库存,您可以联系我们找货
